[ Upstream commit f62280efe8934a1275fd148ef302d1afec8cd3df ]
When using 8250_omap driver, we need to specify the right
compatible value for the UART to work on dm814x and dm816x.
Add the missing SPI controller DMA handler in the dm816x DT
node, only properties for the two channels on four were present.
Cc: Brian Hutchinson <b.hutchman@gmail.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Add missing #mbox-cells for dm816x mbox DT node.
The interconnects on dm816x are like on omap4, so we should use
l3-noc instead of l3-smx. But as the related SoC specific
l3_target_data is still missing from omap_l3_noc let's just
remove the entry for now.
Reported-by: Matthijs van Duin <matthijsvanduin@gmail.com>
With commit 3e457371f436 ("usb: musb: Fix fifo reads for dm816x with
musb_dsps") we need to use the right compatible flag to avoid issues
with FIFO reads.
Cc: Bin Liu <binmlist@gmail.com>
Cc: George Cherian <george.cherian@ti.com>
Fixes: 3e457371f436 ("usb: musb: Fix fifo reads for dm816x with musb_dsps")
Acked-by: Felipe Balbi <balbi@ti.com>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
Looks like we have cppi41 on dm816x just like on am335x.
Cc: Felipe Balbi <balbi@ti.com>
Cc: Matthijs van Duin <matthijsvanduin@gmail.com>
Commit 7800064ba507 ("ARM: dts: Add basic dm816x device tree
configuration") added basic devices for dm816x, but I was not able
to test the GPIO interrupts earlier until I found some suitable pins
to test with. We can mux the MMC card detect and write protect pins
from SD_SDCD and SD_SDWP mode to use a normal GPIO interrupts that
are also suitable for the MMC subsystem.
This turned out several issues that need to be fixed:
- I set the GPIO type wrong to be compatible with omap3 instead
of omap4. The GPIO controller on dm816x has EOI interrupt
register like omap4 and am335x.
- I got the GPIO interrupt numbers wrong as each bank has two
and we only use one. They need to be set up the same way as
on am335x.
- The gpio banks are missing interrupt controller related
properties.
With these changes the GPIO interrupts can be used with the
MMC card detect pin, so let's wire that up. Let's also mux all
the MMC lines for completeness while at it.
For the first GPIO bank I tested using GPMC lines temporarily
muxed to GPIOs on the dip switch 10.
to test the USB completely because of an unconfigured USB phy, and
I only tested it to make sure the Mentor chips are detected and
clocked without a phy.
After testing the USB with actual devices I noticed a few issues
that should be fixed to avoid confusion:
- The USB id pin on dm8168-evm is hardwired and can be changed
only by software. As there are two USB-A type connectors, let's
start both in host mode instead of otg.
- The Mentor core is configured in such a way on dm8168-evm that
it's not capable of multipoint at least on revision c board
that I have.
- We need ranges for the syscon to properly set up the phy as
children of the SCM syscon area.
- Let's not disable the second interface, the board specific
dts files can do that if really needed. Most boards should
just keep it enabled to ensure the device is idled properly.
Note that also a phy and several musb fixes are still needed to
make the USB to work properly in addition to this fix.
Looks like I only got half done with moving pinctrl and syscon to
be children of the SCM. I've set up the FAPLL clocks that way already,
but did not complete the job as I copied the syscon values from
am33xx.dtsi.
To make sure the syscon mapping works, I've verfified that we can
set up davinci_emac mac address the same way as cpsw already does
with the syscon mapping. So let's add that too.
The clocks on dm816x are a bit different from the other omap
variants. The clocks are sourced from a FAPLL (Flying Adder PLL)
unlike on other omaps. Other than that, it's a similar setup
to am33xx with extra muxes and dividers that can be defined
as existing component clocks.
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
Similar to other omap variants, let's add dm816x support.
Note that this is based on generated data from the
TI81XX-LINUX-PSP-04.04.00.02 patches published at:
http://downloads.ti.com/dsps/dsps_public_sw/psp/LinuxPSP/TI81XX_04_04/04_04_00_02/index_FDS.html
I've verified the basic functionality, but have not been
able to test all the devices on dm8168-evm.
