path: root/arch/arm/boot/dts/bcm283x.dtsi
2020-05-02ARM: dts: bcm283x: Disable dsi0 nodeNicolas Saenz Julienne
commit 90444b958461a5f8fc299ece0fe17eab15cba1e1 upstream. Since its inception the module was meant to be disabled by default, but the original commit failed to add the relevant property. Fixes: 4aba4cf82054 ("ARM: dts: bcm2835: Add the DSI module nodes and clocks") Signed-off-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-12ARM: dts: bcm283x: Fix critical trip pointStefan Wahren
[ Upstream commit 30e647a764d446723a7e0fb08d209e0104f16173 ] During definition of the CPU thermal zone of BCM283x SoC family there was a misunderstanding of the meaning "criticial trip point" and the thermal throttling range of the VideoCore firmware. The latter one takes effect when the core temperature is at least 85 degree celsius or higher So the current critical trip point doesn't make sense, because the thermal shutdown appears before the firmware has a chance to throttle the ARM core(s). Fix these unwanted shutdowns by increasing the critical trip point to a value which shouldn't be reached with working thermal throttling. Fixes: 0fe4d2181cc4 ("ARM: dts: bcm283x: Add CPU thermal zone with 1 trip point") Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-24ARM: bcm283x: Reduce register ranges for UART, SPI and I2CStefan Wahren
The assigned register ranges for UART, SPI and I2C were too wasteful. In order to avoid overlapping with the new functions on BCM2711 reduce the ranges. Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Acked-by: Eric Anholt <eric@anholt.net>
2019-06-22ARM: bcm283x: Enable DMA support for SPI controllerLukas Wunner
Without this, the driver for the BCM2835 SPI controller uses interrupt mode instead of DMA mode, incurring a significant performance penalty. The Foundation's device tree has had these attributes for years, but for some reason they were never upstreamed. They were originally contributed by Noralf Trønnes and Martin Sperl: https://github.com/raspberrypi/linux/commit/25f3e064afc8 https://github.com/raspberrypi/linux/commit/e0edb52b47e6 The DREQ numbers 6 and 7 are documented in section 4.2.1.3 of: https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf Tested-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de> Signed-off-by: Lukas Wunner <lukas@wunner.de> Reviewed-by: Eric Anholt <eric@anholt.net> Reviewed-by: Martin Sperl <kernel@martin.sperl.org> Signed-off-by: Stefan Wahren <wahrenst@gmx.net> Cc: Martin Sperl <kernel@martin.sperl.org> Cc: Noralf Trønnes <noralf@tronnes.org>
2019-02-01ARM: bcm283x: Switch V3D over to using the PM driver instead of firmware.Eric Anholt
The GRAFX domain only contains V3D, and this driver should be the only accessor of V3D (firmware usage gets disabled when V3D is in the DT), so we can safely make Linux control the GRAFX and GRAFX_V3D power domains. Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
2019-02-01ARM: bcm283x: Extend the WDT DT node out to cover the whole PM block. (v4)Eric Anholt
It was covering part of the PM block's range, up to the WDT regs. To support the rest of the PM block's functionality, we need the full register range plus the AXI Async Bridge regs for PM sequencing. This doesn't convert any of the consumers over to the new binding yet, since we will need to be careful in coordinating our usage of firmware services that might power domains on and off versus the bcm2835-pm driver's access of those same domains. Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
2018-07-09ARM: dts: bcm283x: Add Transposer blockBoris Brezillon
The transposer block is allowing one to write the result of the VC4 composition back to memory instead of displaying it on a screen. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Liviu Dudau <liviu.dudau@arm.com> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-off-by: Eric Anholt <eric@anholt.net>
2018-04-16ARM: bcm283x: Add missing interrupt for RNG blockStefan Wahren
This patch adds the missing interrupt property to the RNG block of BCM283x. Link: https://github.com/raspberrypi/linux/issues/2195 CC: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2018-03-13Merge tag 'arm-soc/for-4.17/devicetree' of ↵Arnd Bergmann
https://github.com/Broadcom/stblinux into next/dt Pull "Broadcom devicetree changes for 4.17" from Florian Fainelli: This pull request contains Broadcom ARM-based SoCs devicetree changes for 4.17, please pull the following: - Henry fixes the pin functions for the JTAG pins, nothing uses this for now, but it could be backported eventually if deemed appropriate - Stefan fixes the register ranges for the bcm2835-i2s nodes in the binding document definition, he then fixes the probing of the bcm2835-i2s driver by providing an appropriate register range and a missing clock. Stefan also makes sure that the appropriate pull settings are applied to the pins used on the Raspberry Pi Zero Wireless, he then adds the necessary UART node to connected to the BCM43438 Bluetooth adapter on the Pi Zero W. He finally enables USB OTG mode on the Pi Zero W since he became usable again - Baruch adds the necessary Device Tree nodes to support the Raspberry Pi GPIO expander which is controlled via the VC4 firmware - Hiroshi adds the missing LEDs on the Buffalo WZR-900DHP router - Eric adds the DPI hardware block into the BCM283x Device Tree include file for future use when an actual panel is available - Florian updates the Northstar Plus platforms to use port 8 of the internal switch as the CPU/management port since necessary code was added in the b53 switch driver to support that * tag 'arm-soc/for-4.17/devicetree' of https://github.com/Broadcom/stblinux: ARM: dts: NSP: Switch to port 8 for CPU port ARM: bcm2835: Add the DPI hardware to the device tree. ARM: dts: BCM5301X: add missing LEDs for Buffalo WZR-900DHP ARM: dts: bcm2835-rpi-zero-w: Enable OTG mode ARM: dts: bcm2835-rpi-zero-w: Add bcm43438 serial slave ARM: dts: bcm283x: Apply pull settings to Zero W relevant groups ARM: dts: bcm2837-rpi-3-b: add GPIO expander ARM: dts: bcm2835: make the firmware node into a bus ARM: dts: bcm283x: Fix probing of bcm2835-i2s dt-bindings: bcm283x: Fix register ranges of bcm2835-i2s ARM: dts: bcm283x: Fix pin function of JTAG pins
2018-03-12ARM: bcm2835: Add the DPI hardware to the device tree.Eric Anholt
It's currently marked disabled, as it's not useful without a panel associated with it and the GPIO pins routed to ALT2. Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
2018-02-26ARM: dts: bcm283x: Apply pull settings to Zero W relevant groupsStefan Wahren
Instead of keeping the firmware's pull settings, we better apply them via the devicetree pin control. Start with the RPi Zero W relevant first to keep the effort low. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2018-02-22ARM: BCM: dts: Remove leading 0x and 0s from bindings notationMathieu Malaterre
Improve the DTS files by removing all the leading "0x" and zeros to fix the following dtc warnings: Warning (unit_address_format): Node /XXX unit name should not have leading "0x" and Warning (unit_address_format): Node /XXX unit name should not have leading 0s Converted using the following command: find . -type f \( -iname *.dts -o -iname *.dtsi \) -exec sed -i -e "s/@\([0-9a-fA-FxX\.;:#]+\)\s*{/@\L\1 {/g" -e "s/@0x\(.*\) {/@\1 {/g" -e "s/@0+\(.*\) {/@\1 {/g" {} +^C For simplicity, two sed expressions were used to solve each warnings separately. To make the regex expression more robust a few other issues were resolved, namely setting unit-address to lower case, and adding a whitespace before the the opening curly brace: https://elinux.org/Device_Tree_Linux#Linux_conventions This will solve as a side effect warning: Warning (simple_bus_reg): Node /XXX@<UPPER> simple-bus unit address format error, expected "<lower>" This is a follow up to commit 4c9847b7375a ("dt-bindings: Remove leading 0x from bindings notation") Reported-by: David Daney <ddaney@caviumnetworks.com> Suggested-by: Rob Herring <robh@kernel.org> Signed-off-by: Mathieu Malaterre <malat@debian.org> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2018-02-22ARM: dts: bcm283x: Fix probing of bcm2835-i2sStefan Wahren
Since 517e7a1537a ("ASoC: bcm2835: move to use the clock framework") the bcm2835-i2s requires a clock as DT property. Unfortunately the necessary DT change has never been applied. While we are at it also fix the first PCM register range to cover the PCM_GRAY register. Fixes: 517e7a1537a ("ASoC: bcm2835: move to use the clock framework") Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Eric Anholt <eric@anholt.net> Tested-by: Matthias Reichl <hias@horus.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2018-02-22ARM: dts: bcm283x: Fix pin function of JTAG pinsHenry Zhang
BCM2835 ARM Peripherals doc shows gpio pins 4, 5, 6, 12 and 13 carry altenate function, ALT5 for ARM JTAG Fixes: 21ff843931b2 ("ARM: dts: bcm283x: Define standard pinctrl groups in the gpio node.") Signed-off-by: Henry Zhang <henryzhang62@gmail.com> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2018-01-04dt-bindings/bcm283x: Define polarity of per-cpu interruptsStefan Wahren
This patch define the polarity of the per-cpu interrupts on BCM2836 and BCM2837 in order to avoid the warnings from ARM arch timer code: arch_timer: WARNING: Invalid trigger for IRQ19, assuming level low arch_timer: WARNING: Please fix your firmware arch_timer: cp15 timer(s) running at 19.20MHz (virt). Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2017-11-15ARM: dts: bcm283x: Fix DTC warnings about missing phy-cellsStefan Wahren
This patch fixes the DTC warnings about missing property #phy-cells. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-10-06ARM: dts: bcm283x: Fix console path on RPi3Loic Poulain
Contrary to other RPi devices, RPi3 uses uart0 to communicate with the BCM43438 bluetooth controller. uart1 is then used for the console. Today, the console configuration is inherited from the bcm283x dtsi (bootargs) which is not the correct one for the RPi3. This leads to routing issue and confuses the Bluetooth controller with unexpected data. This patch introduces chosen/stdout path to configure console to uart0 on bcm283x family and overwrite it to uart1 in the RPi3 dts. Create serial0/1 aliases referring to uart0 and uart1 paths. Remove unneeded earlyprintk. Fixes: 4188ea2aeb6d ("ARM: bcm283x: Define UART pinmuxing on board level") Signed-off-by: Loic Poulain <loic.poulain@gmail.com> Tested-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-07-04Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM device-tree updates from Arnd Bergmann: "Device-tree continues to see lots of updates. The majority of patches here are smaller changes for new hardware on existing platforms, and there are a few larger changes worth pointing out. New machines: - The new Action Semi S500 platform is added along with initial support for the LeMaker Guitar board. - STM32 gains support for three new boards: stm32h743-disco, stm32f746-disco, and stm32f769-disco, along with new device support for the existing stm32f429 boards. - Renesas adds two new boards, the tiny GR-Peach based on RZ/A1H with 10MB on-chip SRAM, and the iWave G20D-Q7 System-on-Module plus board. - On Marvell "mvebu", we gain support for the Linksys WRT3200ACM wireless router. - For NXP i.MX, we gain support for the Gateworks Ventana GW5600 and the Technexion Pico i.MX7D single-board computers. - The BeagleBone Blue is added for OMAP, it's the latest variation of the popular Beaglebone Black single-board computer. - The Allwinner based Lichee Pi Zero and NanoPi M1 Plus boards are added, these are the latest variations of a seemingly endless supply of similar single-board computers. Other updates: - Linus Walleij improves support for the "Faraday" based SoC platforms from various SoC makers (Moxart, Aspeed, Gemini) - The ARM Mali GPU is now describe on Rockchips SoCs - Mediatek MT7623 is extended significantly, making it much more useful. - Lots of individual updates on Renesas, OMAP, Rockchips, Broadcom, Allwinner, Qualcomm, iMX - For Amlogic, the clock support is extended a lot on meson8b. - We now build the devicetree file for the Raspberry Pi 3 on 32-bit ARM, in addition to the existing ARM64 support, to help users wanting to run a 32-bit system on it" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (345 commits) ARM: dts: socfpga: set the i2c frequency ARM: dts: socfpga: Add second ethernet alias to VINING FPGA ARM: dts: socfpga: Drop LED node from VINING FPGA ARM: dts: socfpga: Remove I2C EEPROMs from VINING FPGA ARM: dts: socfpga: Enable QSPI support on VINING FPGA ARM: dts: socfpga: Fix the ethernet clock phandle ARM: pxa: Use - instead of @ for DT OPP entries ARM: dts: owl-s500: Add SPS node ARM: dts: owl-s500: Set CPU enable-method dt-bindings: arm: cpus: Add S500 enable-method ARM: dts: Add Actions Semi S500 and LeMaker Guitar dt-bindings: arm: Document Actions Semi S900 dt-bindings: timer: Document Owl timer ARM: dts: imx6q-cm-fx6: add sdio wifi/bt nodes dt-bindings: arm: Document Actions Semi S500 dt-bindings: Add vendor prefix for Actions Semi ARM: dts: turris-omnia: Add generic compatible string for I2C EEPROM ARM: dts: mvebu: add support for Linksys WRT3200ACM (Rango) ARM: dts: armada-385-linksys: fixup button node names ARM: dts: armada-385-linksys: group pins in pinctrl ...
2017-06-12ARM: dts: bcm283x: Add generic USB PHYStefan Wahren
In order to use dwc2 in OTG or gadget mode the USB PHY should be specified. Since there is no bcm283x USB PHY driver use the generic one. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2017-05-19Merge tag 'bcm2835-dt-fixes-2017-05-16' into devicetree/fixesFlorian Fainelli
This pull request brings in a fix for booting on SMP Raspberry Pis, particularly with maxcpus=1 Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-05-15ARM: dts: bcm283x: Add CPU thermal zone with 1 trip pointStefan Wahren
As suggested by Eduardo Valentin this adds the thermal zone for the bcm2835 SoC with its single thermal sensor. We start with the criticial trip point and leave the cooling devices empty since we don't have any at the moment. Since the coefficients could vary depending on the SoC we need to define them separate. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Eduardo Valentin <edubezval@gmail.com>
2017-05-15ARM: dts: bcm283x: Reserve first page for firmwarePhil Elwell
The Raspberry Pi startup stub files for multi-core BCM283X processors make the secondary CPUs spin until the corresponding mailbox is written. These stubs are loaded at physical address 0x00000xxx (as seen by the ARMs), but this page will be reused by the kernel unless it is explicitly reserved, causing the waiting cores to execute random code. Use the /memreserve/ Device Tree directive to mark the first page as off-limits to the kernel. See: https://github.com/raspberrypi/linux/issues/1989 Signed-off-by: Phil Elwell <phil@raspberrypi.org> Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-03-27ARM: dts: bcm2835: fix uart0/uart1 pinsBaruch Siach
According to the BCM2835 ARM Peripherals document uart1 doesn't map to pins 36-39, but uart0 does. Also, split into separate Rx/Tx and CST/RTS groups to match other uart nodes. Fixes: 21ff843931b ("ARM: dts: bcm283x: Define standard pinctrl groups in the gpio node.") Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-03-27ARM: dts: bcm2835: fix i2c0 pinsBaruch Siach
According to the BCM2835 ARM Peripherals document i2c0 doesn't map to pins 32, 34 but to 28, 29. Fixes: 21ff843931b ("ARM: dts: bcm283x: Define standard pinctrl groups in the gpio node.") Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-03-27ARM: dts: bcm2835: fix uart0 pinctrl node namesBaruch Siach
Downstream kernel uses pins 32, 33 as UART0 (PL011) Rx/Tx to communicate with the Bluetooth chip. So ALT3 of these pins is most likely not CTS/RTS. Change the node name to reflect that. This matches section 6.2 "Alternative Function Assignments" in the BCM2835 ARM Peripherals document. With this change in place, adding &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_gpio32 &gpclk2_gpio43>; status = "okay"; }; to bcm2837-rpi-3-b.dts does the right thing on my Raspberry Pi 3. Pins 30, 31 are CTS/RTS of UART0 in alternate function 3. Rename uart0_gpio30 as well. While at it, fix a little typo in a nearby comment. Fixes: 21ff843931b ("ARM: dts: bcm283x: Define standard pinctrl groups in the gpio node.") Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Eric Anholt <eric@anholt.net>
2017-03-17ARM: dts: bcm2835: add sdhost controller to devicetreeGerd Hoffmann
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Acked-by: Eric Anholt <eric@anholt.net> Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
2017-03-16ARM: dts: bcm283x: Add HDMI audio related propertiesBoris Brezillon
Add the dmas and dma-names properties to support HDMI audio. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2017-03-06ARM: dts: bcm2835: Add the DSI module nodes and clocks.Eric Anholt
The modules stay disabled by default, and if you want to enable DSI you'll need an overlay that connects a panel to it. Signed-off-by: Eric Anholt <eric@anholt.net>
2017-01-18ARM: dts: bcm283x: Add VEC node in bcm283x.dtsiBoris Brezillon
Add the VEC (Video EnCoder) node definition in bcm283x.dtsi. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2016-11-11ARM: bcm2835: dts: add thermal node to device-tree of bcm283xMartin Sperl
Add the node for the thermal sensor of the bcm2835-soc to the device tree. Signed-off-by: Martin Sperl <kernel@martin.sperl.org> Reviewed-by: Eric Anholt <eric@anholt.net> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Changelog: V1 -> V5: generic settings is shared in bcm283x.dtsi, but disabled moved the compatible string to the SOC specific dtsi for arm and arm64 V5 -> V6: fix remove 0x prefix from thermal@0x7e212000 Note: there is no arm/boot/dts/bcm2837.dtsi as of now, so the 32-bit rpi3 dt is not modified. Signed-off-by: Eric Anholt <eric@anholt.net>
2016-10-31ARM: dts: bcm283x: fix typo in mailbox addressStefan Wahren
The address of the mailbox node in the bcm283x.dtsi also has a typo. So fix it accordingly. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Andreas Färber <afaerber@suse.de> Fixes: 05b682b7a3b2 ("ARM: bcm2835: dt: Add the mailbox to the device tree") Signed-off-by: Eric Anholt <eric@anholt.net>
2016-10-17ARM: dts: bcm283x: Define standard pinctrl groups in the gpio node.Eric Anholt
The BCM2835-ARM-Peripherals.pdf documentation specifies what the function selects do for the pins, and there are a bunch of obvious groupings to be made. With these created, we'll be able to replace bcm2835-rpi.dtsi's main "set all of these pins to alt0" with references to specific groups we want enabled. Also add pinctrl groups for emmc and sdhost. Based on patches by Eric Anholt, with fixups by Gerd Hoffmann. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
2016-10-07Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "These are as usual a very large number of mostly boring updates to enable devices in existing machines, or to fix minor bugs. Notably, an ongoing treewide effort to fix warnings caused by an update to the device tree compiler. These are enabled with "make W=1" at the moment but can hopefully become the default once all issues have been addressed. No new SoC platform is added this time around (Armada 395 and Orion mv88f5181 are slight variations of existing ones), but a significant number of new dts files are added, which I list by platform: - Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets, Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite, Olimex A33-Olinuxino, and Nano Pi Neo single-board computers - ARM Realview: all supported machines (ported from board files) - Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and BCM958622hr reference boards for Northstar platform, Raspberry Pi Zero single-board computer - Marvell EBU: Netgear WNR854T router (ported from board file), Armada 395 SoC platform and GP board Armada 390 DB development board - NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x single-board computer, Technologic Systems TS-4900 and Engicam IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board - Qualcomm: LG Nexus 5 Phone - Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards - Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288 Reload platform - ST Microelectronics STi: B2260 (96boards) single-board computer - TI Davinci: OMAP-L138 LCDK Development kit - TI OMAP: beagleboard-x15 rev B1 single-board computer" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits) ARM: dts: sony-nsz-gs7: add missing unit name to /memory node ARM: dts: chromecast: add missing unit name to /memory node ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node ARM: dts: berlin2: Add missing unit name to /soc node ARM: dts: berlin2cd: Add missing unit name to /soc node ARM: dts: berlin2q: Add missing unit name to /soc node ARM: dts: berlin2: Remove skeleton.dtsi inclusion ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion ARM: dts: berlin2q: Remove skeleton.dtsi inclusion arm: dts: berlin2q: enable all wdt nodes unconditionally arm: dts: berlin2: enable all wdt nodes unconditionally ARM: dts: omap5-igep0050.dts: Use tabs for indentation ARM: dts: Fix igepv5 power button GPIO direction ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node ARM: dts: s3c64xx: Use macros for pinctrl configuration ARM: dts: s3c2416: Use macros for pinctrl configuration ARM: dts: s5pv210: Use macros for pinctrl configuration ARM: dts: s3c64xx: Use common macros for pinctrl configuration ...
2016-09-09ARM: dts: Remove use of skeleton.dtsi from bcm283x.dtsiIan Campbell
This file is included from DTS files under arch/arm64 too (via broadcom/bcm2837-rpi-3-b.dts and broadcom/bcm2837.dtsi). There is a desire not to have skeleton.dtsi for ARM64. See commit 3ebee5a2e141 ("arm64: dts: kill skeleton.dtsi") for rationale for its removal. As well as the addition of #*-cells also requires adding the device_type to the rpi memory node explicitly. Note that this change results in the removal of an empty /aliases node from bcm2835-rpi-a.dtb and bcm2835-rpi-a-plus.dtb. I have no hardware to check if this is a problem or not. It also results in some reordering of the nodes in the DTBs (the /aliases and /memory nodes come later). This isn't supposed to matter but, again, I've no hardware to check if it is true in this particular case. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Stefan Wahren <stefan.wahren@i2se.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Frank Rowand <frowand.list@gmail.com> Cc: Eric Anholt <eric@anholt.net> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Lee Jones <lee@kernel.org> Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: devicetree@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-rpi-kernel@lists.infradead.org Cc: arm@kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-08-24ARM: dts: bcm283x: Add missing USB clockStefan Wahren
According to the DWC2 binding an appropriate clock is required. This clock isn't handled by bcm2835 clock driver, so add a fixed clock to the bcm283x DT. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2016-05-31ARM: bcm2835: dt: Add the ethernet to the device treesLubomir Rintel
The hub and the ethernet in its port 1 are hardwired on the board. Compared to the adapters that can be plugged into the USB ports, this one has no serial EEPROM to store its MAC. Nevertheless, the Raspberry Pi has the MAC address for this adapter in its ROM, accessible from its firmware. U-Boot can read out the address and set the local-mac-address property of the node with "ethernet" alias. Let's add the node so that U-Boot can do its business. Model B rev2 and Model B+ entries were verified by me, the hierarchy and pid/vid pair for the Version 2 was provided by Peter Chen. Original Model B is a blind shot, though very likely correct. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2016-05-19Merge tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time round the update brings in following changes: - new tegra driver for ADMA device - support for Xilinx AXI Direct Memory Access Engine and Xilinx AXI Central Direct Memory Access Engine and few updates to this driver - new cyclic capability to sun6i and few updates - slave-sg support in bcm2835 - updates to many drivers like designware, hsu, mv_xor, pxa, edma, qcom_hidma & bam" * tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (84 commits) dmaengine: ioatdma: disable relaxed ordering for ioatdma dmaengine: of_dma: approximate an average distribution dmaengine: core: Use IS_ENABLED() instead of checking for built-in or module dmaengine: edma: Re-evaluate errors when ccerr is triggered w/o error event dmaengine: qcom_hidma: add support for object hierarchy dmaengine: qcom_hidma: add debugfs hooks dmaengine: qcom_hidma: implement lower level hardware interface dmaengine: vdma: Add clock support Documentation: DT: vdma: Add clock support for dmas dmaengine: vdma: Add config structure to differentiate dmas MAINTAINERS: Update Tegra DMA maintainers dmaengine: tegra-adma: Add support for Tegra210 ADMA Documentation: DT: Add binding documentation for NVIDIA ADMA dmaengine: vdma: Add Support for Xilinx AXI Central Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI CDMA dmaengine: vdma: Add Support for Xilinx AXI Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI DMA dmaengine: vdma: Rename xilinx_vdma_ prefix to xilinx_dma dmaengine: slave means at least one of DMA_SLAVE, DMA_CYCLIC dmaengine: mv_xor: Allow selecting mv_xor for mvebu only compatible SoC ...
2016-04-19ARM: bcm2835: Add VC4 to the device tree.Eric Anholt
VC4 is the GPU (display and 3D) present on the 283x. Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2016-04-19ARM: bcm2835: add interrupt-names and apply correct mappingMartin Sperl
Add interrupt-names properties to dt and apply the correct mapping between irq and dma channels. Signed-off-by: Martin Sperl <kernel@martin.sperl.org> Acked-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Eric Anholt <eric@anholt.net> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-02-17ARM: bcm2835: add bcm2835-aux-uart support to DTMartin Sperl
Add bcm2835-aux-uart support to the device tree. Signed-off-by: Martin Sperl <kernel@martin.sperl.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2016-02-02ARM: bcm2835: Add the Raspberry Pi power domain driver to the DT.Alexander Aring
This connects the USB driver to the USB power domain, so that USB can actually be turned on at boot if the bootloader didn't do it for us. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Kevin Hilman <khilman@linaro.org>
2016-02-02ARM: bcm2835: follow dt uart node-naming conventionMartin Sperl
This patch fixes the naming of the device tree node: uart@7e201000 to conform to the standard of: serial@7e201000 Signed-off-by: Martin Sperl <kernel@martin.sperl.org> [anholt: Rebased on 2835.dtsi -> 283x.dtsi change] Signed-off-by: Eric Anholt <eric@anholt.net>
2016-02-02ARM: bcm2835: Add PWM clock support to the device treeRemi Pommarel
Signed-off-by: Remi Pommarel <repk@triplefau.lt> [anholt: Rebased on 2835.dtsi -> 283x.dtsi change] Signed-off-by: Eric Anholt <eric@anholt.net>
2016-02-02ARM: bcm2835: add the auxiliary spi1 and spi2 to the device treeMartin Sperl
This enables the use of the auxiliary spi1 and spi2 devices on the bcm2835 SOC. Note that this requires the use of the new clk-bcm2835-aux to work. Signed-off-by: Martin Sperl <kernel@martin.sperl.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org> [anholt: Rebased on 2835.dtsi -> 283x.dtsi change] Signed-off-by: Eric Anholt <eric@anholt.net>
2015-12-31ARM: bcm2835: Add the auxiliary clocks to the device tree.Eric Anholt
These will be used for enabling UART1, SPI1, and SPI2. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-31ARM: bcm2835: Split the DT for peripherals from the DT for the CPUEric Anholt
The set of peripherals remained constant across bcm2835 (Raspberry Pi 1) and bcm2836 (Raspberry Pi 2), but the CPU was swapped out. Split the files so that we can include just peripheral setup in 2836. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
