Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
Remove leading zeros in OHCI node for at91sam9260 based boards.
Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com>
Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org>
The ethernut5 is actually based on an at91sam9xe, use the correct dts include.
Cc: Martin Reimann <martin.reimann@egnite.de>
Cc: Tim Schendekehl <tim.schendekehl@egnite.de>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Define egnite Ethernut 5 main and slow crystals frequencies.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
to prepare the switch to the macro.
Add support for the Ethernut 5 open hardware design, based
on Atmel's AT91SAM9XE512 SoC.
Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
