This patch adds entries for HDMI, Mixer and i2c with hdmi-phy modules
found in Exynos 4210 and 4x12 SoCs.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Presented device tree bindings provide data already hardcoded in the
exynos_tmu_data.c file.
After this commit, it should be possible to reuse common thermal core
framework in Exynos SoCs.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Presented patch aims to move data necessary for correct CPU cooling device
configuration from exynos_tmu_data.c to device tree.
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
This patch add PPMUs (Platform Performance Monitoring Unit) dt node
for Exynos4 (Exynos4210/4212/4412) SoCs. PPMU dt node is used for
monitor the utilization of each IP.
The Exynos4210/Exynos4212/Exynos4412 SoC includes following PPMUs:
- PPMU_DMC0 0x106A_0000
- PPMU_DMC1 0x106B_0000
- PPMU_CPU 0x106C_0000
- PPMU_ACP 0x10AE_0000
- PPMU_RIGHT_BUS 0x112A_0000
- PPMU_LEFT_BUS 0x116A_0000
- PPMU_FSYS 0x1263_0000
- PPMU_LCD0 0x11E4_0000
- PPMU_CAMIF 0x11AC_0000
- PPMU_IMAGE 0x12AA_0000
- PPMU_TV 0x12E4_0000
- PPMU_3D 0x1322_0000
- PPMU_MFC_LEFT 0x1366_0000
- PPMU_MFC_RIGHT 0x1367_0000
Additionally, the Exynos4210 SoC includes following PPMUs:
- PPMU_LCD1 0x1224_0000
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
This patch replaces all custom samsung,power-domain dt
properties with generic power domain bindings and updates
documentation Samsung's devices referring to old binding.
Suggested-by: Kevin Hilman <khilman@kernel.org>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
[javier.martinez@collabora.co.uk: tested on the Exynos5800 Peach Pi Chromebook]
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
This patch adds device tree nodes for L2 cache controller present on
Exynos4 SoCs.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Recent patch by Tomasz Figa ("irqchip: gic: Fix core ID calculation
when topology is read from DT") fixed GIC driver to filter cluster ID
from values returned by cpu_logical_map() for SoCs having registers
mapped without per-CPU banking making it is possible to add CPU nodes
for Exynos4 SoCs. In case of Exynos SoCs these CPU nodes are also
required by future changes adding initialization of cpuidle states in
Exynos cpuidle driver through DT.
Tested on Origen board (Exynos4210 SoC) and Trats2 (Exynos4412 SoC).
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
This patch extends nodes of PMU system controller on Exynos4210, 4x12,
5250 and 5420 SoCs with newly defined properties used by Exynos CLKOUT
driver.
This patch cleans a arm-pmu node up for exynos4. Only exynos4412 series
boards have four pmu interrupts. Rest of exynos4 boards, except 4412, have only
two pmu interrupts. Thus, we can define two interrupts in the
exynos4.dtsi and extends the interrupts only exynos4412.dtsi.
Cc: Chanwoo Choi <cw00.choi@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
Tested-by: Tushar Behera <tushar.behera@linaro.org>
Instead of hardcoding the SYSRAM details for each SoC,
pass this information through device tree (DT) and make
the code SoC agnostic. Generic DT SRAM bindings are
used for achieving this.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Add generic compatible strings to the respective board DT files.
The patch replaces magic numbers with macros defined in DT header
in exynos4 clock bindings.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
For consistency with other device tree nodes, this patch adds missing
spaces after node labels.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
There is no need to use two cells for interrupt specifiers inside the
MCT interrupt map, so this patch simplifies the map to use one cell.
MCT is not an interrupt controller and so there is no point for device
tree nodes representing it to contain interrupt-controller
and #interrupt-cells properties.
"Device tree and bindings updates for 3.12.
General additions of various on-chip and on-board peripherals on
various platforms as support gets added. Some of the bigger changes
are:
- Addition of (new) PCI-e support on Tegra.
- More Tegra4 support, including PMC configuration for Dalmore.
- Addition of a new board for Exynos4 (trats2) and more bindings for
4x12 IP.
- Addition of Allwinner A20 and A31 SoC and board files.
- Move of the ST Ericsson device tree files to now use ste-* prefix.
- More move of hardware description of shmobile platforms to DT.
- Two new board dts files for Freescale MXs"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits)
dts: Rename DW APB timer compatible strings
dts: Deprecate ALTR as a vendor prefix
of: add vendor prefix for Altera Corp.
ARM: at91/dt: sam9x5ek: add sound configuration
ARM: at91/dt: sam9x5ek: enable SSC
ARM: at91/dt: sam9x5ek: add WM8731 codec
ARM: at91/dt: sam9x5: add SSC DMA parameters
ARM: at91/dt: add at91rm9200 PQFP package version
ARM: at91: at91rm9200: set default mmc0 pinctrl-names
ARM: at91: at91sam9n12: correct pin number of gpio-key
ARM: at91: at91sam9n12: add qt1070 support
ARM: at91: at91sam9n12: add pinctrl of TWI
ARM: at91: Add PMU support for sama5d3
ARM: at91: at91sam9260: add missing pinctrl-names on mmc
ARM: tegra: configure power off for Dalmore
ARM: DT: binding fixup to align with vendor-prefixes.txt (DT)
ARM: dts: add sdio blocks to bcm28155-ap board
ARM: dts: align sdio numbers to HW definition
ARM: sun7i: Add Olimex A20-Olinuxino-Micro support
ARM: sun7i: Add Allwinner A20 DTSI
Add common camera node and detailed properties for
the Exynos4210 FIMC devices.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
... for the sake of consistency and assumed convention.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Added clock entries to G2D node.
Adds TMU clock entries to exynos4210.dtsi file.
Pull late ARM Exynos multiplatform changes from Arnd Bergmann:
"These continue the multiplatform support for exynos, adding support
for building most of the essential drivers (clocksource, clk, irqchip)
when combined with other platforms. As a result, it should become
really easy to add full multiplatform exynos support in 3.11, although
we don't yet enable it for 3.10.
The changes were not included in the earlier multiplatform series in
order to avoid clashes with the other Exynos updates.
This also includes work from Tomasz Figa to fix the pwm clocksource
code on Exynos, which is not strictly required for multiplatform, but
related to the other patches in this set and needed as a bug fix for
at least one board."
* tag 'multiplatform-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (22 commits)
ARM: dts: exynops4210: really add universal_c210 dts
ARM: dts: exynos4210: Add basic dts file for universal_c210 board
ARM: dts: exynos4: Add node for PWM device
ARM: SAMSUNG: Do not register legacy timer interrupts on Exynos
clocksource: samsung_pwm_timer: Work around rounding errors in clockevents core
clocksource: samsung_pwm_timer: Correct programming of clock events
clocksource: samsung_pwm_timer: Use proper clockevents max_delta
clocksource: samsung_pwm_timer: Add support for non-DT platforms
clocksource: samsung_pwm_timer: Drop unused samsung_pwm struct
clocksource: samsung_pwm_timer: Keep all driver data in a structure
clocksource: samsung_pwm_timer: Make PWM spinlock global
clocksource: samsung_pwm_timer: Let platforms select the driver
Documentation: Add device tree bindings for Samsung PWM timers
clocksource: add samsung pwm timer driver
irqchip: exynos: look up irq using irq_find_mapping
irqchip: exynos: pass irq_base from platform
irqchip: exynos: localize irq lookup for ATAGS
irqchip: exynos: allocate combiner_data dynamically
irqchip: exynos: pass max combiner number to combiner_init
ARM: exynos: add missing properties for combiner IRQs
Pull ARM SoC device tree updates (part 2) from Arnd Bergmann:
"These are mostly new device tree bindings for existing drivers, as
well as changes to the device tree source files to add support for
those devices, and a couple of new boards, most notably Samsung's
Exynos5 based Chromebook.
The changes depend on earlier platform specific updates and touch the
usual platforms: omap, exynos, tegra, mxs, mvebu and davinci."
* tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits)
ARM: exynos: dts: cros5250: add EC device
ARM: dts: Add sbs-battery for exynos5250-snow
ARM: dts: Add i2c-arbitrator bus for exynos5250-snow
ARM: dts: add mshc controller node for Exynos4x12 SoCs
ARM: dts: Add chip-id controller node on Exynos4/5 SoC
ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
ARM: davinci: da850-evm: add SPI flash support
ARM: davinci: da850: override SPI DT node device name
ARM: davinci: da850: add SPI1 DT node
spi/davinci: add DT binding documentation
spi/davinci: no wildcards in DT compatible property
ARM: dts: mvebu: Convert mvebu device tree files to 64 bits
ARM: dts: mvebu: introduce internal-regs node
ARM: dts: mvebu: Convert all the mvebu files to use the range property
ARM: dts: mvebu: move all peripherals inside soc
ARM: dts: mvebu: fix cpus section indentation
ARM: davinci: da850: add EHRPWM & ECAP DT node
ARM/dts: OMAP3: fix pinctrl-single configuration
ARM: dts: Add OMAP3430 SDP NOR flash memory binding
ARM: dts: Add NOR flash bindings for OMAP2420 H4
The exynos combiner irqchip needs to find the parent interrupts
and needs to know their number, so add the missing properties
for exynos4 as they were already present for exynos5.
This patch adds a arm-pmu node to bind device tree for exynos4210.
The exynos4210 and 4212 have two cpus which includes a pmu. In contrast, the
exynos4412 has 4 cpus and pmus. We need to define two more pmus for this type
board. However, supporting arm-pmu for the exynos4412 will handle it later
because there is no dts support for 4412 based board.
Added G2D DT node to Exynos4210.
For all supported peripheral controllers on Exynos4 SoCs, add clock
lookup information.
Tested-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Tested-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Add clock controller nodes for EXYNOS4210, EXYNOS4x12, EXYNOS5250
and EXYNOS5440 SoCs.
Add MCT device tree node for Exynos4210, Exynos4212, Exynos4412
and Exynos5250.
Cc: Changhwan Youn <chaos.youn@samsung.com>
Fix the incorrect compatible property value of pinctrl for EXYNOS4 SoCs.
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
This patch adds device tree nodes for power domains available
on EXYNOS4 SoCs.
arch/arm/boot/dts/exynos4210.dtsi
This patch adds necessary source definations needed for TMU driver and
adds devicetree node for exynos4210.
Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com>
This patch reworks wake-up interrupt handling in pinctrl-exynos driver,
so each pin bank, which provides wake-up interrupts, has its own IRQ
domain.
Information about whether given pin bank provides wake-up interrupts,
how many and whether they are separate or muxed are parsed from device
tree.
It gives following advantages:
- interrupts can be specified in device tree in a more readable way,
e.g. :
device {
interrupt-parent = <&gpx2>;
interrupts = <4 0>;
- the amount and layout of interrupts is not hardcoded in the code
anymore, but defined in SoC-specific structure
- bank and pin of each wake-up interrupt can be easily identified, to
allow operations, such as setting the pin to EINT function, from
irq_set_type() callback
Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Thomas Abraham <thomas.abraham@linaro.org>
Instead of registering one IRQ domain for all pin banks of a pin
controller, this patch implements registration of per-bank domains.
At a cost of a little memory overhead (~2.5KiB for all GPIO interrupts
of Exynos4x12) it simplifies driver code and device tree sources,
because GPIO interrupts can be now specified per banks.
Example:
device {
interrupt-parent = <&gpa1>;
interrupts = <3 0>;
This patch is a preparation for converting the pinctrl-samsung driver to
one GPIO chip and IRQ domain per bank. It allows particular banks to be
specified using their phandles.
arch/arm/boot/dts/exynos4210-origen.dts
Most definitions from exynos4210.dtsi can be applied for other SoCs from
EXYNOS4 line as well, so move the common part into separate file that
can be included by dtsi files of other EXYNOS4 SoCs (as well as current
exynos4210.dtsi).
[kgene.kim@samsung.com: Dongjin Kim <dongjin.kim@agreeyamobility.net>
submitted a similar patch 'Add DTS files derived from common EXYNOS4'
before this but I picked this up because of included exynos4x12 stuff]
Add pinctrl driver nodes for the three instances of pin controllers
in SAMSUNG EXYNOS4210 SoC and add the pin group nodes available in the
each of those three instances.
Bindings for DMA channels are still under discussion and will
change once this has been resolved. Therefore we mark them
the newly added ones as preliminary. Let's hope nobody starts
relying on them...
Add device nodes for the three instances of spi controllers in
EXYNOS4 platforms. Enable instance SPI 2 for SMDKV310 board and
disable all spi instances for Origen board.
Add node for EXYNOS4 interrupt combiner controller.
Commit db0d4db22a78 ('ARM: gic: allow GIC to support non-banked setups)
requires a cpu-offset property to be specified for non-banked gic
controllers, which is the case for Exynos4.
Reported-and-Tested-by: Karol Lewandowski <k.lewandowsk@samsung.com>
Add initial dts file for EXYNOS4210 SoC. This dts file describes
the SoC specific devices and properties. Along with this, add dts
file for Samsung's SMDKV310 board and Insignal's ORIGEN board which
uses the EXYNOS4210 dts file and extends it to describe the board
specific properties.
