path: root/arch/arm/boot/dts/at91sam9x5cm.dtsi
2013-05-17ARM: at91: dt: switch to pinctrl to pre-processorJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-03-21ARM: at91/at91sam9x5cm: add 1-wire chip on CM boardRichard Genoud
This add the 1-wire chip present on the CM board to the DTS. As the pin is also used by leds, it's disabled by default. If the board really wants it, it can be enabled in the board DTS. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-02-07ARM: at91: at91sam9x5: add DT parameters to enable PMECCJosh Wu
Default ecc correctable setting is 2bits in 512 bytes. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-04-04ARM: at91: dt: remove unit-address part for memory nodesLudovic Desroches
Because of the inclusion of skeleton.dtsi, the memory node is named "memory" we where not modifying the already included one but creating a new one. It caused bad memory node detection during early_init_dt_scan_memory() so we modify them. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: devicetree-discuss@lists.ozlabs.org
2012-03-15ARM: at91: add pmc DT supportJean-Christophe PLAGNIOL-VILLARD
Specified the main Oscillator via clock binding. This will allow to do not hardcode it anymore in the DT board at 12MHz. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-03-15ARM: at91: sam9x5 add nand supportJean-Christophe PLAGNIOL-VILLARD
Enable the nand in the cpu module with the partition. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-03-01ARM: at91: at91sam9x5cm/dt: add leds supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-02-03ARM: at91/at91sam9x5: Device tree definition filesNicolas Ferre
Device tree include file for the AT91SAM9x5 SoC family. An additional .dtsi file is created to describe the generic SAM9x5 CPU Module (CM). Device tree source files for each Evaluation Kit that are using the generic CPU Module and the carrier board. The selection of available peripherals is done in this .dts file. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
