Enable RTC for all the at91sam9x5 CPU Modules: this will enable it for all the
EK boards.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Having clocks grouped in a subnode is common practice, so move the crystals and
the ADC clock under a clocks node for the at91sam9x5 SoC and at91sam9x5 based
boards.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Define sam9x5ek's main and slow crystal frequencies.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
This add the 1-wire chip present on the CM board to the DTS.
As the pin is also used by leds, it's disabled by default.
If the board really wants it, it can be enabled in the board DTS.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Default ecc correctable setting is 2bits in 512 bytes.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Because of the inclusion of skeleton.dtsi, the memory node is
named "memory" we where not modifying the already included one
but creating a new one. It caused bad memory node detection during
early_init_dt_scan_memory() so we modify them.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: devicetree-discuss@lists.ozlabs.org
Specified the main Oscillator via clock binding.
This will allow to do not hardcode it anymore in the DT board at 12MHz.
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Enable the nand in the cpu module with the partition.
Device tree include file for the AT91SAM9x5 SoC family.
An additional .dtsi file is created to describe the generic
SAM9x5 CPU Module (CM).
Device tree source files for each Evaluation Kit that are using
the generic CPU Module and the carrier board. The selection of
available peripherals is done in this .dts file.
