[ Upstream commit b0fe66cf095016e0b238374c10ae366e1f087d11 ]
Currently, multi_v7_defconfig + CONFIG_FUNCTION_TRACER fails to build
with clang:
arm-linux-gnueabi-ld: kernel/softirq.o: in function `_local_bh_enable':
softirq.c:(.text+0x504): undefined reference to `mcount'
arm-linux-gnueabi-ld: kernel/softirq.o: in function `__local_bh_enable_ip':
softirq.c:(.text+0x58c): undefined reference to `mcount'
arm-linux-gnueabi-ld: kernel/softirq.o: in function `do_softirq':
softirq.c:(.text+0x6c8): undefined reference to `mcount'
arm-linux-gnueabi-ld: kernel/softirq.o: in function `irq_enter':
softirq.c:(.text+0x75c): undefined reference to `mcount'
arm-linux-gnueabi-ld: kernel/softirq.o: in function `irq_exit':
softirq.c:(.text+0x840): undefined reference to `mcount'
arm-linux-gnueabi-ld: kernel/softirq.o:softirq.c:(.text+0xa50): more undefined references to `mcount' follow
clang can emit a working mcount symbol, __gnu_mcount_nc, when
'-meabi gnu' is passed to it. Until r369147 in LLVM, this was
broken and caused the kernel not to boot with '-pg' because the
calling convention was not correct. Always build with '-meabi gnu'
when using clang but ensure that '-pg' (which is added with
CONFIG_FUNCTION_TRACER and its prereq CONFIG_HAVE_FUNCTION_TRACER)
cannot be added with it unless this is fixed (which means using
clang 10.0.0 and newer).
Link: https://github.com/ClangBuiltLinux/linux/issues/35
Link: https://bugs.llvm.org/show_bug.cgi?id=33845
Link: https://github.com/llvm/llvm-project/commit/16fa8b09702378bacfa3d07081afe6b353b99e60
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
After discussing with the subarch maintainers and Hilscher,
we concluded that the netx subarchitecture (Netx 100/500)
is no longer maintained or tested, and noone will miss it
if we delete it. So delete it.
There is a newer Netx 4000 architecture which we may see
included at some point, but this will be supported using
the standard multiplatform and devicetree mechanisms and is
easier to develop from scratch.
Cc: Michael Trensch <MTrensch@hilscher.com>
Acked-By: Robert Schwebel <r.schwebel@pengutronix.de>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Pull ARM updates from Russell King:
"ARM development updates:
- more unified assembly conversions for clang
- drop obsolete -mauto-it assembler option
- remove arm_memory_present in preference to the generic version
- remove unused asm/limits.h header
- vdso linker update
We tried to make the assembler warn if unified syntax was not used,
but unfortunately older versions of GCC warn, so the commit had to be
reverted"
* tag 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
Revert "ARM: 8846/1: warn if divided syntax assembler is used"
ARM: 8858/1: vdso: use $(LD) instead of $(CC) to link VDSO
ARM: 8855/1: remove unused <asm/limits.h>
ARM: 8850/1: use memblocks_present
ARM: 8854/1: drop -mauto-it
ARM: 8853/1: drop WASM to work around LLVM issue
ARM: 8852/1: uaccess: use unified assembler language syntax
ARM: 8851/1: add TUSERCOND() macro for conditional postfix
This reverts commit e8c24bbda7d5eba6df5ca45e5462fd3f96b8f217.
GCC 4.7, which is still permitted, emits code using the original
syntax. This means we end up with lots of assembler warnings when
building with a currently-supported version of gcc.
Revert the commit (with fixups to keep the follow-on -mauto-it
change) to avoid these warnings.
The assembler option -mauto-it is no longer a valid option. The last
remaining references have been removed from the documentation in
July 2009 [0].
The currently supported binutils version is 2.20 (released in
September 2009) or higher where gas supports -mimplicit-it=always.
Drop the fallback to -mauto-it and use -mimplicit-it=always only.
[0] https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=529707530657a333a304c651c808ea630c955223
Signed-off-by: Stefan Agner <stefan@agner.ch>
Remove the -mno-warn-deprecated assembler flag to make sure the GNU
assembler warns in case non-unified syntax is used.
Acked-by: Nicolas Pitre <nico@linaro.org>
Move the Trusted Foundations support out of arch/arm/firmware and into
drivers/firmware where most other firmware support implementations are
located.
Signed-off-by: Thierry Reding <treding@nvidia.com>
- An improvement from Ard Biesheuvel, who noted that the identity map
setup was taking a long time due to flush_cache_louis().
- Update a comment about dma_ops from Wolfram Sang.
- Remove use of "-p" with ld, where this flag has been a no-op since
2004.
- Remove the printing of the virtual memory layout, which is no longer
useful since we hide pointers.
- Correct SCU help text.
- Remove legacy TWD registration method.
- Add pgprot_device() implementation for mapping PCI sysfs resource
files.
- Initialise PFN limits earlier for kmemleak.
- Fix argument count to match macro definition (affects clang builds)
- Use unified assembler language almost everywhere for clang, and other
clang improvements (from Stefan Agner, Nathan Chancellor).
- Support security extension for noMMU and other noMMU cleanups (from
Vladimir Murzin).
- Remove unnecessary SMP bringup code (which was incorrectly copy'n'
pasted from the ARM platform implementations) and remove it from the
arch code to discourge further copys of it appearing.
- Add Cortex A9 erratum preventing kexec working on some SoCs.
- AMBA bus identification updates from Mike Leach.
- More use of raw spinlocks to avoid -RT kernel issues (from Yang Shi
and Sebastian Andrzej Siewior).
- MCPM hyp/svc mode mismatch fixes from Marek Szyprowski.
* tag 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (32 commits)
ARM: 8849/1: NOMMU: Fix encodings for PMSAv8's PRBAR4/PRLAR4
ARM: 8848/1: virt: Align GIC version check with arm64 counterpart
ARM: 8847/1: pm: fix HYP/SVC mode mismatch when MCPM is used
ARM: 8845/1: use unified assembler in c files
ARM: 8844/1: use unified assembler in assembly files
ARM: 8843/1: use unified assembler in headers
ARM: 8841/1: use unified assembler in macros
ARM: 8840/1: use a raw_spinlock_t in unwind
ARM: 8839/1: kprobe: make patch_lock a raw_spinlock_t
ARM: 8837/1: coresight: etmv4: Update ID register table to add UCI support
ARM: 8836/1: drivers: amba: Update component matching to use the CoreSight UCI values.
ARM: 8838/1: drivers: amba: Updates to component identification for driver matching.
ARM: 8833/1: Ensure that NEON code always compiles with Clang
ARM: avoid Cortex-A9 livelock on tight dmb loops
ARM: smp: remove arch-provided "pen_release"
ARM: actions: remove boot_lock and pen_release
ARM: oxnas: remove CPU hotplug implementation
ARM: qcom: remove unnecessary boot_lock
ARM: 8832/1: NOMMU: Limit visibility for CONFIG_FLASH_{MEM_BASE,SIZE}
ARM: 8831/1: NOMMU: pmsa-v8: remove unneeded semicolon
This adds the basic M10V SoC support under arch/arm.
Since all cores are activated in the custom bootloader before booting
linux, it is necessary to wait for the secondary-cores using cpu-enable-
method and special sram.
Signed-off-by: Sugaya Taichi <sugaya.taichi@socionext.com>
This option is not supported by lld:
ld.lld: error: unknown argument: -p
This has been a no-op in binutils since 2004 (see commit dea514f51da1 in
that tree). Given that the lowest officially supported of binutils for
the kernel is 2.20, which was released in 2009, nobody needs this flag
around so just remove it. Commit 1a381d4a0a9a ("arm64: remove no-op -p
linker flag") did the same for arm64.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Pull more ARM SoC updates from Olof Johansson:
"A few updates that we merged late but are low risk for regressions for
other platforms (and a few other straggling patches):
- I mis-tagged the 'drivers' branch, and missed 3 patches. Merged in
here. They're for a driver for the PL353 SRAM controller and a
build fix for the qualcomm scm driver.
- A new platform, RDA Micro RDA8810PL (Cortex-A5 w/ integrated
Vivante GPU, 256MB RAM, Wifi). This includes some acked
platform-specific drivers (serial, etc). This also include DTs for
two boards with this SoC, OrangePi 2G and OrangePi i86.
- i.MX8 is another new platform (NXP, 4x Cortex-A53 + Cortex-M4, 4K
video playback offload). This is the first i.MX 64-bit SoC.
- Some minor updates to Samsung boards (adding a few peripherals in
DTs).
- Small rework for SMP bootup on STi platforms.
- A couple of TEE driver fixes.
- A couple of new config options (bcm2835 thermal, Uniphier MDMAC)
enabled in defconfigs"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (27 commits)
ARM: multi_v7_defconfig: enable CONFIG_UNIPHIER_MDMAC
arm64: defconfig: Re-enable bcm2835-thermal driver
MAINTAINERS: Add entry for RDA Micro SoC architecture
tty: serial: Add RDA8810PL UART driver
ARM: dts: rda8810pl: Add interrupt support for UART
dt-bindings: serial: Document RDA Micro UART
ARM: dts: rda8810pl: Add timer support
ARM: dts: Add devicetree for OrangePi i96 board
ARM: dts: Add devicetree for OrangePi 2G IoT board
ARM: dts: Add devicetree for RDA8810PL SoC
ARM: Prepare RDA8810PL SoC
dt-bindings: arm: Document RDA8810PL and reference boards
dt-bindings: Add RDA Micro vendor prefix
ARM: sti: remove pen_release and boot_lock
arm64: dts: exynos: Add Bluetooth chip to TM2(e) boards
arm64: dts: imx8mq-evk: enable watchdog
arm64: dts: imx8mq: add watchdog devices
MAINTAINERS: add i.MX8 DT path to i.MX architecture
arm64: add support for i.MX8M EVK board
arm64: add basic DTS for i.MX8MQ
Introduce ARCH_RDA and mach-rda for RDA Micro SoCs.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
On ARM, we currently only change the value of the stack canary when
switching tasks if the kernel was built for UP. On SMP kernels, this
is impossible since the stack canary value is obtained via a global
symbol reference, which means
a) all running tasks on all CPUs must use the same value
b) we can only modify the value when no kernel stack frames are live
on any CPU, which is effectively never.
So instead, use a GCC plugin to add a RTL pass that replaces each
reference to the address of the __stack_chk_guard symbol with an
expression that produces the address of the 'stack_canary' field
that is added to struct thread_info. This way, each task will use
its own randomized value.
Cc: Russell King <linux@armlinux.org.uk>
Cc: Emese Revfy <re.emese@gmail.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: kernel-hardening@lists.openwall.com
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull Devicetree updates from Rob Herring:
"A bit bigger than normal as I've been busy this cycle.
There's a few things with dependencies and a few things subsystem
maintainers didn't pick up, so I'm taking them thru my tree.
The fixes from Johan didn't get into linux-next, but they've been
waiting for some time now and they are what's left of what subsystem
maintainers didn't pick up.
Summary:
- Sync dtc with upstream version v1.4.7-14-gc86da84d30e4
- Work to get rid of direct accesses to struct device_node name and
type pointers in preparation for removing them. New helpers for
parsing DT cpu nodes and conversions to use the helpers. printk
conversions to %pOFn for printing DT node names. Most went thru
subystem trees, so this is the remainder.
- Fixes to DT child node lookups to actually be restricted to child
nodes instead of treewide.
- Refactoring of dtb targets out of arch code. This makes the support
more uniform and enables building all dtbs on c6x, microblaze, and
powerpc.
- Various DT binding updates for Renesas r8a7744 SoC
- Vendor prefixes for Facebook, OLPC
- Restructuring of some ARM binding docs moving some peripheral
bindings out of board/SoC binding files
- New "secure-chosen" binding for secure world settings on ARM
- Dual licensing of 2 DT IRQ binding headers"
* tag 'devicetree-for-4.20' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (78 commits)
ARM: dt: relicense two DT binding IRQ headers
power: supply: twl4030-charger: fix OF sibling-node lookup
NFC: nfcmrvl_uart: fix OF child-node lookup
net: stmmac: dwmac-sun8i: fix OF child-node lookup
net: bcmgenet: fix OF child-node lookup
drm/msm: fix OF child-node lookup
drm/mediatek: fix OF sibling-node lookup
of: Add missing exports of node name compare functions
dt-bindings: Add OLPC vendor prefix
dt-bindings: misc: bk4: Add device tree binding for Liebherr's BK4 SPI bus
dt-bindings: thermal: samsung: Add SPDX license identifier
dt-bindings: clock: samsung: Add SPDX license identifiers
dt-bindings: timer: ostm: Add R7S9210 support
dt-bindings: phy: rcar-gen2: Add r8a7744 support
dt-bindings: can: rcar_can: Add r8a7744 support
dt-bindings: timer: renesas, cmt: Document r8a7744 CMT support
dt-bindings: watchdog: renesas-wdt: Document r8a7744 support
dt-bindings: thermal: rcar: Add device tree support for r8a7744
Documentation: dt: Add binding for /secure-chosen/stdout-path
dt-bindings: arm: zte: Move sysctrl bindings to their own doc
The purpose of CONFIG_CPU_32v3 is to avoid ldrh/strh on the RiscPC,
which is pretty much an ARMv4 device, except its bus will choke on the
half-words. The way to make the C compiler not output ldrh/strh is with
-march=armv3, which doesn't support them in the ISA. However, this
prevents certain cryptography code from working that uses instructions
like umull. Fortunately there's also -march=armv3m that does support
those, making it possible to continue assembling optimized cryptography
routines for our beloved RiscPC.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
There is nothing arch specific about building dtb files other than their
location under /arch/*/boot/dts/. Keeping each arch aligned is a pain.
The dependencies and supported targets are all slightly different.
Also, a cross-compiler for each arch is needed, but really the host
compiler preprocessor is perfectly fine for building dtbs. Move the
build rules to a common location and remove the arch specific ones. This
is done in a single step to avoid warnings about overriding rules.
The build dependencies had been a mixture of 'scripts' and/or 'prepare'.
These pull in several dependencies some of which need a target compiler
(specifically devicetable-offsets.h) and aren't needed to build dtbs.
All that is really needed is dtc, so adjust the dependencies to only be
dtc.
This change enables support 'dtbs_install' on some arches which were
missing the target.
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Paul Burton <paul.burton@mips.com>
Acked-by: Ley Foon Tan <ley.foon.tan@intel.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Cc: Michal Marek <michal.lkml@markovi.net>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: James Hogan <jhogan@kernel.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: linux-kbuild@vger.kernel.org
Cc: linux-snps-arc@lists.infradead.org
Cc: uclinux-h8-devel@lists.sourceforge.jp
Cc: linux-mips@linux-mips.org
Cc: nios2-dev@lists.rocketboards.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-xtensa@linux-xtensa.org
Signed-off-by: Rob Herring <robh@kernel.org>
You can always prefix machine/plat header search paths with
$(srctree)/ because $(srctree) is '.' for in-tree building.
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- add build_{menu,n,g,x}config targets for compile-testing Kconfig
- fix and improve recursive dependency detection in Kconfig
- fix parallel building of menuconfig/nconfig
- fix syntax error in clang-version.sh
- suppress distracting log from syncconfig
- remove obsolete "rpm" target
- remove VMLINUX_SYMBOL(_STR) macro entirely
- fix microblaze build with CONFIG_DYNAMIC_FTRACE
- move compiler test for dead code/data elimination to Kconfig
- rename well-known LDFLAGS variable to KBUILD_LDFLAGS
- misc fixes and cleanups
* tag 'kbuild-v4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: rename LDFLAGS to KBUILD_LDFLAGS
kbuild: pass LDFLAGS to recordmcount.pl
kbuild: test dead code/data elimination support in Kconfig
initramfs: move gen_initramfs_list.sh from scripts/ to usr/
vmlinux.lds.h: remove stale <linux/export.h> include
export.h: remove VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR()
Coccinelle: remove pci_alloc_consistent semantic to detect in zalloc-simple.cocci
kbuild: make sorting initramfs contents independent of locale
kbuild: remove "rpm" target, which is alias of "rpm-pkg"
kbuild: Fix LOADLIBES rename in Documentation/kbuild/makefiles.txt
kconfig: suppress "configuration written to .config" for syncconfig
kconfig: fix "Can't open ..." in parallel build
kbuild: Add a space after `!` to prevent parsing as file pattern
scripts: modpost: check memory allocation results
kconfig: improve the recursive dependency report
kconfig: report recursive dependency involving 'imply'
kconfig: error out when seeing recursive dependency
kconfig: add build-only configurator targets
scripts/dtc: consolidate include path options in Makefile
Commit a0f97e06a43c ("kbuild: enable 'make CFLAGS=...' to add
additional options to CC") renamed CFLAGS to KBUILD_CFLAGS.
Commit 222d394d30e7 ("kbuild: enable 'make AFLAGS=...' to add
additional options to AS") renamed AFLAGS to KBUILD_AFLAGS.
Commit 06c5040cdb13 ("kbuild: enable 'make CPPFLAGS=...' to add
additional options to CPP") renamed CPPFLAGS to KBUILD_CPPFLAGS.
For some reason, LDFLAGS was not renamed.
Using a well-known variable like LDFLAGS may result in accidental
override of the variable.
Kbuild generally uses KBUILD_ prefixed variables for the internally
appended options, so here is one more conversion to sanitize the
naming convention.
I did not touch Makefiles under tools/ since the tools build system
is a different world.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
Pull ARM 32-bit SoC platform updates from Olof Johansson:
"Most of the SoC updates in this cycle are cleanups and moves to more
modern infrastructure:
- Davinci was moved to common clock framework
- OMAP1-based Amstrad E3 "Superphone" saw a bunch of cleanups to the
keyboard interface (bitbanged AT keyboard via GPIO).
- Removal of some stale code for Renesas platforms
- Power management improvements for i.MX6LL"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (112 commits)
ARM: uniphier: select RESET_CONTROLLER
arm64: uniphier: select RESET_CONTROLLER
ARM: uniphier: remove empty Makefile
ARM: exynos: Clear global variable on init error path
ARM: exynos: Remove outdated maintainer information
ARM: shmobile: Always enable ARCH_TIMER on SoCs with A7 and/or A15
ARM: shmobile: r8a7779: hide unused r8a7779_platform_cpu_kill
soc: r9a06g032: don't build SMP files for non-SMP config
ARM: shmobile: Add the R9A06G032 SMP enabler driver
ARM: at91: pm: configure wakeup sources for ULP1 mode
ARM: at91: pm: add PMC fast startup registers defines
ARM: at91: pm: Add ULP1 mode support
ARM: at91: pm: Use ULP0 naming instead of slow clock
ARM: hisi: handle of_iomap and fix missing of_node_put
ARM: hisi: check of_iomap and fix missing of_node_put
ARM: hisi: fix error handling and missing of_node_put
ARM: mx5: Set the DBGEN bit in ARM_GPC register
ARM: imx51: Configure M4IF to avoid visual artifacts
ARM: imx: call imx6sx_cpuidle_init() conditionally for 6sll
ARM: imx: fix i.MX6SLL build
Pull Kbuild updates from Masahiro Yamada:
- verify depmod is installed before modules_install
- support build salt in case build ids must be unique between builds
- allow users to specify additional host compiler flags via HOST*FLAGS,
and rename internal variables to KBUILD_HOST*FLAGS
- update buildtar script to drop vax support, add arm64 support
- update builddeb script for better debarch support
- document the pit-fall of if_changed usage
- fix parallel build of UML with O= option
- make 'samples' target depend on headers_install to fix build errors
- remove deprecated host-progs variable
- add a new coccinelle script for refcount_t vs atomic_t check
- improve double-test coccinelle script
- misc cleanups and fixes
* tag 'kbuild-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (41 commits)
coccicheck: return proper error code on fail
Coccinelle: doubletest: reduce side effect false positives
kbuild: remove deprecated host-progs variable
kbuild: make samples really depend on headers_install
um: clean up archheaders recipe
kbuild: add %asm-generic to no-dot-config-targets
um: fix parallel building with O= option
scripts: Add Python 3 support to tracing/draw_functrace.py
builddeb: Add automatic support for sh{3,4}{,eb} architectures
builddeb: Add automatic support for riscv* architectures
builddeb: Add automatic support for m68k architecture
builddeb: Add automatic support for or1k architecture
builddeb: Add automatic support for sparc64 architecture
builddeb: Add automatic support for mips{,64}r6{,el} architectures
builddeb: Add automatic support for mips64el architecture
builddeb: Add automatic support for ppc64 and powerpcspe architectures
builddeb: Introduce functions to simplify kconfig tests in set_debarch
builddeb: Drop check for 32-bit s390
builddeb: Change architecture detection fallback to use dpkg-architecture
builddeb: Skip architecture detection when KBUILD_DEBARCH is set
arch/arm/mach-uniphier/Makefile has been unused for a long time.
Since commit ce99d0bf312d ("kbuild: clear LDFLAGS in the top Makefile"),
the top-level Makefile caters to this.
With the recent syntax extension, Kconfig is now able to evaluate the
compiler / toolchain capability.
However, accumulating flags to 'LD' is not compatible with the way
it works; 'LD' must be passed to Kconfig to call $(ld-option,...)
from Kconfig files. If you tweak 'LD' in arch Makefile depending on
CONFIG_CPU_BIG_ENDIAN, this would end up with circular dependency
between Makefile and Kconfig.
Pull ARM SoC platform updates from Olof Johansson:
"Here are the main updates for SoC support (besides DT additions) for
ARM 32- and 64-bit platforms. The branch also contains defconfig
updates to turn on drivers and options as needed on the various
platforms.
The largest parts of the delta are from cleanups moving platform data
and board file setup of TI platforms to ti-sysc bus drivers. There are
also some sweeping changes of eeprom and nand setup on Davinci, i.MX
and other platforms.
Samsung is removing support for Exynos5440, which was an oddball SoC
that hasn't been seen much use in designs.
Renesas is adding support for new SoCs (R-Car E3, RZ/G1C and RZ/N1D).
Linus Walleij is also removing support for ux500 (Sony Ericsson)
U8540/9540 SoCs that never made it to significant mass production and
products"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
MAINTAINERS: add NXP linux team maillist as i.MX reviewer
ARM: stm32: Don't select DMA unconditionally on STM32MP157C
arm64: defconfig: Enable PCIe on msm8996 and db820c
ARM: pxa3xx: enable external wakeup pins
ARM: pxa: stargate2: use device properties for at24 eeprom
arm64: defconfig: Enable HISILICON_LPC
arm64: defconfig: enable drivers for Poplar support
arm64: defconfig: Enable UFS on msm8996
ARM: berlin: switch to SPDX license identifier
arm: berlin: remove non-necessary flush_cache_all()
ARM: berlin: extend BG2CD Kconfig entry
OMAP: CLK: CLKSRC: Add suspend resume hooks
ARM: AM43XX: Add functions to save/restore am43xx control registers
ASoC: ams_delta: use GPIO lookup table
ARM: OMAP1: ams-delta: add GPIO lookup tables
bus: ti-sysc: Fix optional clocks array access
ARM: OMAP2+: Make sure LOGICRETSTATE bits are not cleared
ARM: OMAP2+: prm44xx: Inroduce cpu_pm notifiers for context save/restore
ARM: OMAP2+: prm44xx: Introduce context save/restore for am43 PRCM IO
ARM: OMAP2+: powerdomain: Introduce cpu_pm notifiers for context save/restore
- Initial round of Spectre variant 1 and variant 2 fixes for 32-bit ARM
- Clang support improvements
- nommu updates for v8 MPU
- enable ARM_MODULE_PLTS by default to avoid problems loading modules
with larger kernels
- vmlinux.lds and dma-mapping cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (31 commits)
ARM: spectre-v1: fix syscall entry
ARM: spectre-v1: add array_index_mask_nospec() implementation
ARM: spectre-v1: add speculation barrier (csdb) macros
ARM: KVM: report support for SMCCC_ARCH_WORKAROUND_1
ARM: KVM: Add SMCCC_ARCH_WORKAROUND_1 fast handling
ARM: spectre-v2: KVM: invalidate icache on guest exit for Brahma B15
ARM: KVM: invalidate icache on guest exit for Cortex-A15
ARM: KVM: invalidate BTB on guest exit for Cortex-A12/A17
ARM: spectre-v2: warn about incorrect context switching functions
ARM: spectre-v2: add firmware based hardening
ARM: spectre-v2: harden user aborts in kernel space
ARM: spectre-v2: add Cortex A8 and A15 validation of the IBE bit
ARM: spectre-v2: harden branch predictor on context switches
ARM: spectre: add Kconfig symbol for CPUs vulnerable to Spectre
ARM: bugs: add support for per-processor bug checking
ARM: bugs: hook processor bug checking into SMP and suspend paths
ARM: bugs: prepare processor bug infrastructure
ARM: add more CPU part numbers for Cortex and Brahma B15 CPUs
ARM: 8774/1: remove no-op macro VMLINUX_SYMBOL()
ARM: 8773/1: amba: Export amba_bustype
By default, sparse assumes a 64bit machine when compiled on x86-64
and 32bit when compiled on anything else.
This can of course create all sort of problems for the other archs, like
issuing false warnings ('shift too big (32) for type unsigned long'), or
worse, failing to emit legitimate warnings.
Fix this by adding the -m32/-m64 flag, depending on CONFIG_64BIT,
to CHECKFLAGS in the main Makefile (and so for all archs).
Also, remove the now unneeded -m32/-m64 in arch specific Makefiles.
Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com>
According to GCC documentation -m(no-)thumb-interwork is
meaningless in AAPCS configurations. Also clang does not
support the flag:
clang-5.0: error: unknown argument: '-mno-thumb-interwork'
Just drop -mno-thumb-interwork in AEABI configuration.
Since commit 9b5ba0df4ea4f940 ("ARM: shmobile: Introduce ARCH_RENESAS")
ARCH_RENESAS is a more appropriate platform dependency than the legacy
ARCH_SHMOBILE, hence use the former.
This will allow to drop ARCH_SHMOBILE on ARM in the near future.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Adds basic support for the Nuvoton NPCM750 BMC.
Signed-off-by: Brendan Higgins <brendanhiggins@google.com>
Reviewed-by: Tomer Maimon <tmaimon77@gmail.com>
Reviewed-by: Avi Fishman <avifishman70@gmail.com>
Tested-by: Tomer Maimon <tmaimon77@gmail.com>
Tested-by: Avi Fishman <avifishman70@gmail.com>
The GNU assembler has implemented the "unified syntax" parsing since
2005. This "unified" syntax is required when the kernel is built in
Thumb2 mode. However the "unified" syntax is a mixed bag of features,
including not requiring a `#' prefix with immediate operands. This leads
to situations where some code builds just fine in Thumb2 mode and fails
to build in ARM mode if that prefix is missing. This behavior
discrepancy makes build tests less valuable, forcing both ARM and Thumb2
builds for proper coverage.
Let's "fix" this issue by always using the "unified" syntax for both ARM
and Thumb2 mode. Given that the documented minimum binutils version that
properly builds the kernel is version 2.20 released in 2010, we can
assume that any toolchain capable of building the latest kernel is also
"unified syntax" capable.
Whith this, a bunch of macros used to mask some differences between both
syntaxes can be removed, with the side effect of making LTO easier.
Suggested-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Nicolas Pitre <nico@linaro.org>
"One of the most remarkable improvements in this cycle is, Kbuild is
now able to cache the result of shell commands. Some variables are
expensive to compute, for example, $(call cc-option,...) invokes the
compiler. It is not efficient to redo this computation every time,
even when we are not actually building anything. Kbuild creates a
hidden file ".cache.mk" that contains invoked shell commands and their
results. The speed-up should be noticeable.
Summary:
- Fix arch build issues (hexagon, sh)
- Clean up various Makefiles and scripts
- Fix wrong usage of {CFLAGS,LDFLAGS}_MODULE in arch Makefiles
- Cache variables that are expensive to compute
- Improve cc-ldopton and ld-option for Clang
- Optimize output directory creation"
* tag 'kbuild-v4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (30 commits)
kbuild: move coccicheck help from scripts/Makefile.help to top Makefile
sh: decompressor: add shipped files to .gitignore
frv: .gitignore: ignore vmlinux.lds
selinux: remove unnecessary assignment to subdir-
kbuild: specify FORCE in Makefile.headersinst as .PHONY target
kbuild: remove redundant mkdir from ./Kbuild
kbuild: optimize object directory creation for incremental build
kbuild: create object directories simpler and faster
kbuild: filter-out PHONY targets from "targets"
kbuild: remove redundant $(wildcard ...) for cmd_files calculation
kbuild: create directory for make cache only when necessary
sh: select KBUILD_DEFCONFIG depending on ARCH
kbuild: fix linker feature test macros when cross compiling with Clang
kbuild: shrink .cache.mk when it exceeds 1000 lines
kbuild: do not call cc-option before KBUILD_CFLAGS initialization
kbuild: Cache a few more calls to the compiler
kbuild: Add a cache for generated variables
kbuild: add forward declaration of default target to Makefile.asm-generic
kbuild: remove KBUILD_SUBDIR_ASFLAGS and KBUILD_SUBDIR_CCFLAGS
hexagon/kbuild: replace CFLAGS_MODULE with KBUILD_CFLAGS_MODULE
Pull ARM SoC platform updates from Arnd Bergmann:
"Most of the commits are for defconfig changes, to enable newly added
drivers or features that people have started using. For the changed
lines lines, we have mostly cleanups, the affected platforms are OMAP,
Versatile, EP93xx, Samsung, Broadcom, i.MX, and Actions.
The largest single change is the introduction of the TI "sysc" bus
driver, with the intention of cleaning up more legacy code.
Two new SoC platforms get added this time:
- Allwinner R40 is a modernized version of the A20 chip, now with a
Quad-Core ARM Cortex-A7. According to the manufacturer, it is
intended for "Smart Hardware"
- Broadcom Hurricane 2 (Aka Strataconnect BCM5334X) is a family of
chips meant for managed gigabit ethernet switches, based around a
Cortex-A9 CPU.
Finally, we gain SMP support for two platforms: Renesas R-Car E2 and
Amlogic Meson8/8b, which were previously added but only supported
uniprocessor operation"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (118 commits)
ARM: multi_v7_defconfig: Select RPMSG_VIRTIO as module
ARM: multi_v7_defconfig: enable CONFIG_GPIO_UNIPHIER
arm64: defconfig: enable CONFIG_GPIO_UNIPHIER
ARM: meson: enable MESON_IRQ_GPIO in Kconfig for meson8b
ARM: meson: Add SMP bringup code for Meson8 and Meson8b
ARM: smp_scu: allow the platform code to read the SCU CPU status
ARM: smp_scu: add a helper for powering on a specific CPU
dt-bindings: Amlogic: Add Meson8 and Meson8b SMP related documentation
ARM: OMAP3: Delete an unnecessary variable initialisation in omap3xxx_hwmod_init()
ARM: OMAP3: Use common error handling code in omap3xxx_hwmod_init()
ARM: defconfig: select the right SX150X driver
arm64: defconfig: Enable QCOM_IOMMU
arm64: Add ThunderX drivers to defconfig
arm64: defconfig: Enable Tegra PCI controller
cpufreq: imx6q: Move speed grading check to cpufreq driver
arm64: defconfig: re-enable Qualcomm DB410c USB
ARM: configs: stm32: Add MDMA support in STM32 defconfig
ARM: imx: Enable cpuidle for i.MX6DL starting at 1.1
bus: ti-sysc: Fix unbalanced pm_runtime_enable by adding remove
bus: ti-sysc: mark PM functions as __maybe_unused
ARM depends on the macros '__ARMEL__' & '__ARMEB__' being defined
or not to correctly select or define endian-specific macros,
structures or pieces of code.
These macros are predefined by the compiler but sparse knows
nothing about them and thus may pre-process files differently
from what gcc would.
Fix this by passing '-D__ARMEL__' or '-D__ARMEB__' to sparse,
depending on the endianness of the kernel, like defined by GCC.
Note: In most case it won't change anything since most ARMs use
little-endian (but an allyesconfig would use big-endian!).
To: Russell King <linux@armlinux.org.uk>
As kbuild document & commit 6588169d51 says: KBUILD_{C,LD}FLAGS_MODULE are
used to add arch-specific options for $(CC) and $(LD). From commandline,
{C,LD}FLAGS_MODULE shall be used.
Doesn't have any functional change, but just follow kbuild rules.
Signed-off-by: Cao jin <caoj.fnst@cn.fujitsu.com>
CC: Russell King <linux@armlinux.org.uk>
CC: linux-arm-kernel@lists.infradead.org
This adds the necessary SMP-operations and startup code to use the
additional cores on the Amlogic Meson8/Meson8m2 (both are using the same
sequence) and Meson8b (using a slightly difference sequence) SoCs.
Signed-off-by: Carlo Caione <carlo@endlessm.com>
[add Meson8/Meson8m2 support and allow taking CPU cores offline as well]
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
By default sparse uses the characteristics of the build
machine to infer things like the wordsize.
This is fine when doing native builds but for ARM it's,
I suspect, very rarely the case and if the build are done
on a 64bit machine we get a bunch of warnings like:
'cast truncates bits from constant value (... becomes ...)'
Fix this by adding the -m32 flags for sparse.
Reported-by: Stephen Boyd <sboyd@codeaurora.org>
Add ARCH_ACTIONS and mach-actions/owl.c for "actions,s500".
The KBUILD_IMAGE variable is used by the rpm and deb-pkg targets, which
expect it to point to the image file in the build directory. The
builddeb script has a workaround for architectures which only provide
the basename, but let's provide a clean interface for packaging tools.
Signed-off-by: Michal Marek <mmarek@suse.com>
- an update for clkdev registration error detection to simplify users
- add cpu capacity parsing from DT
- support for larger cachelines found on UniPhier caches
- documentation for udelay constants
- properly tag assembly function declarations
- remove unnecessary indirection of asm/mach-types.h
- switch to syscall table based generation to simplify future additions
of system calls, along with correpsonding commit for pkey syscalls
- remove redundant sa1101 header file
- RONX protect modules when they're in the vmalloc region
ARM: mm: allow set_memory_*() to be used on the vmalloc region
ARM: mm: fix set_memory_*() bounds checks
ARM: 8631/1: clkdev: Detect errors in clk_hw_register_clkdev() for mass registration
ARM: 8629/1: vfp: properly tag assembly function declarations in C code
ARM: 8622/3: add sysfs cpu_capacity attribute
ARM: 8621/3: parse cpu capacity-dmips-mhz from DT
ARM: 8623/1: mm: add ARM_L1_CACHE_SHIFT_7 for UniPhier outer cache
ARM: Update mach-types
ARM: sa1100: remove SA-1101 header file
ARM: 8619/1: udelay: document the various constants
ARM: wire up new pkey syscalls
ARM: convert to generated system call tables
ARM: remove indirection of asm/mach-types.h
Refactor the oxnas Kconfig entries among the OX810SE and OX820 configs,
and add the files to support the OX820 SMP feature.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Convert ARM to use a similar mechanism to x86 to generate the unistd.h
system call numbers and the various kernel system call tables. This
means that rather than having to edit three places (asm/unistd.h for
the total number of system calls, uapi/asm/unistd.h for the system call
numbers, and arch/arm/kernel/calls.S for the call table) we have only
one place to edit, making the process much more simple.
The scripts have knowledge of the table padding requirements, so there's
no need to worry about __NR_syscalls not fitting within the immediate
constant field of ALU instructions anymore.
Arrange for mach-types.h to be directly generated in the relevant
path, so we don't need a one-liner file in arch/arm/include/asm/.
We currently define OBJCOPYFLAGS in the top-level arm Makefile, and thus
these flags will be passed to all uses of objcopy, kernel-wide, for
which they are not explicitly overridden. The flags we set are intended
for converting a few ELF files into raw binaries, and thus the flags
chosen are problematic for some other uses which do not expect a raw
binary result, e.g. the upcoming lkdtm rodata test:
http://www.openwall.com/lists/kernel-hardening/2016/06/08/2
This patch localises the objcopy flags such that they are only used for
the cases we require them for today.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Laura Abbott <labbott@redhat.com>
The machine specific header files are exported for traditional
platforms, but not for the ones that use ARCH_MULTIPLATFORM, as
they could conflict with one another.
In case of ARM_SINGLE_ARMV7M, we end up also exporting them,
but that appears to be a mistake, and we should treat it the
same way as ARCH_MULTIPLATFORM here.
'make W=1' warns about this because it passes -Wmissing-includes
to gcc and the directories are not actually present.
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
Switch CLPS711X to multiplatform.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Commit 3939f3345050 ("ARM: 8418/1: add boot image dependencies to
not generate invalid images") fixed bad image generation for the
parallel building, but as its side effect, Kbuild now descends into
arch/arm/boot/ again and again, duplicating the log messages.
It looks clumsy, so let's display the same message only once.
This commit moves the log rules from arch/arm/boot/Makefile to
arch/arm/Makefile. I did not delete them completely because *Image
are the final targets that users are interested in.
Without this commit, the log of incremental build is like follows:
$ make ARCH=arm UIMAGE_LOADADDR=0x80208000 uImage
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
Kernel: arch/arm/boot/Image is ready
Kernel: arch/arm/boot/zImage is ready
Image arch/arm/boot/uImage is ready
With this commit, it will look like follows:
Kernel: arch/arm/boot/uImage is ready
The Cortex-M Prototyping System (or V2M-MPS2) is designed for
prototyping and evaluation Cortex-M family of processors including the
latest Cortex-M7
It comes with a range of useful peripherals including 8MB single cycle
SRAM, 16MB PSRAM, Ethernet, QSVGA touch screen panel, 4bit RGB VGA
connector, Audio, SPI and GPIO.
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
