path: root/arch/arm/boot/dts/am4372.dtsi
2015-04-22Merge tag 'armsoc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late changes from Olof Johansson: "We were expecting to sit on this branch through most of the merge window since the contents was merged into our tree late, but we ended up sitting on all of our contents so it can go in with the rest. The contents here is: - a large branch of cleanups of the CM/PRM blocks on OMAP. - a couple of patches plumbing up CM/PRM on OMAP5 and DRA7. - a branch with DT updates for Freescale i.MX. including some shuffling from .dts to .dtsi (include) files that causes a little churn" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits) ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON ARM: OMAP4+: control: add support for initializing control module via DT ARM: dts: dra7: add minimal l4 bus layout with control module support ARM: dts: omap5: add minimal l4 bus layout with control module support ARM: OMAP4+: control: remove support for legacy pad read/write ARM: OMAP4: display: convert display to use syscon for dsi muxing ARM: dts: omap4: add minimal l4 bus layout with control module support ARM: dts: am4372: add minimal l4 bus layout with control module support ARM: dts: am43xx-epos-evm: fix pinmux node layout ARM: dts: am33xx: add minimal l4 bus layout with control module support ARM: dts: omap3: add minimal l4 bus layout with control module support ARM: dts: omap24xx: add minimal l4 bus layout with control module support ARM: OMAP2+: control: add syscon support for register accesses ARM: OMAP2+: id: cache omap_type value ARM: OMAP2+: control: remove API for getting control module base address ARM: OMAP2+: clock: add low-level support for regmap ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags ARM: OMAP2+: CM: move SoC specific init calls within a generic API ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility ...
2015-04-22Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "As always, this tends to be one of our bigger branches. There are lots of updates this release, but not that many jumps out as something that needs more detailed coverage. Some of the highlights are: - DTs for the new Annapurna Labs Alpine platform - more graphics DT pieces falling into place on Exynos, bridges, clocks. - plenty of DT updates for Qualcomm platforms for various IP blocks - some churn on Tegra due to switch-over to tool-generated pinctrl data - misc fixes and updates for Atmel at91 platforms - various DT updates to add IP block support on Broadcom's Cygnus platforms - more updates for Renesas platforms as DT support is added for various IP blocks (IPMMU, display, audio, etc)" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits) ARM: dts: alpine: add internal pci Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135." ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB ARM: dts: qcom: Add idle state device nodes for 8064 ARM: dts: qcom: Add idle states device nodes for 8084 ARM: dts: qcom: Add idle states device nodes for 8974/8074 ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs devicetree: bindings: Document qcom,idle-states devicetree: bindings: Update qcom,saw2 node bindings dt-bindings: Add #defines for MSM8916 clocks and resets arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974 arm: dts: qcom: Add LCC nodes arm: dts: qcom: Add TCSR support for MSM8960 arm: dts: qcom: Add TCSR support for MSM8660 arm: dts: qcom: Add TCSR support for IPQ8064 ...
2015-04-22Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's the usual "low-priority fixes that didn't make it into the last few -rcs, with a twist: We had a fixes pull request that I didn't send in time to get into 4.0, so we'll send some of them to Greg for -stable as well. Contents here is as usual not all that controversial: - a handful of randconfig fixes from Arnd, in particular for older Samsung platforms - Exynos fixes, !SMP building, DTS updates for MMC and lid switch - Kbuild fix to create output subdirectory for DTB files - misc minor fixes for OMAP" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: at91/dt: sama5d3 xplained: add phy address for macb1 kbuild: Create directory for target DTB ARM: mvebu: Disable CPU Idle on Armada 38x ARM: DRA7: Enable Cortex A15 errata 798181 ARM: dts: am57xx-beagle-x15: Add thermal map to include fan and tmp102 ARM: dts: DRA7: Add bandgap and related thermal nodes bus: ocp2scp: SYNC2 value should be changed to 0x6 ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCP ARM: OMAP2+: remove superfluous NULL pointer check ARM: EXYNOS: Fix build breakage cpuidle on !SMP ARM: dts: fix lid and power pin-functions for exynos5250-spring ARM: dts: fix mmc node updates for exynos5250-spring ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688 MAINTAINERS: add OMAP defconfigs under OMAP SUPPORT ARM: OMAP1: PM: fix some build warnings on 1510-only Kconfigs ARM: cns3xxx: don't export static symbol ARM: S3C24XX: avoid a Kconfig warning ARM: S3C24XX: fix header file inclusions ARM: S3C24XX: fix building without PM_SLEEP ARM: S3C24XX: use SAMSUNG_WAKEMASK for s3c2416 ...
2015-04-15Merge branch 'omap/dt' into next/lateArnd Bergmann
As pointed out by Stephen Rothwell, commit e52117638b79 ("ARM: dts: omap3: Add DT entries for OMAP 3 ISP") conflicts with b8845074cfbb ("ARM: dts: omap3: add minimal l4 bus layout with control module support") in non-obvious ways, causing a build failure when both patches are present. This merges the two branches that introduce the respective changes into the next/late branch to resolve the way that Stephen suggested, as confirmed by Tony. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: https://lkml.org/lkml/2015/4/6/436 Acked-by: Tony Lindgren <tony@atomide.com>
2015-04-01Merge branch '4.0-rc1-prcm-cleanup-v6' of ↵Tony Lindgren
https://github.com/t-kristo/linux-pm into omap-for-v4.1/prcm-cleanup Conflicts: arch/arm/boot/dts/dra7.dtsi
2015-03-31ARM: dts: am4372: add minimal l4 bus layout with control module supportTero Kristo
This patch creates an l4_wkup interconnect for AM43xx, and moves some of the generic peripherals under it. System control module nodes are moved under this new interconnect also, and the SCM clock layout is changed to use the renamed SCM nodea as the clock provider. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2015-03-26ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCPKishon Vijay Abraham I
Added a new compatible string "ti,am437x-ocp2scp" for OCP2SCP module. This is needed since except for the OCP2SCP used in AM437x, SYNC2 value in OCP2SCP TIMING should be changed whereas the default value is sufficient in AM437x. Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-16ARM: dts: AM4372: update hdq compatible propertyVignesh R
This patch updates hdq node compatible property to "ti,am4372-hdq". Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-15ARM: omap: convert wakeupgen to stacked domainsMarc Zyngier
OMAP4/5 has been (ab)using the gic_arch_extn to provide wakeup from suspend, and it makes a lot of sense to convert this code to use stacked domains instead. This patch does just this, updating the DT files to actually reflect what the HW provides. BIG FAT WARNING: because the DTs were so far lying by not exposing the WUGEN HW block, kernels with this patch applied won't have any suspend-resume facility when booted with old DTs, and old kernels with updated DTs won't even boot. On a platform with this patch applied, the system looks like this: root@bacon-fat:~# cat /proc/interrupts CPU0 CPU1 16: 0 0 WUGEN 37 gp_timer 19: 233799 155916 GIC 27 arch_timer 23: 0 0 WUGEN 9 l3-dbg-irq 24: 1 0 WUGEN 10 l3-app-irq 27: 282 0 WUGEN 13 omap-dma-engine 44: 0 0 4ae10000.gpio 13 DMA 294: 0 0 WUGEN 20 gpmc 297: 506 0 WUGEN 56 48070000.i2c 298: 0 0 WUGEN 57 48072000.i2c 299: 0 0 WUGEN 61 48060000.i2c 300: 0 0 WUGEN 62 4807a000.i2c 301: 8 0 WUGEN 60 4807c000.i2c 308: 2439 0 WUGEN 74 OMAP UART2 312: 362 0 WUGEN 83 mmc2 313: 502 0 WUGEN 86 mmc0 314: 13 0 WUGEN 94 mmc1 350: 0 0 PRCM pinctrl, pinctrl 406: 35155709 0 GIC 109 ehci_hcd:usb1 407: 0 0 WUGEN 7 palmas 409: 0 0 WUGEN 119 twl6040 410: 0 0 twl6040 5 twl6040_irq_ready 411: 0 0 twl6040 0 twl6040_irq_th IPI0: 0 1 CPU wakeup interrupts IPI1: 0 0 Timer broadcast interrupts IPI2: 95334 902334 Rescheduling interrupts IPI3: 0 0 Function call interrupts IPI4: 479 648 Single function call interrupts IPI5: 0 0 CPU stop interrupts IPI6: 0 0 IRQ work interrupts IPI7: 0 0 completion interrupts Err: 0 Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-01-07ARM: dts: am4372: add VPFE DT node entriesBenoit Parrot
Add Video Processing Front End (VPFE) device tree nodes for AM34xx family of devices. Signed-off-by: Benoit Parrot <bparrot@ti.com> Signed-off-by: Darren Etheridge <detheridge@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-12-14Merge tag 'usb-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big set of USB and PHY patches for 3.19-rc1. The normal churn in the USB gadget area is in here, as well as xhci and other individual USB driver updates. The PHY tree is also in here, as there were dependancies on the USB tree. All of these have been in linux-next" * tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits) arm: omap3: twl: remove usb phy init data usbip: fix error handling in stub_probe() usb: gadget: udc: missing curly braces USB: mos7720: delete some unneeded code wusb: replace memset by memzero_explicit usbip: remove unneeded structure usb: xhci: fix comment for PORT_DEV_REMOVE xhci: don't use the same variable for stopped and halted rings current TD xhci: clear extra bits from slot context when setting max exit latency xhci: cleanup finish_td function USB: adutux: NULL dereferences on disconnect usb: chipidea: fix platform_no_drv_owner.cocci warnings usb: chipidea: Fixed a few typos in comments Documentation: bindings: add doc for the USB2 ChipIdea USB driver usb: chipidea: add a usb2 driver for ci13xxx usb: chipidea: fix phy handling usb: chipidea: remove duplicate dev_set_drvdata for host_start usb: chipidea: parameter 'mode' isn't needed for hw_device_reset usb: chipidea: add controller reset API usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER ...
2014-11-24ARM: dts: am4372: Add DCAN nodesRoger Quadros
The SoC contains 2 DCAN modules. Add them. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-24ARM: dts: am4372: Add control module syscon nodeRoger Quadros
Use syscon regmap to expose the Control module register space. This register space is shared between many users e.g. DCAN, USB, display, etc. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-21ARM: dts: AM43xx: add tscadc DT entries for am437x-evm and am43x-epos-evmVignesh R
This patch adds tscadc DT entries for am437x-gp-evm and am43x-epos-evm. Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-10arm: boot: dts: am4372: enable dwc3 suspend PHY quirkFelipe Balbi
Whenever Suspend PHY bit is set on AM437x devices, USB will not work due to Set EP Configuration command always failing. This was only found after a recent commit 2164a47 (usb: dwc3: set SUSPHY bit for all cores, which will be merged for v3.19) added a missing *required* step to dwc3 initialization. Synopsys Databook requires that we enable Suspend PHY bit after initialization but that, unfortunately, breaks AM437x. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-11-10ARM: dts: OMAP2+: Add #mbox-cells property to all mailbox nodesSuman Anna
The '#mbox-cells' property is added to all the OMAP mailbox nodes. This property is mandatory with the new mailbox framework. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-08Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "As usual, this is the largest branch, though this time a little under half of the total changes with 307 individual non-merge changesets. The largest changes are the addition of new machines, in particular the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support for the old i.MX1 platform. Other changes include - at91: various sam9 and sama5 updates - exynos: much extended Peach Pi/Pit (Chromebook 2) support - keystone: new peripherals - meson: added DT for meson6 SoC - mvebu: new device support for Armada 370/375 - qcom: improved support for IPQ8064 and MSM8x60 - rockchip: much improved support for rk3288 - shmobile: lots of updates all over the place - sunxi: dts license change - sunxi: more a23 device support - vexpress: CLCD DT description" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits) ARM: DTS: meson: update DTSI to add watchdog node ARM: dts: keystone-k2l: fix mdio io start address ARM: dts: keystone-k2e: fix mdio io start address ARM: dts: keystone-k2e: update usb1 node for dma properties ARM: dts: keystone: fix io range for usb_phy0 Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt" Revert "ARM: dts: hix5hd2: add wdg node" ARM: dts: add rk3288 i2s controller ARM: vexpress: Add CLCD Device Tree properties ARM: bcm2835: add I2S pinctrl to device tree ARM: meson: documentation: add bindings documentation ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS ARM: dts: mt6589: Change compatible string for GIC ARM: dts: mediatek: Add compatible property for aquaris5 ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk ARM: dts: mt6589: Fix typo in GIC unit address ARM: dts: Build dtb for Mediatek board ARM: dts: keystone: fix bindings for pcie and usb clock nodes ARM: dts: keystone: k2l: Fix chip selects for SPI devices ARM: dts: keystone: add dsp gpio controllers nodes ...
2014-10-08Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support. Among the things new for this release are: - at91: Added support for the new SAMA5D4 SoC, following the earlier SAMA5D3 - bcm: Added support for BCM63XX family of DSL SoCs - hisi: Added support for HiP04 server-class SoC - meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform - shmobile: added support for new r8a7794 (R-Car E2) automotive SoC Noteworthy changes to existing SoC support are: - imx: convert i.MX1 to device tree - omap: lots of power management work - omap: base support to enable moving to standard UART driver - shmobile: lots of progress for multiplatform support, still ongoing" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits) ARM: hisi: depend on ARCH_MULTI_V7 CNS3xxx: Fix debug UART. ARM: at91: fix nommu build regression ARM: meson: add basic support for MesonX SoCs ARM: meson: debug: add debug UART for earlyprintk support irq: Export handle_fasteoi_irq ARM: mediatek: Add earlyprintk support for mt6589 ARM: hisi: Fix platmcpm compilation when ARMv6 is selected ARM: debug: fix alphanumerical order on debug uarts ARM: at91: document Atmel SMART compatibles ARM: at91: add sama5d4 support to sama5_defconfig ARM: at91: dt: add device tree file for SAMA5D4ek board ARM: at91: dt: add device tree file for SAMA5D4 SoC ARM: at91: SAMA5D4 SoC detection code and low level routines ARM: at91: introduce basic SAMA5D4 support clk: at91: add a driver for the h32mx clock ARM: pxa3xx: provide specific platform_devices for all ssp ports ARM: pxa: ssp: provide platform_device_id for PXA3xx ARM: OMAP4+: Remove static iotable mappings for SRAM ARM: OMAP4+: Move SRAM data to DT ...
2014-09-18ARM: OMAP4+: Move SRAM data to DTRajendra Nayak
Use drivers/misc/sram.c driver to manage SRAM on all DT only OMAP platforms (am33xx, am43xx, omap4 and omap5) instead of the existing private plat-omap/sram.c Address and size related data is removed from mach-omap2/sram.c and now passed to drivers/misc/sram.c from DT. Users can hence use general purpose allocator apis instead of OMAP private ones to manage and use SRAM. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-11ARM: dts: OMAP2+: Add sub mailboxes device node informationSuman Anna
The sub-mailbox devices are added to the Mailbox DT nodes on OMAP2420, OMAP2430, OMAP3, AM33xx, AM43xx, OMAP4 and OMAP5 family of SoCs. This data represents the same mailboxes that used to be represented in hwmod attribute data previously. The node name is chosen based on the .name field of omap_mbox_dev_info structure used in the hwmod data. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-09ARM: dts: AM437x: switch to compatible pinctrlNishanth Menon
Now that ti,am437-padconf is available, switch over to that compatible property. Retain pinctrl-single for legacy support. While at it, mark the pinctrl as interrupt controller so that it can be used with interrupts-extended property for wakeup events. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-09-03ARM: dts: am4372: fix USB regs sizeFelipe Balbi
Size should be 64KiB instead of 92KiB. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-08Merge tag 'dt-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device-tree changes from Olof Johansson: "Unlike the board branch, this keeps having large sets of changes for every release, but that's quite expected and is so far working well. Most of this is plumbing for various device bindings and new platforms, but there's also a bit of cleanup and code removal for things that are moved from platform code to DT contents (some OMAP clock code in particular). There's also a pinctrl driver for tegra here (appropriately acked), that's introduced this way to make it more bisectable. I'm happy to say that there were no conflicts at all with this branch this release, which means that changes are flowing through our tree as expected instead of merged through driver maintainers (or at least not done with conflicts). There are several new boards added, and a couple of SoCs. In no particular order: - Rockchip RK3288 SoC support, including DTS for a dev board that they have seeded with some community developers. - Better support for Hardkernel Exynos4-based ODROID boards. - CCF conversions (and dtsi contents) for several Renesas platforms. - Gumstix Pepper (TI AM335x) board support - TI eval board support for AM437x - Allwinner A23 SoC, very similar to existing ones which mostly has resulted in DT changes for support. Also includes support for an Ippo tablet with the chipset. - Allwinner A31 Hummingbird board support, not to be confused with the SolidRun i.MX-based Hummingboard. - Tegra30 Apalis board support" * tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits) ARM: dts: Enable USB host0 (EHCI) on rk3288-evb ARM: dts: add rk3288 ehci usb devices ARM: dts: Turn on USB host vbus on rk3288-evb ARM: tegra: apalis t30: fix device tree compatible node ARM: tegra: paz00: Fix some indentation inconsistencies ARM: zynq: DT: Clarify Xilinx Zynq platform ARM: dts: rockchip: add watchdog node ARM: dts: rockchip: remove pinctrl setting from radxarock uart2 ARM: dts: Add missing pinctrl for uart0/1 for exynos3250 ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250 ARM: dts: Add TMU dt node to monitor the temperature for exynos3250 ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250 ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only ARM: dts: max77686 is exynos5250-snow only ARM: zynq: DT: Remove DMA from board DTs ARM: zynq: DT: Add CAN node ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table ARM: dts: Add PMU DT node for exynos5260 SoC ARM: EXYNOS: Add support for Exynos5410 PMU ARM: dts: Add PMU to exynos5410 ...
2014-07-15ARM: dts: AM4372: Correct mailbox node dataSuman Anna
The mailbox DT node for AM4372 is enabled and is corrected to remove some properties that have crept in by mistake. Fixes: 9e3269b (ARM: dts: AM4372: Add L2, EDMA, mailbox, MMC and SHAM nodes) Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-01ARM: dts: am4372: let boards access all nodes through labelsFelipe Balbi
By providing labels for rtc, wdt, cpu and dispc nodes, boards can access them to add board-specific data. Signed-off-by: Felipe Balbi <balbi@ti.com> Tested-by: Franklin Cooper Jr. <fcooper@ti.com> Tested-by: Tom Rini <trini@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-09Merge tag 'fbdev-omap-dt-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull OMAP DT fbdev updates from Tomi Valkeinen: "Here are display related device tree data changes for OMAP. They are based on an already merged branch to satisfy the dependencies for the dts file changes. Add OMAP DT data: - omap5 display subsystem - display data for omap5 uEVM board - am43xx display subsystem - display data for am43xx ePOS and GP boards (LCD only) - display data for GTA04 board - display data for overo board - display data for duovero-parlor board - display data for omap3 evm and ldp boards" * tag 'fbdev-omap-dt-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: ARM: omap5.dtsi: Add audio related parameters to hdmi node ARM: omap4.dtsi: Add audio related parametes to hdmi node ARM: dts: duovero-parlor: Add HDMI output ARM: dts: overo: Add support for 3.5'' LCD output ARM: dts: overo: Add support for 4.3'' LCD output ARM: dts: overo: Add support for DVI output ARM: dts: Add LCD panel sharp ls037v7dw01 support for omap3-evm and ldp ARM: dts: omap3-gta04: Add display support ARM: dts: omap5-uevm.dts: add display nodes ARM: dts: omap5-uevm.dts: add tca6424a ARM: dts: omap5.dtsi: add DSS nodes ARM: dts: am43x-epos-evm: add LCD data ARM: dts: am437x-gp-evm: add LCD data ARM: dts: am4372.dtsi: add DSS information
2014-06-03ARM: dts: am4372.dtsi: add DSS informationSathya Prakash M R
Add DT data for the display subsystem for AM4372. The DSS on AM4372 is basically OMAP3's DSS, without DSI and VENC blocks. Signed-off-by: Sathya Prakash M R <sathyap@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-06-02Merge tag 'drivers-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC driver changes from Olof Johansson: "SoC-near driver changes that we're merging through our tree. Mostly because they depend on other changes we have staged, but in some cases because the driver maintainers preferred that we did it this way. This contains a largeish cleanup series of the omap_l3_noc bus driver, cpuidle rework for Exynos, some reset driver conversions and a long branch of TI EDMA fixes and cleanups, with more to come next release. The TI EDMA cleanups is a shared branch with the dmaengine tree, with a handful of Davinci-specific fixes on top. After discussion at last year's KS (and some more on the mailing lists), we are here adding a drivers/soc directory. The purpose of this is to keep per-vendor shared code that's needed by different drivers but that doesn't fit into the MFD (nor drivers/platform) model. We expect to keep merging contents for this hierarchy through arm-soc so we can keep an eye on what the vendors keep adding here and not making it a free-for-all to shove in crazy stuff" * tag 'drivers-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits) cpufreq: exynos: Fix driver compilation with ARCH_MULTIPLATFORM tty: serial: msm: Remove direct access to GSBI power: reset: keystone-reset: introduce keystone reset driver Documentation: dt: add bindings for keystone pll control controller Documentation: dt: add bindings for keystone reset driver soc: qcom: fix of_device_id table ARM: EXYNOS: Fix kernel panic when unplugging CPU1 on exynos ARM: EXYNOS: Move the driver to drivers/cpuidle directory ARM: EXYNOS: Cleanup all unneeded headers from cpuidle.c ARM: EXYNOS: Pass the AFTR callback to the platform_data ARM: EXYNOS: Move S5P_CHECK_SLEEP into pm.c ARM: EXYNOS: Move the power sequence call in the cpu_pm notifier ARM: EXYNOS: Move the AFTR state function into pm.c ARM: EXYNOS: Encapsulate the AFTR code into a function ARM: EXYNOS: Disable cpuidle for exynos5440 ARM: EXYNOS: Encapsulate boot vector code into a function for cpuidle ARM: EXYNOS: Pass wakeup mask parameter to function for cpuidle ARM: EXYNOS: Remove ifdef for scu_enable in pm ARM: EXYNOS: Move scu_enable in the cpu_pm notifier ARM: EXYNOS: Use the cpu_pm notifier for pm ...
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-05-26Merge tag 'davinci-for-v3.16/edma' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/drivers Merge "DaVinci EDMA clean-up for v3.16" from Sekhar Nori: This series makes edma use configuration information available within the IP instead of reading it from platform data or DT. Some other useful clean-ups are included too. * tag 'davinci-for-v3.16/edma' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci: (34 commits) ARM: edma: Remove redundant/unused parameters from edma_soc_info ARM: davinci: Remove redundant/unused parameters for edma ARM: dts: am4372: Remove obsolete properties from edma node ARM: dts: am33xx: Remove obsolete properties from edma node dt/bindings: ti,edma: Remove redundant properties from documentation ARM: edma: Get IP configuration from HW (number of channels, tc, etc) ARM: edma: Save number of regions from pdata to struct edma ARM: edma: Remove num_cc member from struct edma ARM: edma: Remove queue_tc_mapping data from edma_soc_info ARM: davinci: Remove eDMA3 queue_tc_mapping data from edma_soc_info ARM: edma: Do not change TC -> Queue mapping, leave it to default. ARM: edma: Take the number of tc from edma_soc_info (pdata) ARM: edma: No need to clean the pdata in edma_of_parse_dt() ARM: edma: Clean up and simplify the code around irq request dmaengine: edma: update DMA memcpy to use new param element dmaengine: edma: Document variables used for residue accounting dmaengine: edma: Provide granular accounting dmaengine: edma: Make reading the position of active channels work dmaengine: edma: Store transfer data in edma_desc and edma_pset dmaengine: edma: Create private pset struct ... Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-26Merge tag 'omap-for-v3.16/fixes-not-urgent-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/fixes-non-critical Merge "ARM: omap non urgent fixes for v3.16 merge window, resend" from Tony Lindgren: Non urgent omap fixes for v3.16 merge window. * tag 'omap-for-v3.16/fixes-not-urgent-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: am43xx: fix starting offset of NAND.filesystem MTD partition ARM: dts: am335x-boneblack: remove use of ti,vcc-aux-disable-is-sleep ARM: OMAP2+: free use_gptimer_clksrc variable after boot ARM: OMAP5: Redo THUMB mode switch on secondary CPU ARM: dts: AM4372: add l3-noc information ARM: dts: DRA7: Use dra7-l3-noc instead of omap4-l3-noc Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-22ARM: dts: am4372: Remove obsolete properties from edma nodePeter Ujfalusi
dma-channels, ti,edma-regions and ti,edma-slots no longer needed in DT since the the same information is available in the IP's CCCFG register. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2014-05-19ARM: dts: am4372: Add cpsw phy sel dt nodeMugunthan V N
Add cpsw phy sel device tree node for selecting phy mode in control module Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-14ARM: dts: am4372: Add hdq device tree dataSourav Poddar
Add device tree nodes and pinmux for hdq/1wire on am43x epos evm. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/altera/altera_sgdma.c net/netlink/af_netlink.c net/sched/cls_api.c net/sched/sch_api.c The netlink conflict dealt with moving to netlink_capable() and netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations in non-init namespaces. These were simple transformations from netlink_capable to netlink_ns_capable. The Altera driver conflict was simply code removal overlapping some void pointer cast cleanups in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-08Merge branch 'pull/l3noc/dts-fixes' of ↵Tony Lindgren
https://github.com/nmenon/linux-2.6-playground into omap-for-v3.16/fixes-not-urgent
2014-05-06ARM: dts: am43x-epos: Add qspi deviceSourav Poddar
This patch adds qspi nodes for am43xx SOC devices. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-06ARM: dts: AM4372: Add USB nodesGeorge Cherian
Add nodes for 2 instances each of - ocp2scp - USB PHY control module - USB PHY - dwc3_omap - USB for AM43xx. Signed-off-by: George Cherian <george.cherian@ti.com> Acked-by: Roger Quadros <rogerq@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-05ARM: dts: AM4372: add l3-noc informationAfzal Mohammed
AM4372 has two clk domains 100f and 200s. Provide register mapping, interrupt information and compatibility flags associated with it. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Afzal Mohammed <afzal@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2014-05-05ARM: dts: am4372: Add clock names for cpsw and cptsGeorge Cherian
Add CPSW fck and CPTS clock and clock names for AM4372 Signed-off-by: George Cherian <george.cherian@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-23dt: Fix binding typos in clock-names and interrupt-namesGeert Uytterhoeven
s/interrupts-names/interrupt-names/g s/clocks-names/clock-names/g Some of the binding files and device tree files get this wrong and the kernel won't be able to pick it up. Fix them up now so that they don't get widely used. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by : Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-03-05ARM: dts: am43x-epos-evm: add SD card hotplug supportBalaji T K
Add card detect gpio for SD card slot and include dt gpio header. Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-02Merge tag 'for_3.15/dts_signed' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/bcousson/linux-omap-dt into omap-for-v3.15/dt Add craneboard devices Add more N900 devices Add am43x-epos-evm and am437x-gp-evm devices Add OMAP4 DMM devices Conflicts: arch/arm/boot/dts/am43x-epos-evm.dts arch/arm/boot/dts/dra7.dtsi
2014-03-02ARM: dts: am43xx: add support for parallel NAND flashPekon Gupta
This patch: - enables GPMC h/w and ELM h/w engine for AM43xx devices (am4372.dtsi) - adds pinmux and DT node for Micron 4K-paged x8 NAND device (MT29F4G08AB) present on following boards: am43x-epos-evm: On this board, NAND Flash control lines are muxed with QSPI, Thus only one of the two can be used at a time. Selection is controlled by: (a) dynamically driving following GPIO pin from software GPMC_A0(GPIO) == 0 NAND is selected (default) GPMC_A0(GPIO) == 1 eMMC is selected Signed-off-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-02ARM: dts: am4372: Add pwm-cells property for ecap device.Sourav Poddar
Add "pwm-cells" node for all ecap, ehrpwm in am43x dtsi files. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
2014-02-28ARM: dts: OMAP3+: add clock nodes for CPUNishanth Menon
OMAP34xx, AM3517 and OMAP36xx platforms use dpll1 clock. OMAP443x, OMAP446x, OMAP447x, OMAP5, DRA7, AM43xx platforms use dpll_mpu clock. Latency used is the generic latency defined in omap-cpufreq driver. Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-02-28ARM: dts: AM4372: Add hwspinlock nodeSuman Anna
Add the hwspinlock device tree node for AM43xx family of SoCs. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-01-17ARM: dts: am43xx clock dataTero Kristo
This patch creates a unique node for each clock in the AM43xx power, reset and clock manager (PRCM). Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2013-10-22ARM: dts: AM33xx+: Add i2c aliasesNishanth Menon
Provide alias to allow ordering the i2c devices correctly. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
