path: root/arch/arm/boot/dts/armada-398.dtsi
2015-03-04ARM: mvebu: add Device Tree files for Armada 39x SoC and boardThomas Petazzoni
This commit adds the Device Tree files for the Armada 39x family of processors, as well as one Armada 398 Development Board. Like for other Marvell EBU families, a common armada-39x.dtsi contains the description of the common features of all Armada 39x SoCs, while armada-390.dtsi and armada-398.dtsi respectively describe the specificities of those SoCs. Finally, an armada-398-db.dts file is added to describe the Armada 398 Development Board itself. So far, the following features are supported: * SMP: dual Cortex-A9 * Basic ARM IPs: SCU, timer, GIC, L2 cache * Basic Marvell IPs: pin-muxing, clocks, system controller, MBus controller, MPIC interrupt controller, timer, CPU reset for SMP, PMSU. * I2C * SPI * SDHCI * XOR * NAND * UART * PCIe Additional features will be supported in the future. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
