path: root/arch/arm/boot/dts/at91sam9x25ek.dts
2013-05-27Merge tag 'at91-cleanup' of git://github.com/at91linux/linux-at91 into ↵Olof Johansson
next/cleanup From Nicolas Ferre: Big update converting pinctrl to use macros and header files. Increases readability and avoids typos. Update of AT91 defconfigs and merge of defconfigs for the similar SoCs sam9260/9g20 and sam9261/9g10. * tag 'at91-cleanup' of git://github.com/at91linux/linux-at91: ARM: at91: udpate defconfigs ARM: at91: dt: switch to standard IRQ flag defines ARM: at91: dt: switch to pinctrl to pre-processor ARM: at91: dt: add pinctrl pre-processor define ARM: at91: dt: switch to standard GPIO flag defines. ARM: at91: dt: use #include for all device trees Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-14ARM: at91/trivial: fix model name for SAM9X25-EKJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: stable <stable@vger.kernel.org> # 3.8+
2013-04-04ARM: at91/dt: fix macb node declarationNicolas Ferre
Macb0 node cannot be activated in generic sam9x5ek.dtsi file as the sam9g15 does not have one. Move the macb0 & macb1 activation in board .dts file that support them. Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-10-13arm: at91: dt: at91sam9 add serial pinctrl supportJean-Christophe PLAGNIOL-VILLARD
Set the dbgu pinctrl config by default as we have only one possible config For other uart set the rxd/txd by default. For at91sam9x5ek create soc based dts as we need to include specific soc dtsi. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
