Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
Configure the pins in external interrupt mode, as done for Snow in
e5e5c6d14e39 ("ARM: dts: Add power and lid GPIO keys pinctrl for
exynos5250-snow").
Reported-by: Kukjin Kim <kgene@kernel.org>
Suggested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Fixes: 53dd4138bb0a ("ARM: dts: Add exynos5250-spring device tree")
Signed-off-by: Andreas Faerber <afaerber@suse.de>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Resolve a merge conflict with mmc refactoring aaa25a5a33cb ("ARM: dts:
unuse the slot-node and deprecate the supports-highspeed for dw-mmc in
exynos") by dropping the slot@0 nodes, moving its bus-width property to
the mmc node and replacing supports-highspeed with cap-{mmc,sd}-highspeed,
matching exynos5250-snow.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: <stable@vger.kernel.org> [3.19+]
The kernel can use as the default console a serial port if is defined
as stdout device in the Device Tree.
This allows a board to be booted without the need of having a console
parameter in the kernel command line.
Currently the Spring DTS has bootargs in the /chosen node and this is
kept since users that don't have a serial console on this board might
be using it to have the boot log shown in the display. This will have
more precedence than the stdout-path but it's fine since is only used
when CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is enabled.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
The HP Chromebook 11 uses an Atmel maXTouch as trackpad.
The keymap was found by trial-and-error.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Spotted in the Chrome OS 3.8 based device tree.
Needs CONFIG_SENSORS_LM90.
Reported-by: Doug Anderson <dianders@chromium.org>
Adds initial support for the HP Chromebook 11.
Cc: Vincent Palatin <vpalatin@chromium.org>
Cc: Doug Anderson <dianders@chromium.org>
Cc: Stephan van Schaik <stephan@synkhronix.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
