path: root/arch/arm/boot/dts/emev2-kzm9d.dts
2015-10-22ARM: dts: fix gpio-keys wakeup-source propertySudeep Holla
The keyboard driver for GPIO buttons(gpio-keys) checks for one of the two boolean properties to enable gpio buttons as wakeup source: 1. "wakeup-source" or 2. the legacy "gpio-key,wakeup" However juno, ste-snowball and emev2-kzm9d dts file have a undetected "wakeup" property to indictate the wakeup source. This patch fixes it by making use of "wakeup-source" property. Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Simon Horman <horms@verge.net.au> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-15ARM: shmobile: emev2: kzm9d: enable IIC bussesWolfram Sang
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-05-11ARM: shmobile: kzm9d dts: Use generic names for device nodesGeert Uytterhoeven
lan9220 -> ethernet uart -> serial Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-02-24ARM: shmobile: emev2-kzm9d dts: Add PFC information for uart1Niklas Söderlund
Configure the pinmux on kzm9d to use the serial connector for uart1. Signed-off-by: Niklas Söderlund <niso@kth.se> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-10-24ARM: shmobile: kzm9d dts: Add chosen/stdout-pathGeert Uytterhoeven
Add a stdout-path property so that automatic console selection works in the absence of a "console=" parameter on the kernel command line. Note that we have to keep the "console=ttyS1,115200n81" parameter in chosen/bootargs, else the console will use the default setting of 9600 baud. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-10-24ARM: shmobile: kzm9d: sort dts file by addressUlrich Hecht
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-12-10ARM: shmobile: emev2: Use interrupt macros in DT filesLaurent Pinchart
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-12-10ARM: shmobile: Enable DSW2 with gpio-keys on KZM9DMagnus Damm
Use the gpio-keys driver to support the 4 pins on the dip switch DSW2 which is mounted on the KZM9D board. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-10-08ARM: shmobile: Sync KZM9D DTS with KZM9D reference DTSMagnus Damm
Copy the device nodes from KZM9D reference into the KZM9D device tree file. This will allow us to use a single DTS file regarless of kernel configuration. In case of legacy C board code the device nodes may or may not be used, but in the multiplatform case all the DT device nodes are used. Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-08-06ARM: shmobile: kzm9d: remove nfsroot settings from bootargsKuninori Morimoto
NFS detail settings like "nfsroot=,rsize=4096,wsize=4096" are no longer needed Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-07-17ARM: shmobile: Update KZM9D dts command lineMagnus Damm
Update the KZM9D DTS command line to remove following cruft: - console=tty0 - no graphic support upstream anyway - earlyprintk= - not supported by the 8250-em driver anyway - mem= - this is provided via DT anyway Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-01-15ARM: mach-shmobile: kzm9d: update defconfigSimon Horman
* Do not disable SUSPEND Suspend seems to work fine on the kzm9d. This is part of an effort reduce differences between mach-shmobile defconfigs with a view to using a common defconfig. * Enable PM_RUNTIME This also seems to work fine on the kzm9d. This is part of an effort reduce differences between mach-shmobile defconfigs with a view to using a common defconfig. * Move kernel command line from defconfig to dts. This brings us one small step closer to sharing defconfig between kzm9d and other boards. Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2012-05-18mach-shmobile: Use DT_MACHINE for KZM9D V3Magnus Damm
Use DT_MACHINE_START() on the emev2 based KZM9D board. Also include a tiny DTS file to describe the board and update the Kconfig dependencies to select CONFIG_USE_OF. Update the SMP glue code to use OF for matching. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
