The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The compatible set in the armada-38x DTSI is always overridden, and the reg
defined in there is duplicated in the armada-380 and armada-385 DTSIs.
Remove these useless items.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Some nodes in the DTs have a reg property but no unit name in their node name.
This contradicts the way the ePAPR defines the node names. Fix this.
wildcard
Wildcards in compatible strings should be avoid. "marvell,armada38x"
was recently introduced but was not yet used.
The armada 385 SoC is a superset of the armada 380 SoC (with more CPUs
and more PCIe slots). So this patch replaces the use of
"marvell,armada38x" by the "marvell,armada380" string.
Link: https://lkml.kernel.org/r/1403533011-21339-1-git-send-email-gregory.clement@free-electrons.com
Acked-by: Andrew Lunn <andrew@lunn.ch>
Cc: <stable@vger.kernel.org> # v3.15+
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
Due a copy/paste error, the 'reg' values for the third PCIe interface
on Armada 380, and the third and fourth PCIe interfaces on Armada 385
are wrong: they are equal to the one of the second PCIe interface.
This patch fixes this by using the appropriate 'reg' values for those
PCIe interfaces.
Without this fix, the third and fourth PCIe interfaces are unusable on
those platforms.
Reported-by: Nadav Haklai <nadavh@marvell.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1400597008-4148-1-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: 0d3d96ab0059 ("ARM: mvebu: add Device Tree description of the Armada 380/385 SoCs")
This commit improves the Armada 38x Device Tree to add the CPU reset
and PMSU Device Tree nodes as well as the declaration of the enabling
method for the CPUs. These are needed to get SMP working on Armada 38x
platforms.
Link: https://lkml.kernel.org/r/1397483648-26611-12-git-send-email-thomas.petazzoni@free-electrons.com
Instead of hardcoding the values of the interrupt flags, use the
macros provided by <include/dt-bindings/interrupt-controller/irq.h>
and <include/dt-bindings/interrupt-controller/arm-gic.h> for the
Armada 375 and Armada 38x Device Tree files.
Instead of hardcoding 0 and 1 to indicate SPI and PPI GIC interrupts,
use the definitions of <dt-bindings/interrupt-controller/arm-gic.h> to
clarify the Device Tree code.
The Armada 380 and 385 SoCs are new SoCs from Marvell, based on a
Cortex-A9 cores (single core for 380, dual core for 385) and a number
of hardware blocks that are common with earlier SoCs from the mvebu
family.
The provided Device Tree describes the following parts of the SoC:
* CPU
* Device Bus
* Clocks
* Interrupt controllers: GIC and MPIC
* GPIO controllers
* I2C buses
* L2 cache
* MBus controller
* Pinctrl
* Serial
* SPI buses
* System controller (for reboot)
* Timer
* XOR engines
* PCIe controllers
* Network interfaces
