Fix instances of "disable" instead of "disabled"
in the at91rm9200 dtsi.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The PMC is not only used to drive the clocks but also has some registers
related to other functions. One of those is for example the USB gadget
bias.
Using a syscon allows to properly separate those functions.
The system timer, the RTC and the timer counters need the slow clock, add
it.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Pull ARM SoC DT updates from Kevin Hilman:
"As usual, quite a few device-tree updates in ARM land. There was one
minor churn in DTs due to relicensing under a dual-license, and lots
of little additions of new peripherals, features etc, but nothing
really exciting to call to your attention. Some higlights, focsuing
on support for new SoCs and boards:
- AT91: new boards: Overkiz, Acme Systems' Arietta G25
- tegra: HDA support
- bcm: new platforms: Buffalo WXR-1900DHP, SmartRG SR400ac, ASUS
RT-AC87U
- mvebu: new platforms: Compulab CM-A510, Armada 385-based Linksys
boards, DLink DNS-327L
- OMAP: new platforms: Baltos IR5221, LogicPD Torpedo, Toby-Churchill
SL50
- ARM: added support for Juno r1 board
- sunxi: A33 SoC support; new boards: A23 EVB, SinA33, GA10H-A33,
Mele A1000G
- imx: i.MX7D SoC support; new boards: Armadeus Systems APF6,
Gateworks GW5510, and aristainetos2 boards
- hisilicon: hi6220 SoC support; new boards: 96boards hikey"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (462 commits)
ARM: hisi: revert changes from hisi/hip04-dt branch
ARM: nomadik: set proper compatible for accelerometer
ARM64: juno: add GPIO keys
ARM: at91/dt: sama5d4: fix dma conf for aes, sha and tdes nodes
ARM: dts: Introduce STM32F429 MCU
ARM: socfpga: dts: enable ethernet for Arria10 devkit
ARM: dts: k2l: fix the netcp range size
ARM: dts: k2e: fix the netcp range size
ARM: dts: k2hk: fix the netcp range size
ARM: dts: k2l-evm: Add device bindings for netcp driver
ARM: dts: k2e-evm: Add device bindings for netcp driver
ARM: dts: k2hk-evm: Add device bindings for netcp driver
ARM: BCM5301X: Add DT for Asus RT-AC87U
ARM: BCM5301X: add IRQ numbers for PCIe controller
ARM: BCM5301X: add NAND flash chip description
arm64: dts: Add dts files for Hisilicon Hi6220 SoC
clk: hi6220: Document devicetree bindings for hi6220 clock
arm64: hi6220: Document devicetree bindings for Hisilicon hi6220 SoC
ARM: at91/dt: sama5d4ek: mci0 uses slot 0
ARM: at91/dt: kizbox: fix mismatch LED PWM device
The ohci driver now calls clk_set_rate on the uhpck clock (which forwards
set_rate requests to its parent: the usb clock).
Remove useless references to usb clocks from ohci definitions.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The at91rm9200 memory controller is not simply an SDRAM controller. It also
controls the EBI (External Bus Interface), the SMC (Static Memory Controller)and
the Burst Flash Controller.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The system timer register range is used to handle three different
functionalities: Periodic Interval Timer, Real Time Timer and watchdog. Declare
it as a syscon to be able to get a regmap.
Also declare it as a simple-mfd and its watchdog subnode.
Finally, document the watchdog compatible string.
The DBGU is not a simple UART and we need to be able to distinguish it from the
other UARTs, in particular to get its address and check the chip id.
Add nodes for the SRAM available on atmel SoCs
For the at91sam9260 and the at91sam9g20, address mirroring is used to create a
single contiguous SRAM range instead of declaring two separate banks.
Also remove leftover TODOs in the sam9g45 file
[nicolas.ferre@atmel.com: correct at91sam9rl sram size => 0x10000]
Add a node for the RTC available on at91rm9200.
The atmel,clk-divisors property is taking 4 divisors, if less are
provided, the clock registration will fail.
Swap names as they were improperly defined.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
From Nicolas Ferre:
- more SPI DT activation for rm9200
- SPI DMA for at91sam9n12/sama5d3
And one little fix for SPI compatibility string
* tag 'at91-dt' of git://github.com/at91linux/linux-at91:
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
arch/arm/boot/dts/sama5d3.dtsi
From Lorenzo Pieralisi, this is a series of patches that cleans up the CPU
nodes in most of the SoC dtsi files to conform to the standard bindings.
* 'dts-cpus-updates' of git://linux-arm.org/linux-2.6-lp:
ARM: dts: sunxi: cpus/cpu nodes dts updates
ARM: dts: spear: cpus/cpu nodes dts updates
ARM: dts: sh7372: cpus/cpu nodes dts updates
ARM: dts: r8a7740: cpus/cpu nodes dts updates
ARM: dts: pxa2xx: cpus/cpu nodes dts updates
ARM: dts: prima2: cpus/cpu node dts updates
ARM: dts: picoxcell: cpus/cpu nodes dts updates
ARM: dts: omap: cpus/cpu nodes dts updates
ARM: dts: lpc32xx: cpus/cpu nodes dts updates
ARM: dts: imx: cpus/cpu nodes dts updates
ARM: dts: exynos5440: cpus/cpu nodes dts updates
ARM: dts: at91: cpus/cpu node dts updates
ARM: dts: armada-370-xp: cpus/cpu node dts updates
ARM: dts: am33xx: cpus/cpu nodes dts updates
This patch adds pinctrl configurations for at91 Timer Counter blocks.
These pin definitions can be referenced by "atmel,tcb-pwm" devices to
setup pins as PWM output for instance.
Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com>
[nicolas.ferre@atmel.com: switch to pinctrl pre-processor macros]
This patch updates the in-kernel dts files according to the latest cpus
and cpu bindings updates for ARM.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
to prepare the switch to the macro.
GPIO pins used by i2c-gpio must be set to multi drive
(open drain) to work properly.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
