path: root/arch/arm/boot/dts/am33xx-clocks.dtsi
2015-04-22Merge tag 'armsoc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late changes from Olof Johansson: "We were expecting to sit on this branch through most of the merge window since the contents was merged into our tree late, but we ended up sitting on all of our contents so it can go in with the rest. The contents here is: - a large branch of cleanups of the CM/PRM blocks on OMAP. - a couple of patches plumbing up CM/PRM on OMAP5 and DRA7. - a branch with DT updates for Freescale i.MX. including some shuffling from .dts to .dtsi (include) files that causes a little churn" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits) ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON ARM: OMAP4+: control: add support for initializing control module via DT ARM: dts: dra7: add minimal l4 bus layout with control module support ARM: dts: omap5: add minimal l4 bus layout with control module support ARM: OMAP4+: control: remove support for legacy pad read/write ARM: OMAP4: display: convert display to use syscon for dsi muxing ARM: dts: omap4: add minimal l4 bus layout with control module support ARM: dts: am4372: add minimal l4 bus layout with control module support ARM: dts: am43xx-epos-evm: fix pinmux node layout ARM: dts: am33xx: add minimal l4 bus layout with control module support ARM: dts: omap3: add minimal l4 bus layout with control module support ARM: dts: omap24xx: add minimal l4 bus layout with control module support ARM: OMAP2+: control: add syscon support for register accesses ARM: OMAP2+: id: cache omap_type value ARM: OMAP2+: control: remove API for getting control module base address ARM: OMAP2+: clock: add low-level support for regmap ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags ARM: OMAP2+: CM: move SoC specific init calls within a generic API ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility ...
2015-03-31ARM: dts: am33xx: add minimal l4 bus layout with control module supportTero Kristo
This patch creates an l4_wkup interconnect for AM33xx, and moves some of the generic peripherals under it. System control module nodes are moved under this new interconnect also, and the SCM clock layout is changed to use the renamed SCM node as the clock provider. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2015-03-06ARM: dts: am33xx-clocks: Fix ehrpwm tbclk data on am33xxVignesh R
ehrpwm tbclk is wrongly modelled as deriving from dpll_per_m2_ck. The TRM says tbclk is derived from SYSCLKOUT. SYSCLKOUT nothing but the functional clock of pwmss (l4ls_gclk). Fix this by changing source of ehrpwmx_tbclk to l4ls_gclk. Fixes: 9e100ebafb91: ("Fix ehrpwm tbclk data") Signed-off-by: Vignesh R <vigneshr@ti.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-23ARM: dts: am33xx-clock: Fix ehrpwm tbclk dataPoddar, Sourav
tbclk does not need to be a composite clock, we can simply use gate clock for this purpose. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-01-17ARM: dts: am33xx clock dataTero Kristo
This patch creates a unique node for each clock in the AM33xx power, reset and clock manager (PRCM). Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
