The clocks group properties and the clock@0 node are useless, remove them
to avoid copy pasting in future device trees.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
On at91sam9x5ek/at91sam9m10g45ek/sama5d3xek boards, we use the parallel
connection for ov2640. So we must set the hsync/vsync property (1 means
active high).
Otherwise, the connection would be seen as BT.656 or BT.1120.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
First we group the isi data pins, and for now we only use 0~7 data pins
with HSYNC and VSYNC.
Also add the link for atmel-isi and ov2640 sensor node.
[nicolas.ferre@atmel.com: move the pinctrl properties in board .dts file]
Use stdout-path to specify the console and remove the console argument from
the kernel command line.
Enable the RTT and GPBR devices and specify the general purpose register
used to store the current time.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Add rtc node to both the at91sam9g45 SoC family and the at91sam9m10g45ek board.
Signed-off-by: Erik van Luijk <evanluijk@interact.nl>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Define at91sam9m10g45ek main and slow crystals frequencies.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The real polarity of the LEDs is inversed. The led is between 3.3v and the PWM.
It was working before because the driver was getting the duty cycle calculation
wrong.
The d6 and d7 is connected to PWM, we can use PWM to control it,
so switch to PWM leds.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Tested-by: Bo Shen <voice.shen@atmel.com>
boards include:
at91sam9263ek, at91sam9g20ek, at91sam9m10g45ek, at91sam9n12ek, at91sam9x5ek
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
to prepare the switch to the macro.
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
[wenyou.yang@atmel.com: added spi nodes for the sam9263ek, sam9g20ek, sam9m10g45ek and sam9n12ek boards]
[wenyou.yang@atmel.com: submit the patch]
Gpio-keys nodes are not using the "reg" property in their sub nodes.
So, there is no need to define #address-cells and #size-cells properties
in gpio-keys nodes: we remove them.
Add mci controller nodes to atmel boards.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
as we just use the rts and not the rts & cts for rs485
USART are the full pin uart
DBGU the debug Unit
UART the two pin uart
Still use i2c-gpio on boards which have a SoC with a TWI IP which
doesn't have clock stretching in transmission mode.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Because of the inclusion of skeleton.dtsi, the memory node is
named "memory" we where not modifying the already included one
but creating a new one. It caused bad memory node detection during
early_init_dt_scan_memory() so we modify them.
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: devicetree-discuss@lists.ozlabs.org
Change vbus gpio configuration in .dts files to switch to
active low configuration.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: stable <stable@vger.kernel.org>
make the ECHI depends on ARCH_AT91
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Specified the main Oscillator via clock binding.
This will allow to do not hardcode it anymore in the DT board at 12MHz.
Acked-by: Rob Herring <rob.herring@calxeda.com>
Use a local copy of board informatin and fill with DT data.
Use the gpio for d7 as we do not support yet the pwm led via dt.
Add the Cadence macb ethernet controller in at91sam9g45 and at91sam9g20
.dtsi and enable it in at91sam9m10g45ek and usb_a9g20 board device tree file.
Create a new device tree source file for Atmel at91sam9g45 SoC family.
The Evaluation Kit at91sam9m10g45ek includes it.
This first basic support will be populated as drivers and boards will be
converted to device tree.
Contains serial, dma and interrupt controllers.
The generic board file still takes advantage of platform data for early serial
init. As we need a storage media and the NAND flash driver is not converted to
DT yet, we keep old initialization for it.
Reviewed-by: Rob Herring <rob.herring@calxeda.com>
