Add nodes for the SRAM available on atmel SoCs
For the at91sam9260 and the at91sam9g20, address mirroring is used to create a
single contiguous SRAM range instead of declaring two separate banks.
Also remove leftover TODOs in the sam9g45 file
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
[nicolas.ferre@atmel.com: correct at91sam9rl sram size => 0x10000]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
As the SSC integrate in at91sam9g20 support frame sync length
extension, so switch compatible string to support this feature.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
The at91sam9g20 SOC uses its own pllb implementation which is different
from the one inherited from at91sam9260 SOC.
Signed-off-by: Gaël PORTAY <gael.portay@gmail.com>
Define the at91sam9g20 clocks that differ from at91sam9260 in the SoC dtsi file.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
to prepare the switch to the macro.
Add TWI nodes for atmel SoCs but keep i2c-gpio ones in order to let the
choice to the user in dts files.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Now that the bulk of at91sam9g20-related nodes are located in at91sam9260.dtsi,
we have to re-create the path to this ADC node for SoC specific parts.
The at91sam9260 and at91sam9g20 share most of the same IP.
So udpate the node property in the at91sam9g20 only.
These were incorrectly introduced and can cause problems for of_irq_init.
The correct way to define a root controller is no interrupt-parent set at
all or the interrupt-parent is set to the root controller itself when
inherited from a parent node.
Tested-by: Lee Jones <lee.jones@linaro.org>
Because of the inclusion of skeleton.dtsi, the memory node is
named "memory" we where not modifying the already included one
but creating a new one. It caused bad memory node detection during
early_init_dt_scan_memory() so we modify them.
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: devicetree-discuss@lists.ozlabs.org
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Use a string to specific the wakeup mode to make it more readable.
Add the Real-time Clock Wake-up support too for sam9g45 and sam9x5.
Add AT91_SHDW_CPTWK0_MAX to specific the Max of the Wakeup Counter.
Acked-by: Rob Herring <rob.herring@calxeda.com>
We can now drop the call to ioremap_registers() as we have the binding for the
SDRAM/DDR Controller.
Drop ioremap_registers() for sam9x5 too.
Specified the main Oscillator via clock binding.
This will allow to do not hardcode it anymore in the DT board at 12MHz.
For now on use i2c-gpio driver on the same pin as the hardware IP.
Use a local copy of board informatin and fill with DT data.
Device tree support added to atmel_tclib: the generic Timer Counter
library. This is used by the clocksource/clockevent driver tcb_clksrc.
The current DT enabled platforms are also modified to use it:
- .dtsi files are modified to add Timer Counter Block entries
- alias are created to allow identification of each block
- clkdev lookup tables are added for clocks identification.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Retreive registers address and IRQ from device tree entry.
Called from at91_dt_init_irq() so that timers are up-n-running
when timers initialization will occur.
[nicolas.ferre@atmel.com: change error path and interrupts property handling]
Add "legacy" type of irqdomain to preserve old-style numbering
and allow smooth transition for both DT and non-DT cases.
Original idea and code by Jean-Christophe Plagniol-Villard.
Add an irqdomain for the AIC interrupt controller.
The device tree support is mapping the registers and
is using the irq_domain_add_legacy() to manage hwirq
translation.
The documentation is describing the meaning of the
two cells required for using this "interrupt-controller"
in a device tree node.
Add the Cadence macb ethernet controller in at91sam9g45 and at91sam9g20
.dtsi and enable it in at91sam9m10g45ek and usb_a9g20 board device tree file.
Reviewed-by: Rob Herring <rob.herring@calxeda.com>
