path: root/arch/arm/boot/dts/bcm4709-asus-rt-ac87u.dts
2015-09-14ARM: BCM5301X: add NAND flash chip description for Asus RT-AC87UHauke Mehrtens
The NAND flash chip description were not imported for the Asus RT-AC87U dts file when this was done for all the other dts files, because these patches were send in parallel. This adds a missing NAND flash chip description to this patch: commit 9faa5960eef3204cae6637b530f5e23e53b5a9ef Author: Hauke Mehrtens <hauke@hauke-m.de> Date: Fri May 29 23:39:47 2015 +0200 ARM: BCM5301X: add NAND flash chip description Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-06-06ARM: BCM5301X: Add DT for Asus RT-AC87URafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
