commit 8d4514173211586c6238629b1ef1e071927735f5 upstream.
As written in the datasheet the PCA955 can only handle low level irq and
not edge irq.
Without this fix the interrupt is not usable for pca955: the gpio-pca953x
driver already set the irq type as low level which is incompatible with
edge type, then the kernel prevents using the interrupt:
"irq: type mismatch, failed to map hwirq-18 for
/soc/internal-regs/gpio@18100!"
Fixes: 928413bd859c ("ARM: mvebu: Add Armada 388 General Purpose
Development Board support")
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 079ae0c121fd23287f4ad2be9e9f8a13f63cae73 upstream.
The Armada 388 GP Device Tree file describes two times a regulator
named 'reg_usb2_1_vbus', with the exact same description. This has
been wrong since Armada 388 GP support was introduced.
Fixes: 928413bd859c0 ("ARM: mvebu: Add Armada 388 General Purpose Development Board support")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The newest revisions of A388-GP (v1.5 and higher) support only
DAT3-based card detection. Revisions < v1.5 based on GPIO detection
via I2C expander, but this solution is supposed to be deprecated on
new boards. In order to satisfy all type of hardware this commit
changes card detection to use software polling mechanism. Also a
comment is added on possible card detection options in A388-GP
DT board file.
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Contrary to what the Device Tree indicates, the EEPROM at 0x54 is not
populated, so we get rid of this comment.
However, there is an EEPROM at 0x57, so we add support for this
AT24C64 EEPROM:
$ hexdump -C /sys/bus/i2c/devices/0-0057/eeprom
00000000 0c ff f3 ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
00000010 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
00002000
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This regulator was lacking the reference to the GPIO that controls it,
and the regulator-min-microvolt and regulator-max-microvolt
properties. Thanks to this commit, the pwr-sata0 regulator now looks
more like the other pwr-sata{1,2,3} regulators in the same Device
Tree, with of course the exception of a different GPIO reference.
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
On Marvell Armada 38x, the USB2 controller registers are at 0x58000,
so the corresponding Device Tree node should have a unit address of
58000, and not 50000. We were using 50000 due to an incorrect
copy/pastebin of Armada 370/XP code.
Add the regulators to each SATA port.
The A388-GP is a board produced by Marvell that holds
- 1 PCIe slot
- 2 mini PCIe slot (one of them is multiplexed with the PCIe slot,
muxing is selected through the GPIO expander)
- 1 16MB SPI-NOR
- 2 Gigabit Ethernet ports
- 4 SATA ports (2 of them are multiplexed with the mini PCIe slots,
- 1 SDIO slot
- 1 USB3 port
- 2 USB2 port
- 2 GPIO/interrupts expander on I2C
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
