According to the binding documentation and the source code the atmel-gpio
controller takes IRQ_TYPE_* as its flags values, not GPIO_ACTIVE_*.
This patch uses the right variable type which yields the same result
when compiled. Note that this might be wrong and actually
IRQ_TYPE_LEVEL_LOW is intended by the dt author.
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The board is now manufactured by Aries Embedded GmbH, update compat string.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
vcc_3v3_reg and vcc_mmc1_reg are fixed regulators and don't need a
reg property. Remove their unit-address.
Solves:
Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /fixedregulator@1 has a unit name, but no reg property
The Denx MA5D4 dts doesn't properly define the slow_xtal and main_xtal
frequencies, the PMC then has to fallback to using the RC oscillators whose
precision is not really good.
As both crystals are populated, define their frequencies, see p17 of
http://www.denx-cs.de/sites/all/files/MA5D4.HWM_.002.pdf
Also, remove the obsolete main_clock definition.
Add support for the DENX MA5D4 SoM and MA5D4EVK board. The system
consists of a SoM with eMMC, SPI NOR for booting, 2x SPI CAN chip
and an EVK with microSD slot, 2x UART, 2x CAN port, 3x USB port,
LEDs and expansion headers.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Josh Wu <josh.wu@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
