path: root/arch/arm/boot/dts/exynos5250-snow.dts
2016-09-16ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250Krzysztof Kozlowski
Usage of DTS macros instead of hard-coded numbers makes code easier to read. One does not have to remember which value means pull-up/down or specific driver strength. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-30ARM: dts: Add Exynos5250 Snow Rev5+ support on exynos5250-snow-rev5Javier Martinez Canillas
There are 2 revisions of the Exynos5250 Snow Chromebook that were shipped: Rev4 and Rev5. The only difference between these 2 revisions is the codec, Rev4 has a max98095 codec while Rev5 has a max98090. Mainline only supports Rev4 so this patch moves the common device nodes to a DTSI file and adds a DTS for the Exynos5250 Snow Rev5. The Snow Rev5 DTS is based on the DTS found in the ChromiumOS 3.8 tree. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Tested-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Reviewed-by: Douglas Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-08-14ARM: dts: Add SPI CS on exynos5250-snowMichal Suchanek
Although there is only one choice of chipselect it is necessary to specify it. The driver cannot claim the gpio otherwise. Signed-off-by: Michal Suchanek <hramrach@gmail.com> Acked-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-08-14ARM: dts: add CPU OPP and regulator supply property for exynos5250Thomas Abraham
For Exynos5250 platforms, add CPU operating points and CPU regulator supply properties for migrating from Exynos specific cpufreq driver to using generic cpufreq driver. Cc: Doug Anderson <dianders@chromium.org> Cc: Andreas Faerber <afaerber@suse.de> Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> [b.zolnierkie: split Exynos5250 support from the original patch] [b.zolnierkie: added CPU regulator supply property for Spring boards] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Tested-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-06-03ARM: dts: Remove duplicated I2C7 nodes in exynos5250-snowKrzysztof Kozlowski
The i2c_7 node (i2c@12CD0000) with LVDS bridge child node was put in Exynos5250 Snow DTS file twice. Move the LVDS bridge to proper existing i2c_7 node. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-05-09ARM: dts: Add keep-power-in-suspend to WiFi SDIO node for exynos5250-snowJavier Martinez Canillas
The Marvell mwifiex driver prevents the system to enter into a suspend state if the card power is not preserved during a suspend/resume cycle. So Suspend-to-RAM and Suspend-to-idle are failing on Exynos5250 Snow. Add the keep-power-in-suspend Power Management property to the SDIO/MMC node so the mwifiex suspend handler doesn't fail and the system is able to enter into a suspend state. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-03-18ARM: dts: Define stdout-path property for exynos5250-snowJavier Martinez Canillas
The kernel can use as the default console a serial port if is defined as stdout device in the Device Tree. This allows a board to be booted without the need of having a console parameter in the kernel command line. Currently the Snow DTS has a bootargs in the /chosen node and this is kept since users that don't have a serial console on this board might be using it to have the boot log shown in the display. This will have more precedence than the stdout-path but it's fine since is only used when CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is enabled. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-02-27ARM: dts: represent bridge and panel connection for exynos5250-snowAjay Kumar
Define videoports and use endpoints to describe the connection between the encoder, bridge and the panel, instead of using phandles. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Acked-by: Inki Dae <inki.dae@samsung.com> Tested-by: Rahul Sharma <rahul.sharma@samsung.com> Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Tested-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Tested-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-02-27ARM: dts: Add cap-sdio-irq to wifi mmc node for exynos5250-snowJavier Martinez Canillas
Enabling SDIO IRQ signalling for the wifi MMC/SDIO slot doubles the transmission transfer rate. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-02-27ARM: dts: Enable wifi power-on for exynos5250-snowJavier Martinez Canillas
The Snow board has a MMC/SDIO wifi chip that is always powered but it needs a power sequence involving a reset (active low) and an enable (active high) pins. Both pins are marked as active low since the MMC simple power sequence driver asserts the pins prior to the card power up procedure and de-asserts the pins after the card has been powered. So the reset line will be left de-asserted and the enable pin will be left asserted. The chip also needs an external 32kHz reference clock to be operational that is by the MAX77686 PMIC clock. Add a simple MMC power sequence provider for the wifi MMC/SDIO slot. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-01-15ARM: dts: Add power and lid GPIO keys pinctrl for exynos5250-snowJavier Martinez Canillas
The Exynos5250 Snow Chromebook has GPIO keys for power and lid so the SoC I/O pins have to be configured in external interrupt mode. Currently, this is working without setting the pinctrl lines but is better to set it explicitly instead of relying on the previous state of the I/O pins. The DTS snippets were taken from the downstream ChromeOS tree. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2014-12-09Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "The DT branch adds a lot of new stuff for additional SoC and board support. The branch is the largest one and contains 513 out of the total 972 non-merge arm-soc changesets for 3.19. Most of the changes are about enabling additional on-chip devices for existing machines, but there are also an unusual number of new SoC types being added this time: - AMLogic Meson8 - ARM Realview in DT mode - Allwinner A80 - Broadcom BCM47081 - Broadcom Cygnus - Freescale LS1021A - Freescale Vybrid 500 series - Mediatek MT6592, MT8127, MT8135 - STMicroelectronics STiH410 - Samsung Exynos4415 The level of support for the above differs widely, some are just stubs with nothing more than CPU, memory and a UART, but others are fairly complete. As usual, these get extended over time. There are also many new boards getting added, this is the list of model strings that are showing up in new dts files: - ARM RealView PB1176 - Altera SOCFPGA Arria 10 - Asus RT-N18U (BCM47081) - Buffalo WZR-1750DHP (BCM4708) - Buffalo WZR-600DHP2 (BCM47081) - Cygnus Enterprise Phone (BCM911360_ENTPHN) - D-Link DIR-665 - Google Spring - IGEP COM MODULE Rev. G (TI OMAP AM/DM37x) - IGEPv2 Rev. F (TI OMAP AM/DM37x) - LS1021A QDS Board - LS1021A TWR Board - LeMaker Banana Pi - MarsBoard RK3066 - MediaTek MT8127 Moose Board - MediaTek MT8135 evaluation board - Mele M3 - Merrii A80 Optimus Board - Netgear R6300 V2 (BCM4708) - Nomadik STN8815NHK - NovaTech OrionLXm - Olimex A20-OLinuXino-LIME2 - Raspberry Pi Model B+ - STiH410 B2120 - Samsung Monk board - Samsung Rinato board - Synology DS213j - Synology DS414 - TBS2910 Matrix ARM mini PC - TI AM5728 BeagleBoard-X15 - Toradex Colibri VF50 on Colibri Evaluation Board - Zynq ZYBO Development Board Other notable changes include: - exynos: cleanup of existing dts files - mvebu: improved pinctrl support for Armada 370/XP - nomadik: restructuring dts files - omap: added CAN bus support - shmobile: added clock support for some SoCs - shmobile: added sound support for some SoCs - sirf: reset controller support - sunxi: continuing the relicensing under dual GPL/MIT - sunxi: lots of new on-chip device support - sunxi: working simplefb support (long awaited) - various: provide stdout-path property for earlycon" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits) ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured Revert "ARM: dts: rockchip: temporarily disable smp on rk3288" ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2 ARM: BCM5301X: Add DT for Asus RT-N18U ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP ARM: BCM5301X: Add DT for Netgear R6300 V2 ARM: BCM5301X: Add buttons for Netgear R6250 ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file arm: dts: zynq: Add Digilent ZYBO board arm: dts: zynq: Move crystal freq. to board level doc: dt: vendor-prefixes: Add Digilent Inc Documentation: devicetree: Fix Xilinx VDMA specification ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188 ARM: dts: rockchip: add label property for leds on Radxa Rock ARM: BCM5301X: Add LEDs for Netgear R6250 V1 ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file ARM: dts: add sysreg phandle to i2c device nodes for exynos ARM: dts: Remove unused bootargs from exynos3250-rinato ARM: dts: add board dts file for Exynos3250-based Monk board ...
2014-11-19ARM: dts: Explicitly set dr_mode on exynos5250-snowSjoerd Simons
Explicitly set the dr_mode for the dwc3 controller on the Snow board to host mode. This is required to ensure the controller is initialized in the right mode if the kernel is build with USB gadget support. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-10-21ARM: dts: Add rtc_src clk for s3c-rtc on exynos5250-snowJavier Martinez Canillas
commit 546b117fdf17 ("rtc: s3c: add support for RTC of Exynos3250 SoC") added an "rtc_src" DT property for the Samsung's S3C Real Time Clock controller that specifies the 32.768 kHz clock that uses the RTC as its source clock. In the case of the Exynos5250 based Snow board, the Maxim 77686 32kHz AP clock is used as the source clock. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-10-21ARM: dts: Clean up exynos5250-smdk5250Andreas Faerber
Use the new style for referencing inherited nodes and use symbolic names. Goal is the alignment of all exynos5250 based device trees for comparison. Signed-off-by: Andreas Faerber <afaerber@suse.de> Reviewed-by: Tomasz Figa <t.figa@samsung.com> [kgene.kim@samsung.com: rebased and squashed] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-10-21ARM: dts: Fill in bootargs for exynos5250-snowAndreas Faerber
exynos5250-cros-common.dtsi had an empty /chosen node. Fill in exemplary boot arguments. Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Andreas Faerber <afaerber@suse.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-10-21ARM: dts: Clean up exynos5250-snowAndreas Faerber
Use the new style of referencing inherited nodes and use symbolic names. Reorder one pinctrl node in GPIO order. Goal is the alignment of all exynos5250 based device trees for comparison. Suggested-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Andreas Faerber <afaerber@suse.de> Reviewed-by: Tomasz Figa <t.figa@samsung.com> [kgene.kim@samsung.com: rebased and squashed] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-09-14ARM: dts: update display related nodes for exynos5250-snowAjay Kumar
Add DT nodes for ptn3460 bridge chip and panel. Add backlight enable pin and backlight power supply for pwm-backlight. Also add bridge phandle needed by dp to enable display on snow. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-08-18ARM: dts: unuse the slot-node and deprecate the supports-highspeed for ↵Jaehoon Chung
dw-mmc in exynos dw-mmc controller can support multiple slots. But, there are no use-cases anywhere. So we don't need to support the slot-node for dw-mmc controller. And "supports-highspeed" property in dw-mmc is deprecated. "supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed". Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Tushar Behera <trblinux@gmail.com> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Tested-by: Sachin Kamat <sachin.kamat@samsung.com> [kgene.kim@samsung.com: rebased exynos5250-snow changes] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-08-18ARM: dts: Fold exynos5250-cros-common into exynos5250-snowAndreas Faerber
exynos5250-cros-common.dtsi was meant for sharing common pieces across ChromeOS devices. This turned out premature, as several devices ended up in the common file that are not common after all. Since the remaining common ChromeOS pieces are fairly minor, exynos5250-cros-common.dtsi was requested to be merged into the Snow device tree, sharing only the keyboard controller for now. This may be re-evaluated as both mature. Suggested-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Andreas Faerber <afaerber@suse.de> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-08-18ARM: dts: Fix MMC pinctrl for exynos5250-snowAndreas Faerber
The pinctrl properties should be on the device directly and not on the slot sub-node. Reported-by: Doug Anderson <dianders@chromium.org> Cc: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Andreas Faerber <afaerber@suse.de> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-31Merge tag 'samsung-dt-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt Merge "Samsung DT 2nd updates for v3.17" from Kukjin Kim: This is based on tags/exynos-power because this DT changes are depending PMU cleanup. Fixes boot for exynos5260 and exynos5410, - Since exynos cannot boot without obtaining PMU address via DT from now on, add PMU node for exynos5260 and exynos5410 For preparing exynos5250-spring, - move max77686 and cypress,cyapa trackpad from exynos5250- cros-common to exynos5250-snow DT file (Note exynos5250-spring is not included in this branch yet) For exynos3250, - add TMU node and remove duplicated interrupt-parent - add missing pinctrl property for uart0 and uart1 For exynos5250-smdk5250 board - add max77686 pmic interrupt property which is connected to gpx3 * tag 'samsung-dt-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (28 commits) ARM: dts: Add missing pinctrl for uart0/1 for exynos3250 ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250 ARM: dts: Add TMU dt node to monitor the temperature for exynos3250 ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250 ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only ARM: dts: max77686 is exynos5250-snow only ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table ARM: dts: Add PMU DT node for exynos5260 SoC ARM: EXYNOS: Add support for Exynos5410 PMU ARM: dts: Add PMU to exynos5410 ARM: dts: Document exynos5410 PMU ARM: EXYNOS: Move cpufreq and cpuidle device registration to init_machine ARM: EXYNOS: Refactored code for using PMU address via DT ARM: EXYNOS: Support cluster power off on exynos5420/5800 ARM: EXYNOS: populate suspend and powered_up callbacks for mcpm ARM: EXYNOS: do not allow cpuidle registration for exynos5420 cpuidle: big.LITTLE: init driver for exynos5420 cpuidle: big.LITTLE: Add ARCH_EXYNOS entry in config ARM: EXYNOS: add generic function to calculate cpu number cpuidle: big.LITTLE: add of_device_id structure ... Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-30ARM: dts: cypress,cyapa trackpad is exynos5250-Snow onlyAndreas Faerber
Move it from exynos5250-cros-common.dtsi to exynos5250-snow.dts. Spring does not need it, it uses an Atmel maXTouch instead. Signed-off-by: Andreas Faerber <afaerber@suse.de> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-30ARM: dts: max77686 is exynos5250-snow onlyAndreas Faerber
Move it from exynos5250-cros-common.dtsi to exynos5250-snow.dts. Spring does not need it, it uses an s5m8767 instead. Signed-off-by: Andreas Faerber <afaerber@suse.de> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-19Merge tag 'samsung-dt' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt Merge "Samsung DT updates for v3.17" from Kukjin Kim: exynos3250: add i2s dt for audio interface exynos4 - cleanup arm-pmu node because of 4 pmu on exynos4412 but 2 pmu on other exynos4 SoCs - add support sub-nodes to exynos usb host for exynos4 exynos4412-odroid-common - fix T-FLASH hotplug detection - disable 'always on' for BUCK8 - add support for GPIO based buttons - add MAX98090 audio codec exynos4412-odroidx2 and exynos4412-odroidu3 - refactor exynos4412-odroidx and exynos4412-odroid-common for odroid-x2 and u2/u3 exynos4412-odroidx - add support for USB phy, host and device - enable common hardware blocks, secure firmware calls, watchdog, g2d and fimc (mem2mem) multimedia accelerators - add support for USB phy, host and device - correct memory size exynos5410 - fill in CPU clock-frequency property to avoid warning exynos5420 - remove display pd because of instability exynos5420-peach-pit and exynos5800-peach-pi - sort nodes each other to check its differences easily - enable audio support and add sound-card name property - add mask-tpm-reset node - add cros_ec including keyboard, i2c tunnel and tps65090 and battery under the i2c tunnel * tag 'samsung-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: dts: Add I2S dt node for exynos3250 ARM: dts: Add cros_ec to exynos5420-peach-pit and exynos5800-peach-pi ARM: dts: clean up arm-pmu node for exynos4 ARM: dts: remove display power domain for exynos5420 ARM: dts: Add sound nodes for Odroid-X2/U3 boards ARM: dts: fix T-FLASH hotplug detection for exynos4412-odroid-common ARM: dts: add support for GPIO buttons for exynos4412-odroid ARM: dts: disable 'always on' for BUCK8 regulator for exynos4412-odroid-common ARM: dts: refactor Odroid DTS file and add support for Odroid X2 and U2/U3 ARM: dts: correct memory size for exynos4412-odroidx ARM: dts: add support for USB phy, host and device for exynos4412-odroidx ARM: dts: enable common hardware blocks for exynos4412-odroidx ARM: dts: add port sub-nodes to exynos usb host modules for exynos4 ARM: dts: Add mask-tpm-reset node in exynos5800-peach-pi ARM: dts: Add mask-tpm-reset node in exynos5420-peach-pit ARM: dts: Add sound-card name for Snow/Peach-Pit/Peach-Pi ARM: dts: Fill in CPU clock-frequency for exynos5410 ARM: dts: Sort nodes within Peach-pit/Peach-pi dts files ARM: dts: Enable audio support for exynos5800-peach-pi
2014-07-08ARM: dts: Add sound-card name for Snow/Peach-Pit/Peach-PiTushar Behera
Add sound-card name property to Snow/Peach-Pit/Peach-Pi boards. Signed-off-by: Tushar Behera <tushar.b@samsung.com> Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-06-16ARM: dts: Use the cros-ec-keyboard fragment in exynos5250-snowDoug Anderson
Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-19ARM: dts: enable dp-controller for exynos5250-snow boardRahul Sharma
Enable dp-controller for snow board. Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-19ARM: dts: enable fimd for exynos5250-snow boardRahul Sharma
Enable fimd node for snow board. Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-19ARM: dts: enable pwm backlight for exynos5250-snowAjay Kumar
Add PWM backlight node for exynos5250 based snow board. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-19ARM: dts: Add Vbus regulator for USB 3.0 on exynos5250-snowVivek Gautam
Add required fixed-regulator for VBUS supply for USB 3.0 controller phy. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-19ARM: dts: Add sound node for exynos5250-snow boardTushar Behera
The audio codec on Snow board, MAX98095 is connected on I2C7 bus. Also it requires the GPX1-7 line to be pulled up. Updated Snow DTS file to incorporate above changes and added a sound node to instantiate the I2S-based sound card. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-19ARM: dts: enable hdmi for exynos5250 based snow boardRahul Sharma
Enable support for HDMI for exynos5250 based Snow board. Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com> Acked-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-16ARM: dts: add tps65090 power regulator for exynos5250-snowDoug Anderson
Added TPS65090 regulator related nodes to Snow board. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-16ARM: dts: add pinctrl for EC irq of exynos5250-snowDoug Anderson
Added pinctrl node for embedded controller (EC) IRQ on Snow board. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-16ARM: dts: add pinctrl for i2c-arbitrator of exynos5250-snowDoug Anderson
Added i2c-arbitrator pinctrl node to Snow board. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-03-29Merge tag 'exynos-cleanup' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3 Merge "Exynos cleanup for v3.15" from Kukjin Kim: - reorganize code for - add support reserve memory for mfc-v7 - consolidate exynos4 and exynos5 machine codes - add generic compatible strings for exynos4 and exynos5 - update DT with generic compatible strings - move clk related dt-binding header file in dt-bindings/clock * tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock ARM: dts: Update Exynos DT files with generic compatible strings ARM: EXYNOS: Add generic compatible strings ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files ARM: EXYNOS: Consolidate CPU init code ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers ARM: EXYNOS: Add support to reserve memory for MFC-v7 ARM: SAMSUNG: Reorganize calls to reserve memory for MFC Conflicts: arch/arm/mach-exynos/exynos.c Signed-off-by; Arnd Bergmann <arnd@arndb.de>
2014-03-21ARM: dts: Update Exynos DT files with generic compatible stringsSachin Kamat
Add generic compatible strings to the respective board DT files. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-02-24ARM: dts: Re-organize RTC status for exynos5250Sachin Kamat
Some boards might not have RTC xtal, so RTC shouldn't really be enabled by default. Enable it in the required board files. For now enable it for all board files to maintain the enabled status exisitng prior to this patch. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-21ARM: dts: Rename Exynos5250 ChromeOS common file to have exynos prefixMark Brown
Make it easier to notice the common file for ChromeOS devices based on the Exynos5250 by giving it the exynos5250 prefix that the boards have. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Tomasz Figa <t.figa@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-21ARM: dts: Fix status property of mmc nodes for snow boardYuvaraj Kumar C D
Commit e908d5c5 ("ARM: dts: change status property of dwmmc nodes for exynos5250") missed out handling the exynos5250 snow dts file. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-21Merge branch 'v3.14-next/fixes-samsung-2' into v3.14-next/dt-exynos-2Kukjin Kim
2013-12-21ARM: dts: Fix exynos5250-snow's search key to be L_METADoug Anderson
The device tree sent upstream for exynos5250-snow encoded the search key as CAPSLK. However in all ChromeOS kernels it is L_META. One can certainly have long debates about which it ought to be, but I'm proposing setting it to L_META because: * That's how _all_ ChromeOS kernels do it and will do it. * There is no L_META key on the board, so it's nice to have. * For those people who really want it to be caps lock, they can use xmodmap or somesuch. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-21ARM: dts: Add the missing "\" key in non-US keyboards for exynos5250-snowDoug Anderson
When the exynos5250 device tree was sent upstream the keyboard mapping was missing the 2nd instance of the "\" key. There are two copies of the "\" because it simply has a different row and column on US and non-US keyboards. For more details, see the previous patch in this series: (mkbp: Fix problems with backslash). Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-16ARM: dts: rename mmc dts node for exynos5 seriesYuvaraj Kumar C D
This patch rename's the device tree mmc node's from "dwmmc" to "mmc". According to ePAPR chapter 2.2.2 generic node name recommendation, it has been opted change from dwmmc to mmc.Also this patch remove the instance index from the node name. Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-08-26ARM: dts: Update the "status" property of RTC DT node for Exynos5250 SoCVikas Sajjan
Moves the RTC DT node's "status" property from exynos5250 board (arndale & snow) dts files to exynos5250.dtsi, since the bindings in exynos5250.dtsi depicts the RTC h/w completely. Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-08-26ARM: dts: Fix the RTC DT node name for Exynos5250Vikas Sajjan
Fixes the RTC DT node name for Exynos5250 as per the DT node naming convention. Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-06-19ARM: dts: use #include for all device trees for SamsungPadmavathi Venna
Replace /include/ (dtc) with #include (C pre-processor) for all Samsung DT files Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-06-18ARM: dts: Enable RTC node for exynos5250-snowDoug Anderson
By default the exynos RTC is disabled. Enable it for snow. There's also an external RTC on the max77686 PMIC but we haven't yet enabled that. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-05-09ARM: exynos: dts: Fixed vbus-gpiosDoug Anderson
The 'samsung,vbus-gpio' was submitted before pinmux landed for exynos5250 and uses the old-style gpio specifier. Fix the two exynos5250 boards that use it. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Olof Johansson <olof@lixom.net>
