commit d7d5a43c0d16760f25d892bf9329848167a8b8a4 upstream.
When the Crypto SRAM mappings were added to the Device Tree files
describing the Armada XP boards in commit c466d997bb16 ("ARM: mvebu:
define crypto SRAM ranges for all armada-xp boards"), the fact that
those mappings were overlaping with the PCIe memory aperture was
overlooked. Due to this, we currently have for all Armada XP platforms
a situation that looks like this:
Memory mapping on Armada XP boards with internal registers at
0xf1000000:
- 0x00000000 -> 0xf0000000 3.75G RAM
- 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB)
- 0xf1000000 -> 0xf1100000 1M internal registers
- 0xf8000000 -> 0xffe0000 126M PCIe memory aperture
- 0xf8100000 -> 0xf8110000 64KB Crypto SRAM #0 => OVERLAPS WITH PCIE !
- 0xf8110000 -> 0xf8120000 64KB Crypto SRAM #1 => OVERLAPS WITH PCIE !
- 0xffe00000 -> 0xfff00000 1M PCIe I/O aperture
- 0xfff0000 -> 0xffffffff 1M BootROM
The overlap means that when PCIe devices are added, depending on their
memory window needs, they might or might not be mapped into the
physical address space. Indeed, they will not be mapped if the area
allocated in the PCIe memory aperture by the PCI core overlaps with
one of the Crypto SRAM. Typically, a Intel IGB PCIe NIC that needs 8MB
of PCIe memory will see its PCIe memory window allocated from
0xf80000000 for 8MB, which overlaps with the Crypto SRAM windows. Due
to this, the PCIe window is not created, and any attempt to access the
PCIe window makes the kernel explode:
[ 3.302213] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.307841] pci 0000:00:09.0: enabling device (0140 -> 0143)
[ 3.313539] mvebu_mbus: cannot add window '4:f8', conflicts with another window
[ 3.320870] mvebu-pcie soc:pcie-controller: Could not create MBus window at [mem 0xf8000000-0xf87fffff]: -22
[ 3.330811] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf08c0018
This problem does not occur on Armada 370 boards, because we use the
following memory mapping (for boards that have internal registers at
0xf1000000):
- 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 => OK !
Obviously, the solution is to align the location of the Crypto SRAM
mappings of Armada XP to be similar with the ones on Armada 370, i.e
have them between the "internal registers" area and the beginning of
the PCIe aperture.
However, we have a special case with the OpenBlocks AX3-4 platform,
which has a 128 MB NOR flash. Currently, this NOR flash is mapped from
0xf0000000 to 0xf8000000. This is possible because on OpenBlocks
AX3-4, the internal registers are not at 0xf1000000. And this explains
why the Crypto SRAM mappings were not configured at the same place on
Armada XP.
Hence, the solution is two-fold:
(1) Move the NOR flash mapping on Armada XP OpenBlocks AX3-4 from
0xe8000000 to 0xf0000000. This frees the 0xf0000000 ->
0xf80000000 space.
(2) Move the Crypto SRAM mappings on Armada XP to be similar to
Armada 370 (except of course that Armada XP has two Crypto SRAM
and not one).
After this patch, the memory mapping on Armada XP boards with
registers at 0xf1 is:
- 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1
And the memory mapping for the special case of the OpenBlocks AX3-4
(internal registers at 0xd0000000, NOR of 128 MB):
- 0x00000000 -> 0xc0000000 3G RAM
- 0xd0000000 -> 0xd1000000 1M internal registers
- 0xe800000 -> 0xf0000000 128M NOR flash
Fixes: c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards")
Reported-by: Phil Sutter <phil@nwl.cc>
Cc: Phil Sutter <phil@nwl.cc>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
GPLv2+/X11
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Benoit Masson <yahoo@perenite.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
There are currently 2 differents naming conventions used between the
existing Armada SoC DT files for pinctrl entries (*_pin(s): *-pin(s)
and pmx_*: pmx-*) with a vast majority of files using the former:
$ grep _pin arch/arm/boot/dts/armada-*.dts* | wc -l
155
$ grep pmx arch/arm/boot/dts/armada-*.dts* | wc -l
13
In fact, only some Armada XP files are using the second variant.
This patch normalizes those files (mainly ge0/1 entries) to use
the first variant.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Link: https://lkml.kernel.org/r/00114c3169e1d93259ff4150ed46ee36eae16b1e.1416670812.git.arno@natisbad.org
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Now that labels for uartX are available in Marvell Armada .dtsi files,
this patch replaces the "/soc/internal-regs/serial@12000" found in
armada-xp-lenovo-ix4-300d.dts file for stdout-path property by the more
concise &uart0.
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/d1a883510e01f7f212a385e826dccbef903fae42.1416613429.git.arno@natisbad.org
There is only one 74hc595 connected to GPIO but two were given
in the registers-number property. Fix it up.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-By: Benoit Masson <yahoo@perenite.com>
There is an I2C eeprom connected on Lenovo ix4-300d, add the
corresponding node.
Lenovo ix4-300d has two ethernet PHYs connected via RGMII. Add the
corresponding pinctrl settings.
Armada XP pinctrl node gained an alias, make use of it.
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
In other MVEBU SoCs, the pin controller node is called pin-ctrl with
its base address added. Also, we have a node alias to access the pinctrl
node easily. Fix this for Armada XP pinctrl nodes to be consistent with
other SoCs.
The Lenovo Iomega ix4-300d is a 4-Bay sata NAS with dual Gb, USB2.0 & 3.0,
powered by a Marvell Armada XP MV78230 dual core CPU.
http://shop.lenovo.com/us/en/servers/network-storage/lenovoemc/ix4-300d/
Signed-off-by: Benoit Masson <yahoo@perenite.com>
Link: https://lkml.kernel.org/r/1406503839-4662-1-git-send-email-yahoo@perenite.com
