This patch adds stdout-path property to chosen nodes of Exynos4 boards
to enable use of earlycon feature without the need to hardcode port
number in kernel itself.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
This patch replaces the "cs-gpio" from "controller-data" node
as was specified in the old binding and uses the standard
"cs-gpios" property expected by the SPI core as is defined now
in the spi-s3c64xx driver DT binding.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Add generic compatible strings to the respective board DT files.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Add default pin state information for all client nodes that require
pin configuration support using pinctrl interface.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Added G2D DT node to SMDKV310 board.
The clock frequency of xxti and xusbxti clocks is dependent on the
frequency of the on-board oscillator that is used to generate these
clocks. So allow the frequency of these clocks to be specfied from
device tree.
This patch adds status override of serial nodes to enable used
serial ports on Origen and SMDKV310 board.
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Currently all boards must explicitly disable all unused device tree
nodes of unused components (e.g. i2c, sdhci, etc...). This makes it
necessary to all boards to be aware of all components on the SoC, which
in turns makes board dts files longer and more difficult to maintain
(e.g. adding new components to SoC-level tree requires adding nodes with
status="disabled" to every board).
This patch changes "status" of all optional components in SoC-level dts
file to "disabled", adds status="okay" to respective nodes of used
components in dts of all boards and removes all nodes with only
status="disabled" from boards dts.
Acked-by: Thomas Abraham <thomas.abraham@linaro.org>
Add device nodes for the three instances of spi controllers in
EXYNOS4 platforms. Enable instance SPI 2 for SMDKV310 board and
disable all spi instances for Origen board.
Add initial dts file for EXYNOS4210 SoC. This dts file describes
the SoC specific devices and properties. Along with this, add dts
file for Samsung's SMDKV310 board and Insignal's ORIGEN board which
uses the EXYNOS4210 dts file and extends it to describe the board
specific properties.
