[ Upstream commit 403fde644855bc71318c8db65646383e22653b13 ]
The interrupts for the PCIe controllers should all be of type
IRQ_TYPE_LEVEL_HIGH instead of IRQ_TYPE_NONE.
Fixes: d71eb9412088 ("ARM: dts: NSP: Add MSI support on PCI")
Fixes: 522199029fdc ("ARM: dts: NSP: Fix PCIE DT issue")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit a3e32e78a40017756c71ef6dad429ffe3301126a ]
The i2c controller should use IRQ_TYPE_LEVEL_HIGH instead of
IRQ_TYPE_NONE.
Fixes: 0f9f27a36d09 ("ARM: dts: NSP: Add I2C support to the DT")
[ Upstream commit 5f1aa51c7a1eef1c5a60b8334e32c89904964245 ]
Booting a kernel results in the kernel warning us about the following
PPI interrupts configuration:
[ 0.105127] smp: Bringing up secondary CPUs ...
[ 0.110545] GIC: PPI11 is secure or misconfigured
[ 0.110551] GIC: PPI13 is secure or misconfigured
Fix this by using the appropriate edge configuration for PPI11 and
PPI13, this is similar to what was fixed for Northstar (BCM5301X) in
commit 0e34079cd1f6 ("ARM: dts: BCM5301X: Correct GIC_PPI interrupt
flags").
Fixes: 7b2e987de207 ("ARM: NSP: add minimal Northstar Plus device tree")
Fixes: 1a9d53cabaf4 ("ARM: dts: NSP: Add TWD Support to DT")
Acked-by: Jon Mason <jon.mason@broadcom.com>
This uses the existing Northstar USB3 PHY driver to enable the USB3
ports on NSP.
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
The rest of the DTSI file is in incrementing addresses, but the USB
OHCI/ECHI entries are out of sequence. Move them to put them in the
proper place.
Cache related issues with DMA rings and performance issues related to
caching are being caused by not properly setting the "dma-coherent" flag
in the device tree entries. Adding it here to correct the issue.
Fixes: 3107fa5bcfb2 ("ARM: dts: NSP: Add SD/MMC support")
Fixes: 13d04f20935c ("ARM: dts: NSP: Add AMAC entries")
Fixes: 5aeda7bf8a1e ("ARM: dts: NSP: Add and enable amac2")
Fixes: 17d517172300 ("ARM: dts: NSP: Add mailbox (PDC) to NSP")
Fixes: 1d8ece6639e1 ("ARM: dts: NSP: Add EHCI/OHCI USB nodes to device tree")
Fixes: 8dbcad020f2e ("ARM: dts: nsp: Add sata device tree entry")
Add thermal support via the ns-thermal driver and create a single
thermal zone for the entire SoC.
Acked-by: Eduardo Valentin <edubezval@gmail.com>
The unit address for the msi controller is not valid as there is no reg
property, so remove it. Also, msi-controller is the preferred node name.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Jon Mason <jonmason@broadcom.com>
Cc: bcm-kernel-feedback-list@broadcom.com
Acked-by: Ray Jui <ray.jui@broadcom.com>
Adds crypto hardware (SPU) to Northstar Plus device tree file.
Signed-off-by: Steve Lin <steven.lin1@broadcom.com>
Adds mailbox / PDC to NSP device tree. Needs new compatibility string
to differentiate from NS2 version.
The i2c device tree entry should be disabled by default to match the
current convention in other device tree files. Similarily, enable it on
the XMC board, where it is being used.
Add the EHCI and OHCI entries to the Northstar Plus device tree files.
Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yendapally.reddy@broadcom.com>
Pull ARM DT updates from Arnd Bergmann:
"A total of 380 patches this time, mostly adding support for more
hardware in the device tree descriptions. There is not much exciting
here for 4.11, but I've tried my best to condense the information from
the pull requests I got into a readable summary.
Noteworthy changes to existing platforms include:
- The GIC memory map was a bit wrong almost everywhere and now gets
fixed up
- The Allwinner platforms convert to the generic pinmux properties
- The Marvell EBU platforms now use the new DSA binding
- Samsung Exynos4212 was unused and gets removed
- The Renesas power management got improved
New production machines:
- Lego Mindstorms EV3:
https://www.lego.com/en-us/mindstorms/about-ev3
- Beelink X2 Android media box:
http://linux-sunxi.org/Beelink_X2
- "Romulus" baseboard management controller for OpenPower
- Axentia TSE-850 Data Radio Channel (DARC) encoder:
http://www.axentia.se/db/equipment.html
- Luxul XAP-1410 and XWR-1200 wireless access points:
https://luxul.com/xap-1410
New SoCs:
- Allwinner H2+ and V3s, both minor variations of already supported
chips:
http://www.allwinnertech.com/index.php?c=product&a=index&id=38
- Marvell Prestera DX packet processors based on Armada XP
architecture:
http://www.marvell.com/switching/prestera-dx/
- Samsung Exynos4412 Prime gets added, a minor variation of
Exynos4412
New developer and reference boards:
- Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on
Allwinner SoCs:
http://linux-sunxi.org/LicheePi_One
http://www.orangepi.org/orangepizero/
- SAMA5d36ek Reference platform:
http://www.atmel.com/tools/sama5d36-ek.aspx
- Beaglebone Green Wireless and Black Wireless:
https://beagleboard.org/black-wireless
https://beagleboard.org/green-wireless
- phyCORE-AM335x System on Module:
http://phytec.com/products/system-on-modules/phycore/am335x/
- New revision of "vf610-zii" Zodiac Inflight Innovations board
- Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam
i.Core:
http://www.opossom.com/english/index.html
http://www.savageboard.org/
http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
- Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is
- Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas,
qcom, rockchip, sti, stm32 and tegra
New device supports added to some boards and SoCs, briefly by platform:
- Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU
- Aspeed: network, ipmi bt, gpio, pinmux
- Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc
- TI DaVinci: gpio, lcdc, usb, video-in, uart
- TI Keystone 2: MSM RAM, power/reset, uart
- Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal
- Marvell EBU: ethernet switch on Turris Omnia
- NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom,
mmc, nand
- TI OMAP:
- Qualcomm: coresight, gyro/accelerometer, hdmi
- Renesas: pmic, soc-id
- Rockchip: qos
- Samsung: audio on Odroid-X
- Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor
- STi: video in/out
- STM32: timer, pwm, i2c, rtc, add, i2s
- NVIDIA Tegra: tpm
- Uniphier: mmc/sd pinmux"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits)
ARM: dts: armada-385-linksys: fix DSA compatible property
ARM: dts: Fix typo in armada-xp-98dx4251
ARM: DTS: Fix register map for virt-capable GIC
dt-bindings: arm,gic: Fix binding example for a virt-capable GIC
ARM: dts: sun8i: sinlinx: Enable audio nodes
ARM: dts: sun8i: parrot: Enable audio nodes
ARM: dts: sun8i: Add audio codec, dai and card for A33
ARM: dts: Add EMAC AXI settings for Arria10
ARM: dts: am335x-chiliboard: Support charger
ARM: dts: am335x-chiliboard: Support power button
ARM: sun8i: dt: Add mali node
dt-bindings: gpu: Add Mali Utgard bindings
ARM: dts: stm32: Add I2C1 support for STM32429 eval board
ARM: dts: stm32: Add I2C1 support for STM32F429 SoC
ARM: dts: stm32: Use clock DT binding definition on stm32f429 family
dt-bindings: mfd: stm32f4: Add missing binding definition
dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro
ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco
ARM: dts: stm32: add Timers driver for stm32f429 MCU
ARM: dts: add the AB8500 sysclk to the device trees
Add SD/MMC support to the Broadcom NSP SVK and XMC.
Add and enable the third AMAC ethernet interface in the device trees for
the platforms where it is present. Also, enable amac1 on some of the
platforms where that was missing.
The QSPI entry was added out of the sequental order that the rest of the
DTSI file is in. Move it to make it fit in properly. Also, some other
entries have been added in a non-alphabetical order in the DTS files,
making them different from the other NSP DTS files. Move the relevant
peices to make it match. Finally, remove errant new lines.
The range size for axi is 0x2 bytes too small, as the QSPI needs
0x11c408 + 0x004 (which is 0x0011c40c, not 0x0011c40a). No errors have
been observed with this shortcoming, but fixing it for correctness.
Fixes: 329f98c1974e ("ARM: dts: NSP: Add QSPI nodes to NSPI and bcm958625k DTSes")
This enables the GPIO-b support for Broadcom NSP SoC
Adding QSPI Device Tree node compatible with the new spi-bcm-qspi driver for
the Broadcom Northstar Plus SoC DTSI and bcm958625k reference board.
Signed-off-by: Kamal Dasu <kdasu.kdev@gmail.com>
Add PWM support to the device tree for the Broadcom Northstar Plus SoC.
Add the Switch Register Access Block node, this peripheral is identical
to the BCM5301x Northstar SoC, but we utilize the SoC-wide
"brcm,nsp-srab" compatible string to illustrate the integration
difference here.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Add Device Tree entries for the Ethernet devices (AMAC) present on the Broadcom
Northstar Plus SoCs.
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
"libata saw quite a bit of activities in this cycle:
- SMR drive support still being worked on
- bug fixes and improvements to misc SCSI command emulation
- some low level driver updates"
* 'for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (39 commits)
libata-scsi: better style in ata_msense_*()
AHCI: Clear GHC.IS to prevent unexpectly asserting INTx
ata: sata_dwc_460ex: remove redundant dev_err call
ata: define ATA_PROT_* in terms of ATA_PROT_FLAG_*
libata: remove ATA_PROT_FLAG_DATA
libata: remove ata_is_nodata
ata: make lba_{28,48}_ok() use ATA_MAX_SECTORS{,_LBA48}
libata-scsi: minor cleanup for ata_scsi_zbc_out_xlat
libata-scsi: Fix ZBC management out command translation
libata-scsi: Fix translation of REPORT ZONES command
ata: Handle ATA NCQ NO-DATA commands correctly
libata-eh: decode all taskfile protocols
ata: fixup ATA_PROT_NODATA
libsas: use ata_is_ncq() and ata_has_dma() accessors
libata: use ata_is_ncq() accessors
libata: return boolean values from ata_is_*
libata-scsi: avoid repeated calculation of number of TRIM ranges
libata-scsi: reject WRITE SAME (16) with n_block that exceeds limit
libata-scsi: rename ata_msense_ctl_mode() to ata_msense_control()
libata-scsi: fix D_SENSE bit relection in control mode page
Add sata support to the Northstar Plus SoC device tree.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Add PL330 support to the the Broadcom Northstar Plus device tree.
Signed-off-by: Jon Mason <jonmason@broadcom.com>
NSP B0 has a different address for the second core. Since there should
not be any Ax versions in the field, it should be safe to universally
change this.
Add MSI support to the PCI driver of the Northstar Plus SoC. This uses
the existing pcie-iproc driver. So, all that is needed is device tree
entries in the DTS.
Add support for the random number generator to the Northstar Plus
SoC device tree.
Add support for the ARM SP805 Watchdog timer to the Northstar Plus
device tree.
Add support for the ARM SP804 timer to the Northstar Plus device tree.
Add support for the ARM Performance Monitor Unit to the Northstar Plus
device tree.
There is a double definition of the CPUs present in the device tree.
Remove unnecessary cpu device tree definition.
Adding the ranges value is preventing the PCI nodes from working.
Pulling them out outside makes them work again (and makes it similar to
the NS2 device tree).
This enables the GPIO-a support for Broadcom NSP SoC
Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yrdreddy@broadcom.com>
Add device tree changes required for providing SMP support
for Broadcom Northstar Plus SoC.
Signed-off-by: Kapil Hali <kapilh@broadcom.com>
This enables the pinctrl support for Broadcom NSP SoC
Replace current device tree dummy clocks with real clock support for
Reviewed-by: Ray Jui <rjui@broadcom.com>
Add I2C support to the Broadcom Northstar Plus Device Tree. Since no
driver changes are needed to enable this hardware, only the device tree
changes are required to make this functional.
Minor changes to the Broadcom Northstar Plus device tree to make it more
organized and clean. Firstly, move the GIC and L2 cache entries to be
sequential with respect to the memory addresses. Secondly, modify the
address portion of the entry names to reflect the difference from the
range modification.
Add support for the ARM TWD Timer and Watchdog to the Northstar Plus
device tree.
Add NAND support to the device tree for the Broadcom Northstar Plus SoC.
Since no driver changes are needed to enable this hardware, only the
device tree changes are required to make this functional.
Add PCI support to the Northstar Plus SoC. This uses the existing
pcie-iproc driver. So, all that is needed is device tree entries in the
DTS.
Add a very minimalistic set of Northstar Plus Device Tree files which
describes the SoC and the BCM958625 implementation. The perpherials
described are:
ARM Cortex A9 CPU
2 8250 UARTs
ARM GIC
PL310 L2 Cache
ARM A9 Global timer
