[ Upstream commit c25748acc5c20786ecb7518bfeae8fcef93472d6 ]
To avoid the following error:
asoc-simple-card sound: ASoC: Failed to create card debugfs directory
Which is because the card name contains '/' character, which can not be
used in file or directory names.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Drop the unused endpoints. They should only be used when there is an
actual remote-endpoint connected.
Cc: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Enable the SATA node for da850-lcdk. We omit the pinctrl property on
purpose - the muxed SATA pins are not hooked up to anything
SATA-related on the lcdk.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Enable VPIF for video captpure and configure input channel 0, used for
composite input.
Enable the usb1 controller (ohci) and phy for the lcdk board
Signed-off-by: Axel Haslam <ahaslam@baylibre.com>
Add the vga-bridge node to the board DT together with corresponding
ports and vga connector. This allows to retrieve the edid info from
the display automatically.
Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add a gpio-keys node for two user buttons present on the board.
Currently the memory controller and master priorities drivers are
enabled in da850.dtsi. For boards for which there are no settings
defined, this makes these drivers emit error messages.
Disable the nodes in da850.dtsi and only enable them for da850-lcdk -
the only board that currently needs them.
In order to avoid Linux generating a random mac address on every boot,
add an ethernet0 alias that will allow u-boot to patch the dtb with
the MAC address programmed into the EEPROM.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
The polarity of the card detect pin is inverted.
Change it to reflect the right polarity for the board
which is ACTIVE_LOW.
This enables the usb otg controller for the lcdk board.
Signed-off-by: Alexandre Bailon <abailon@baylibre.com>
This adds DT support for the NAND connected to the SoC AEMIF.
Passed torture hashing a 40MB file on top of UBIFS using subpages.
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
[khilman: add back default partitions from an earlier patch]
The LCDK embeds a TLV320AIC3106 connected to the SoC McASP for analog
audio. The power supply of the codec comes from the main PMIC
(TPS650250) DCDCs which are always on per HW design and not
controllable by SW, so SW wise the codec driver will rely on the 'dummy'
regulator.
Quality is good with arecord -pipe- aplay on Line In/Line Out.
Tested-by: Kevin Hilman <khilman@baylibre.com>
The LCDK is the successor to the late Hawkboard.
Among the differences are the flash (16bits vs 8bits) and some pins
(MMC, LEDs, buttons, some external connectors), however the main
components remain the same (eth. phy, audio codec, video decoder and
DAC) except for the main PMIC, different and hard-wired on the LCDK (the
LDOs and DCDCs are always on).
A DT-only boot with this addition gives functional UART, reboot via
watchdog, RTC, ethernet and MMC (I added the CD GPIO for the MMC
although davinci_mmc doesn't call the OF facilities of mmc core).
