commit 12b69a599745fc9e203f61fbb7160b2cc5f479dd upstream.
Various Marvell datasheets advertise second PCIe unit of mv78230
flavour of Armada XP as x4/quad x1 capable. This second unit is in
fact only x1 capable. This patch fixes current mv78230 .dtsi to
reflect that, i.e. makes 1.0 the second interface (instead of 2.0
at the moment). This was successfully tested on a mv78230-based
ReadyNAS 2120 platform with a x1 device (FL1009 XHCI controller)
connected to this second interface.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Introduce a 'internal-regs' subnode, under which all devices are
moved. This is not really needed for now, but will be for the
mvebu-mbus driver. This generates a lot of code movement since it's
indenting by one more tab all the devices. So it was a good
opportunity to fix all the bad indentation.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This conversion will allow to keep 32 bits addresses for the internal
registers whereas the memory of the system will be 64 bits.
Later it will also ease the move of the mvebu-mbus driver to the
device tree support.
Align the cpu node indentation with the rest of the file
[gc]: added a commit description
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The Armada XP SoCs have multiple PCIe interfaces. The MV78230 has 2
PCIe units (one 4x or quad 1x, the other 1x only), the MV78260 has 3
PCIe units (two 4x or quad 1x and one 4x/1x), the MV78460 has 4 PCIe
units (two 4x or quad 1x and two 4x/1x). We therefore add the
necessary Device Tree informations to make those PCIe interfaces
usable.
The SDIO interface is only available on pins MPP30/31/32/33/34/35 on
the various Armada XP variants, so we provide a pin muxing option for
this in the Armada XP .dtsi files.
Even though those muxing options are the same for MV78230, MV78260 and
MV78460, we keep them in each .dtsi file, because the number of pins,
and therefore the declaration of the pinctrl node, is different for
each SoC variant.
The Armada XP GPIO controller has two ways of notifying interrupts:
using global interrupts or using per-CPU interrupts. In an attempt to
use the best available features, the 'marvell,armadaxp-gpio'
compatible string selects a variant of the gpio-mvebu driver that
makes use of the per-CPU interrupts.
Unfortunately, this doesn't work properly in a SMP context, because we
fall into cases where the GPIO interrupt is enabled on CPU X at the
GPIO controller level, but on CPU Y at the interrupt controller
level. It is not yet clear how to fix that easily.
So for 3.8, our approach is to switch to global interrupts for GPIOs,
so that we do not fall into this per-CPU interrupts problem.
This patch therefore fixes GPIO interrupts on Armada XP
platforms. Without this patch, GPIO interrupts simply do not work
reliably, because their proper operation depends on which CPU the code
requesting the interrupt is running.
The Armada XP MV78230 DT include file is missing a ; at the
end of the cpu node.
Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Contrary to our understanding at the time armada-xp-mv78230.dtsi was
written, the MV78230 variant of the Armada XP SoC has two cores and
not one. This patch updates the .dtsi file to take into account this
reality.
Tested-by Gregory CLEMENT <gregory.clement@free-electrons.com>
The gpioX aliases are needed so that the driver can use
of_alias_get_id() to get a 0-based number of the GPIO bank, which we
then use to compute the base GPIO of the bank being probed. This is
similar to what gpio-mxs.c is doing.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
This commits adds the necessary device tree information to define the
compatible property for the pinctrl driver instance of Armada XP SoCs.
Until now, the device tree representation considered the Armada XP as
a single SoC. But in fact, there are three different SoCs in the
Armada XP families, with different number of CPU cores, different
number of Ethernet interfaces... and different number of muxable pins
or functions. We therefore introduce three armada-xp-mv78xx0.dtsi for
the three SoCs of the Armada XP family. The current armada-xp-db.dts
evaluation board uses the MV78460 variant of the SoC.
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
