This patch moves all Armada 370/XP/38x/39x SPI controller nodes from the
'internal-regs' node down into the 'soc' node. This is in preparation
to enable the usage of the SPI direct access mode. A follow-up patch
will add the static MBus mappings for the SPI devices into the 'reg'
property of the SPI controller DT node.
By moving these SPI controller nodes, this patch also makes use of
the labels rather than keeping the tree structure.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Mark Brown <broonie@kernel.org>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Some of the GPIO configs were wrong in the submitted DTS files,
this patch fixes all affected boards.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Cc: <stable@vger.kernel.org> # v4.1 +
When the Crypto SRAM mappings were added to the Device Tree files
describing the Armada XP boards in commit c466d997bb16 ("ARM: mvebu:
define crypto SRAM ranges for all armada-xp boards"), the fact that
those mappings were overlaping with the PCIe memory aperture was
overlooked. Due to this, we currently have for all Armada XP platforms
a situation that looks like this:
Memory mapping on Armada XP boards with internal registers at
0xf1000000:
- 0x00000000 -> 0xf0000000 3.75G RAM
- 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB)
- 0xf1000000 -> 0xf1100000 1M internal registers
- 0xf8000000 -> 0xffe0000 126M PCIe memory aperture
- 0xf8100000 -> 0xf8110000 64KB Crypto SRAM #0 => OVERLAPS WITH PCIE !
- 0xf8110000 -> 0xf8120000 64KB Crypto SRAM #1 => OVERLAPS WITH PCIE !
- 0xffe00000 -> 0xfff00000 1M PCIe I/O aperture
- 0xfff0000 -> 0xffffffff 1M BootROM
The overlap means that when PCIe devices are added, depending on their
memory window needs, they might or might not be mapped into the
physical address space. Indeed, they will not be mapped if the area
allocated in the PCIe memory aperture by the PCI core overlaps with
one of the Crypto SRAM. Typically, a Intel IGB PCIe NIC that needs 8MB
of PCIe memory will see its PCIe memory window allocated from
0xf80000000 for 8MB, which overlaps with the Crypto SRAM windows. Due
to this, the PCIe window is not created, and any attempt to access the
PCIe window makes the kernel explode:
[ 3.302213] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.307841] pci 0000:00:09.0: enabling device (0140 -> 0143)
[ 3.313539] mvebu_mbus: cannot add window '4:f8', conflicts with another window
[ 3.320870] mvebu-pcie soc:pcie-controller: Could not create MBus window at [mem 0xf8000000-0xf87fffff]: -22
[ 3.330811] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf08c0018
This problem does not occur on Armada 370 boards, because we use the
following memory mapping (for boards that have internal registers at
0xf1000000):
- 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 => OK !
Obviously, the solution is to align the location of the Crypto SRAM
mappings of Armada XP to be similar with the ones on Armada 370, i.e
have them between the "internal registers" area and the beginning of
the PCIe aperture.
However, we have a special case with the OpenBlocks AX3-4 platform,
which has a 128 MB NOR flash. Currently, this NOR flash is mapped from
0xf0000000 to 0xf8000000. This is possible because on OpenBlocks
AX3-4, the internal registers are not at 0xf1000000. And this explains
why the Crypto SRAM mappings were not configured at the same place on
Armada XP.
Hence, the solution is two-fold:
(1) Move the NOR flash mapping on Armada XP OpenBlocks AX3-4 from
0xe8000000 to 0xf0000000. This frees the 0xf0000000 ->
0xf80000000 space.
(2) Move the Crypto SRAM mappings on Armada XP to be similar to
Armada 370 (except of course that Armada XP has two Crypto SRAM
and not one).
After this patch, the memory mapping on Armada XP boards with
registers at 0xf1 is:
- 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1
And the memory mapping for the special case of the OpenBlocks AX3-4
(internal registers at 0xd0000000, NOR of 128 MB):
- 0x00000000 -> 0xc0000000 3G RAM
- 0xd0000000 -> 0xd1000000 1M internal registers
- 0xe800000 -> 0xf0000000 128M NOR flash
Fixes: c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards")
Reported-by: Phil Sutter <phil@nwl.cc>
Cc: Phil Sutter <phil@nwl.cc>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
The Mamba (like the OpenBlocks AX3) doesn't have a crystal
connected to the internal RTC - let's prevent the kernel from
probing it.
Cc: <stable@vger.kernel.org> # v4.0 +
Add a DSA section to the DT blob representing the Ethernet switch.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
The Linksys WRT1900AC (Mamba) is a router that has
- 2 mini-PCIe slots with Marvell 88W8864 radios
- 1 USB 3.0 port
- 1 USB 2.0/eSATAp port
- 2 Ethernet interfaces connected to a 88E6172 switch (1x WAN + 4x LAN)
- 128MB NAND flash
- 256MB RAM
gregory.clement@free-electrons.com: - add ARM to the title
- fix the reference to CONFIG_DEBUG_MVEBU_UART0_ALTERNATE
- fix the unbalanced comment for the syscfg partition
