This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
This commit improves the Armada XP GP Device Tree description to
describe the 3 GPIOs that are used to connect the SoC to the PIC
micro-controller that we talk to shutdown the SoC when entering
suspend to RAM.
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1416585613-2113-15-git-send-email-thomas.petazzoni@free-electrons.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have
the proper "clocks" property in their UART controllers node, it is no
longer useful to have the clock-frequency property defined in the
board-level Device Tree files.
Therefore, this commit gets rid of all the useless 'clock-frequency'
properties.
Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com
The Armada XP GP isn't using rgmii-id connections between the MAC and
PHY, but instead a single QSGMII connection, which is a quad-SGMII
connection: a double pair of differential lines that are multiplexed
to convey the traffic of four network interfaces between a MAC and a
PHY.
Until now, the Armada XP GP was relying on the bootloader setting the
correct values in various configuration registers. With this change,
the mvneta driver can be used as a module on this platform.
Link: https://lkml.kernel.org/r/1397569821-5530-4-git-send-email-thomas.petazzoni@free-electrons.com
Tested-by: Arnaud Ebalard <arno@natisbad.org>
Tested-by: Willy Tarreau <w@1wt.eu>
The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus
width declared in the Device Tree being considered as a 16 bits bus
width when configuring the hardware.
This bug in mvebu-devbus driver was compensated by a symetric mistake
in the Armada XP GP Device Tree: a 8 bits bus width was declared, even
though the hardware actually has a 16 bits bus width connection with
the NOR flash.
Now that we have fixed the mvebu-devbus driver to behave according to
its Device Tree binding, this commit fixes the problematic Device Tree
files as well.
This bug was introduced in commit
da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for
NOR flash device on Armada XP-GP board') which was merged in v3.10.
Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board')
Cc: stable@vger.kernel.org # v3.10+
Marvell has now provided bootloaders that are Device Tree capable for
the Armada XP GP board, and that also remap the internal register base
address to 0xf1000000. In addition, the bootloader now sets the MBus
Window base address to 0xf0000000, which allows to use much more RAM
in the last GB of RAM before the 4 GB limit (the entire space from
0xC0000000 to 0xFFFFFFFF was not usable due to being used for I/O, not
only the space from 0xF0000000 to 0xFFFFFFFF is used for I/O).
Therefore this commit:
* Updates the memory->reg Device Tree property with the fact that in
the first bank of RAM, memory up to 0xf0000000 can be used.
* Updates the soc->ranges Device Tree property with the fact that the
internal registers are now mapped at 0xf1000000.
The Armada XP GP board has a NAND flash, so enable it in the devicetree.
In order to skip the driver's custom device detection and use only ONFI
detection, the "marvell,keep-config" parameter is used.
This is needed because we haven't support for setting the timings
parameters yet and must rely in bootloader's.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of internal registers, placing it directly
below the mbus. This is a more accurate representation of the
hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to correspond
to each MBus window.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
move the DeviceBus out of internal registers, placing it directly
below the mbus. This is a more accurate representation of the hardware.
In order to access the SoC BootROM, we need to declare a mapping
(through a ranges property). The mbus driver will use this property
to allocate a suitable address decoding window.
The Armada 370/XP SoC family has a completely configurable address
space handled by the MBus controller.
This patch introduces the device tree layout of MBus, making the
'soc' node as mbus-compatible.
Since every peripheral/controller is a child of this 'soc' node,
this makes all of them sit behind the mbus, thus describing the
hardware accurately.
A translation entry has been added for the internal-regs mapping.
This can't be done in the common armada-370-xp.dtsi because A370
and AXP have different addressing width.
into next/dt
From Shawn Guo:
mxs device tree changes for 3.11:
* A couple of new board support, cfa10055 and cfa10057
* A few updates on cfa10036 device tree source
* Some auart pinctrl data addition
* Adopt soc bus infrastructure for mach-mxs
* tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: mxs: dt: Add Crystalfontz CFA-10057 device tree
ARM: mxs: dt: Add the Crystalfontz CFA-10055 device tree
ARM: cfa10049: Switch the chip select pin of the LCD controller
ARM: cfa10036: Add USB0 OTG port
ARM: dts: apf28dev: Add touchscreen support for APF28dev
ARM: mxs: Fix UARTs on M28EVK
ARM: cfa10036: dt: Change i2c0 clock frequency
ARM: dts: cfa10036: Change the OLED display to SSD1306
ARM: mx28: add auart4 2 pins pinmux to imx28.dtsi
ARM: mx28: add auart3 2 pins pinmux to imx28.dtsi
ARM: mx28: add auart2 2 pins pinmux to imx28.dtsi
ARM: mxs: Use soc bus infrastructure
ARM: dts: mx28: Adjust the digctl compatible string
ARM: mxs: Remove init_irq declaration in machine description
Includes an update to 3.10-rc6
The ranges DT entry needed by the PCIe controller is defined at the
SoC .dtsi level. However, some boards have a NOR flash, and to support
it, they need to override the SoC-level ranges property to add an
additional range. Since PCIe and NOR support came separately, some
boards were not properly changed to include the PCIe range in their
ranges property at the .dts level.
This commit fixes those platforms.
next/dt
From jason Cooper, mvebu dt changes for v3.11.
* tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux: (27 commits)
arm: kirkwood: openblocks-a6: add support for Init button
arm: kirkwood: openblocks-a6: group pinmux configurations
arm: kirkwood: ts219: move pinmux configs to the right devices
arm: kirkwood: topkick: move pinmux configs to the right devices
arm: kirkwood: openblocks_a6: move pinmux configs to the right devices
arm: kirkwood: nsa310: move pinmux configs to the right devices
arm: kirkwood: readynas: move pinmux configs to the right devices
arm: kirkwood: mplcec4: move pinmux configs to the right devices
arm: kirkwood: buffalo linkstation: move pinmux configs to the right devices
arm: kirkwood: keymile: move pinmux configs to the right devices
arm: kirkwood: ns2: move pinmux configs to the right devices
arm: kirkwood: iomega ix2-200: move pinmux configs to the right devices
arm: kirkwood: iconnect: move pinmux configs to the right devices
arm: kirkwood: iconnect: give meaningful names to pinmux configs
arm: kirkwood: ib62x0: move pinmux configs to the right devices
arm: kirkwood: guruplug: move pinmux configs to the right devices
arm: kirkwood: goflexnet: move pinmux configs to the right devices
arm: kirkwood: dreamplug: move pinmux configs to the right devices
arm: kirkwood: dockstar: move pinmux configs to the right devices
arm: kirkwood: dlink dns: move pinmux configs to the right devices
The Armada XP GP board has two USB slots: one on the front side and
one on the back side. This commit enables the two USB host controllers
that correspond to those wo USB slots.
With the latest device tree reorganization which introduced the
'internal-reg' node, now the only region translated is the internal register's.
This makes the description of the hardware incomplete, for it lacks the
Device Bus childs address space.
In order to fix this, it's required to add a 'ranges' entry with a suitable
address space to map Device Bus childs, on a per-board basis.
This patch fixes the ranges property on the Armada XP GP board.
In order to be able to use more than 4GB of RAM when the LPAE is
activated, the dts must be converted in 64 bits.
Only Armada XP is LPAE capable, but as it shares a common dtsi file
with Armada 370, then the common file include the skeleton64. Thanks
to the use of the overload capability of the device tree format,
armada-370 include the 32 bit skeleton and all the armada 370 based
dts can remain the same.
This was heavily based on the work of Lior Amsalem.
Introduce a 'internal-regs' subnode, under which all devices are
moved. This is not really needed for now, but will be for the
mvebu-mbus driver. This generates a lot of code movement since it's
indenting by one more tab all the devices. So it was a good
opportunity to fix all the bad indentation.
This conversion will allow to keep 32 bits addresses for the internal
registers whereas the memory of the system will be 64 bits.
Later it will also ease the move of the mvebu-mbus driver to the
device tree support.
The Marvell Armada XP GP board has 3 physical full-size PCIe slots, so
we enable the corresponding PCIe interfaces in the Device Tree.
The Armada XP Development Board DB-MV784MP-GP has a NOR flash device
connected to the Device Bus. This commit adds the device tree node
to support this device.
This SoC supports a flexible and dynamic decoding window allocation
scheme; but since this feature is still not implemented we need
to specify the window base address in the device tree node itself.
This base address has been selected in a completely arbitrary fashion.
This patch adds an SPI master device node for Armada XP-GP board.
This master node is an SPI flash controller 'n25q128a13'.
Since there is no 'partitions' node declared, one full sized
partition named as the device will be created.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Lior Amsalem <alior@marvell.com>
Tested-by: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Gregory Clement <gregory.clement@free-electrons.com>
This is the new Armada XP evaluation board from Marvell. It comes with
a RS232 port over USB, a SATA link, an internal SSD, 4 Ethernet
Gigabit links.
Support for USB (Host and device), SDIO, PCIe will be added as drivers
when they become available for Armada XP in mainline.
Tested-by: Simon Guinot <simon.guinot@sequanux.org>
Tested-by: Florian Fainelli <florian@openwrt.org>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
