This uses trigger-sources documented in commit 80dc6e1cd85fc ("dt-bindings:
leds: document new trigger-sources property") to specify USB ports. Such an
information can be used by operating system to setup LEDs behavior.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
This adds baud rate, parity & number of data bits. It's required to get
serial working correctly.
Tenda AC9 has PCIe controller with just one device connected to it:
0000:00:00.0 14e4:d145 Bridge Device
└─ 0000:01:00.0 14e4:a8db Network Controller
This card is directly on SoC (doesn't use physical connector) and has
BCM43217 chipset with bcma bus. One of its components is ChipCommon core
which is also a GPIO controller. We need to describe it to be able to
add devices using its GPIO pins.
Broadcom OHCI and EHCI controllers always have 2 ports each on the root
hub. Describe them in DT to allow specifying extra info or referencing
port nodes.
ILP clock (sometimes called a "slow clock") is a part of PMU (Power
Management Unit). There has been recently added a driver for it, so add
a proper entry in the DT as well.
BCM53573 seems to be low priced alternative for Northstar chipsts. It
uses single core Cortex-A7 and doesn't have SDU or local (TWD) timer. It
was also stripped out of independent SPI controller and 2 GMACs.
DTS for Tenda AC9 isn't completed yet. It misses e.g. switch entry (we
still need some b53 fixes) and probably some clocks. It adds support for
basic features however and can be improved later.
