Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
git://git.infradead.org/users/jcooper/linux into irq/core
irqchip core change for v4.1 (round 3) from Jason Cooper
Purge the gic_arch_extn hacks and abuse by using the new stacked domains
NOTE: Due to the nature of these changes, patches crossing subsystems have
been kept together in their own branches.
- tegra
- Handle the LIC properly
- omap
- Convert crossbar to stacked domains
- kill arm,routable-irqs in GIC binding
- exynos
- Convert PMU wakeup to stacked domains
- shmobile, ux500, zynq (irq_set_wake branch)
- Switch from abusing gic_arch_extn to using gic_set_irqchip_flags
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt
Merge "Samsung DT updates for v4.1" from Kukjin Kim:
- for exynos3250
: add assigned clock parents for CMU nodes
- for exynos4412-odroid
: add eMMC reset line
- for exynos5250
: fixed typo for interrupt-cells
- for exynos5250-snow
: define stdout-path property
: represent bridge and panel connection
: enable wifi power-on and add cap-sdio-irq to wifi mmc node
- for exynos5250-spring
- for exynos5420
: add async-bridge clocks for gsc and disp1 PDs
- for exynos5420 boards
: Mux XMMCnDATA[0] pad correctly
- for exynos5420-odroidxu3
- for Peach boards
: add HS400 support and define stdout-path property
: add mclk entry and add WiFi module support
* tag 'samsung-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: Fixed typo interrupt-cells for exynos5420 and exynos5250
ARM: dts: Add HS400 support for exynos5420 and exynos5800
ARM: dts: add async-bridge clocks to gsc power domain for exynos5420
ARM: dts: add async-bridge clocks to disp1 power domain for exynos5420
dt-bindings: add asynchronous bridge clock for exynos
ARM: dts: Define stdout-path property for exynos5250-spring
ARM: dts: Define stdout-path property for exynos5250-snow
ARM: dts: Define stdout-path property for Peach boards
ARM: dts: Add assigned clock parents to CMU node for exynos3250
ARM: dts: Add mclk entry for Peach boards
ARM: dts: Add WiFi module support for Peach boards
ARM: dts: Mux XMMCnDATA[0] pad correctly for Exynos5420 boards
ARM: dts: add eMMC reset line for exynos5422-odroidxu3
ARM: dts: add eMMC reset line for exynos4412-odroid-common
ARM: dts: represent bridge and panel connection for exynos5420-peach-pit
ARM: dts: represent bridge and panel connection for exynos5250-snow
ARM: dts: Add cap-sdio-irq to wifi mmc node for exynos5250-snow
ARM: dts: Enable wifi power-on for exynos5250-snow
Changes fixes the misspelled of #interrups-cell.
arch/arm/boot/dts/exynos5420.dtsi:224: WARNING: 'interrups'
may be misspelled - perhaps 'interrupts'?
Tested on OdroidXU3 board.
Signed-off-by: Anand Moon <linux.amoon@gmail.com>
[kgene@kernel.org: added fixing same typo in exynos5250]
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Exynos has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the fact that the PMU block is actually the first
interrupt controller in the chain for RTC, kernels with this patch
applied wont have any suspend-resume facility when booted
with old DTs, and old kernels with updated DTs may not even boot.
Also, I strongly suspect that there is more than two wake-up
interrupts on these platforms, but I leave it to the maintainers
to fix their mess.
Link: https://lkml.kernel.org/r/1426088693-15724-2-git-send-email-marc.zyngier@arm.com
[ jac: squash in maz's fixup from
https://lkml.kernel.org/r/5506989D.9050703@arm.com ]
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The patch adds domain definition and references to it in appropriate devices.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
[mszyprow: rebased onto generic power domains dt bindings]
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Mixed block needs to control hdmi clock to properly perform power on/off
operation, so add 'hdmi' clock also to mixer nodes.
Presented device tree bindings provide data already hardcoded in the
exynos_tmu_data.c file.
After this commit, it should be possible to reuse common thermal core
framework in Exynos SoCs.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Presented patch aims to move data necessary for correct CPU cooling device
configuration from exynos_tmu_data.c to device tree.
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
This patch replaces all custom samsung,power-domain dt
properties with generic power domain bindings and updates
documentation Samsung's devices referring to old binding.
Suggested-by: Kevin Hilman <khilman@kernel.org>
[javier.martinez@collabora.co.uk: tested on the Exynos5800 Peach Pi Chromebook]
DP PHY now require pmu-system-controller to handle PMU register
to control PHY's power isolation. Adding the same to dp-phy
node.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging tree pull request for 3.19-rc1.
We continued to delete more lines than were added, always a good
thing, but not at a huge rate this release, only about 70k lines
removed overall mostly from removing the horrid bcm driver.
Lots of normal staging driver cleanups and fixes all over the place,
well over a thousand of them, the shortlog shows all the horrid
details.
The "contentious" thing here is the movement of the Android binder
code out of staging into the "real" part of the kernel. This is code
that has been stable for a few years now and is working as-is in the
tens of millions of devices with no issues. Yes, the code is horrid,
and the userspace api leaves a lot to be desired, but it's not going
to change due to legacy issues that we have no control over. Because
so many devices and companies rely on this, and the code is stable,
might as well promote it out of staging.
This was all discussed at the Linux Plumbers conference, and everyone
participating agreed that this was the best way forward.
There is work happening to replace the binder code with something new
that is happening right now, but I don't expect to see the results of
that work for another year at the earliest. If that ever happens, and
Android switches over to it, I'll gladly remove this version.
As for maintainers, I'll be glad to maintain this code, I've been
doing it for the past few years with no problems. I'll send a
MAINTAINERS entry for it before 3.19-final is out, still need to talk
to the Google developers about if they are willing to help with it or
not, last I checked they were, which was good.
All of these patches have been in linux-next for a while with no
reported issues"
* tag 'staging-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1382 commits)
Staging: slicoss: Fix long line issues in slicoss.c
staging: rtl8712: remove unnecessary else after return
staging: comedi: change some printk calls to pr_err
staging: rtl8723au: hal: Removed the extra semicolon
lustre: Deletion of unnecessary checks before three function calls
staging: lustre: fix sparse warnings: static function declaration
staging: lustre: fixed sparse warnings related to static declarations
staging: unisys: remove duplicate header
staging: unisys: remove unneeded structure
staging: ft1000 : replace __attribute ((__packed__) with __packed
drivers: staging: rtl8192e: Include "asm/unaligned.h" instead of "access_ok.h" in "rtl819x_BAProc.c"
Drivers:staging:rtl8192e: Fixed checkpatch warning
Drivers:staging:clocking-wizard: Added a newline
staging: clocking-wizard: check for a valid clk_name pointer
staging: rtl8723au: Hal_InitPGData() avoid unnecessary typecasts
staging: rtl8723au: _DisableAnalog(): Avoid zero-init variables unnecessarily
staging: rtl8723au: Remove unnecessary wrapper _ResetDigitalProcedure1()
staging: rtl8723au: _ResetDigitalProcedure1_92C() reduce code obfuscation
staging: rtl8723au: Remove unnecessary wrapper _DisableRFAFEAndResetBB()
staging: rtl8723au: _DisableRFAFEAndResetBB8192C(): Reduce code obfuscation
Pull ARM SoC DT updates from Arnd Bergmann:
"The DT branch adds a lot of new stuff for additional SoC and board
support. The branch is the largest one and contains 513 out of the
total 972 non-merge arm-soc changesets for 3.19.
Most of the changes are about enabling additional on-chip devices for
existing machines, but there are also an unusual number of new SoC
types being added this time:
- AMLogic Meson8
- ARM Realview in DT mode
- Allwinner A80
- Broadcom BCM47081
- Broadcom Cygnus
- Freescale LS1021A
- Freescale Vybrid 500 series
- Mediatek MT6592, MT8127, MT8135
- STMicroelectronics STiH410
- Samsung Exynos4415
The level of support for the above differs widely, some are just stubs
with nothing more than CPU, memory and a UART, but others are fairly
complete. As usual, these get extended over time.
There are also many new boards getting added, this is the list of
model strings that are showing up in new dts files:
- ARM RealView PB1176
- Altera SOCFPGA Arria 10
- Asus RT-N18U (BCM47081)
- Buffalo WZR-1750DHP (BCM4708)
- Buffalo WZR-600DHP2 (BCM47081)
- Cygnus Enterprise Phone (BCM911360_ENTPHN)
- D-Link DIR-665
- Google Spring
- IGEP COM MODULE Rev. G (TI OMAP AM/DM37x)
- IGEPv2 Rev. F (TI OMAP AM/DM37x)
- LS1021A QDS Board
- LS1021A TWR Board
- LeMaker Banana Pi
- MarsBoard RK3066
- MediaTek MT8127 Moose Board
- MediaTek MT8135 evaluation board
- Mele M3
- Merrii A80 Optimus Board
- Netgear R6300 V2 (BCM4708)
- Nomadik STN8815NHK
- NovaTech OrionLXm
- Olimex A20-OLinuXino-LIME2
- Raspberry Pi Model B+
- STiH410 B2120
- Samsung Monk board
- Samsung Rinato board
- Synology DS213j
- Synology DS414
- TBS2910 Matrix ARM mini PC
- TI AM5728 BeagleBoard-X15
- Toradex Colibri VF50 on Colibri Evaluation Board
- Zynq ZYBO Development Board
Other notable changes include:
- exynos: cleanup of existing dts files
- mvebu: improved pinctrl support for Armada 370/XP
- nomadik: restructuring dts files
- omap: added CAN bus support
- shmobile: added clock support for some SoCs
- shmobile: added sound support for some SoCs
- sirf: reset controller support
- sunxi: continuing the relicensing under dual GPL/MIT
- sunxi: lots of new on-chip device support
- sunxi: working simplefb support (long awaited)
- various: provide stdout-path property for earlycon"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits)
ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured
Revert "ARM: dts: rockchip: temporarily disable smp on rk3288"
ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2
ARM: BCM5301X: Add DT for Asus RT-N18U
ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP
ARM: BCM5301X: Add DT for Netgear R6300 V2
ARM: BCM5301X: Add buttons for Netgear R6250
ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard
ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188
ARM: dts: rockchip: add label property for leds on Radxa Rock
ARM: BCM5301X: Add LEDs for Netgear R6250 V1
ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file
ARM: dts: add sysreg phandle to i2c device nodes for exynos
ARM: dts: Remove unused bootargs from exynos3250-rinato
ARM: dts: add board dts file for Exynos3250-based Monk board
We want those staging fixes in here as well.
This patch adds syscon based phandle to i2c device nodes of exynos5250
and exynos5420. These phandles will be used to save restore i2c sysreg
configuration register during s2r from i2c driver.
CC: Rob Herring <robh+dt@kernel.org>
CC: Randy Dunlap <rdunlap@infradead.org>
CC: Russell King <linux@arm.linux.org.uk>
CC: devicetree@vger.kernel.org
CC: linux-doc@vger.kernel.org
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Explicitly set the dr_mode for the dwc3 controller on the
Snow board to host mode. This is required to ensure the
controller is initialized in the right mode if the kernel is
build with USB gadget support.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of new drivers, features and cleanups for IIO in the 3.19 cycle.
New drivers / supported parts
* rockchip - rk3066-tsadc variant
* si7020 humidity and temperature sensor
* mcp320x - add mcp3001, mcp3002, mcp3004, mcp3008, mcp3201, mcp3202
* bmp280 pressure and temperature sensor
* Qualcomm SPMI PMIC current ADC driver
* Exynos_adc - support exynos7
New features
* vf610-adc - add temperature sensor support
* Documentation of current attributes, scaled pressure, offset and
scaled humidity, RGBC intensity gain factor and scale applied to
differential voltage channels.
* Bring iio_event_monitor up to date with newer modifiers.
* Add of_xlate function to allow for complex channel mappings from the
device tree.
* Add -g parameter to generic_buffer example to allow for devices with
directly fed (no trigger) buffers.
* Move exynos driver over to syscon for PMU register access.
Cleanups, fixes for new drivers
* lis3l02dq drop an unneeded else.
* st sensors - renam st_sensors to st_sensor_settings (for clarity)
* st sensors - drop an unused parameter from all the probe utility
functions.
* vf610 better error handling and tidy up.
* si7020 - cleanups following merge
* as3935 - drop some unnecessary semicolons.
* bmp280 - fix the pressure calculation.
Instead of using the ADC_PHY register base address, use sysreg phandle
in ADC node to control ADC_PHY configuration register.
This patch adds syscon node for Exynos3250, Exynos4x12, Exynos5250,
and Exynos5420, Exynos5800.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
To: linux-samsung-soc@vger.kernel.org
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Allows them to be extended by reference.
Reviewed-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Andreas Faerber <afaerber@suse.de>
drivers/usb/phy/phy-samsung-usb2 driver got replaced by
drivers/phy/phy-samsung-usb2 one. Remove the leftover
USB2 PHY node (EHCI/OHCI USB nodes are using the new one
already) from Exynos5250 dtsi file.
Cc: Mark Brown <broonie@linaro.org>
Cc: Kamil Debski <k.debski@samsung.com>
Cc: Vivek Gautam <gautam.vivek@samsung.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
Reviewed-by: Vivek Gautam <gautam.vivek@samsung.com>
This patch extends nodes of PMU system controller on Exynos4210, 4x12,
5250 and 5420 SoCs with newly defined properties used by Exynos CLKOUT
driver.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Add PMU syscon handle to HDMI dt node for controlling
PHY Enable/Disable bit.
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
Phy and sss module device node missed clock macro.
This patch replace magic number with macros in clock
binding for exynos5250.
Signed-off-by: Beomho Seo <beomho.seo@samsung.com>
Reviewed-by: Sachin Kamat <sachin.kamat@linaro.org>
Add support to PHY of USB2 of the Exynos5250 SoC.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
[gautam.vivek@samsung.com: Split the usb phy entries]
[gautam.vivek@samsung.com: Added phy entry for OHCI also along with EHCI]
Signed-off-by: Vikas Sajjan <vikas.sajjan@samsung.com>
This patch adds sysreg-syscon node to exynos5250 and exynos5420 device
tree, to access System Register's registers using syscon driver.
[gautam.vivek@samsung.com: Split this syreg-syscon dts entry]
[gautam.vivek@samsung.com: added similar syscon entry for exynos5420]
[vikas.sajjan@samsung.com: updated the binding document]
Removing the dt node for older usb3 phy driver from Exynos5250
device tree and updating the dt node for DWC3 controller to
use new phy driver based on generic phy framework.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Add device tree node for new usbdrd-phy driver, which
is based on generic phy framework.
Instead of hardcoding the SYSRAM details for each SoC,
pass this information through device tree (DT) and make
the code SoC agnostic. Generic DT SRAM bindings are
used for achieving this.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Most of the clock related dt-binding header files are located in
dt-bindings/clock folder. It would be good to keep all the similar
header files at a single location.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Acked-by: Tomasz Figa <t.figa@samsung.com>
Add generic compatible strings to the respective board DT files.
This patch adds dt entry for ahci sata controller and its
corresponding phy controller.phy node has been added w.r.t
new generic phy framework.
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
This patch adds the device tree node for SSS module
found on Exynos5420 and Exynos5250
The patch replaces magic numbers with macros defined in DT header
in exynos5250 clock bindings.
Acked-by: Mike Turquette <mturquette@linaro.org>
Some boards might not have RTC xtal, so RTC shouldn't really be
enabled by default. Enable it in the required board files. For
now enable it for all board files to maintain the enabled status
exisitng prior to this patch.
In EXYNOS5 series SoCs, PMU has registers to enable/disable mask/unmask
watchdog timer which is not the case with s3c series SoCs so, there is a
need to have different compatible names for watchdog to handle these pmu
registers access.
Hence this patch removes watchdog node from Exynos5.dtsi common file and
make it separate by updating existing node in Exynos5250 and adding new node
to Exynos5420. This patch also makes the watchdog node enabled by default
Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com>
Tested-by: Doug Anderson <dianders@chromium.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
This patch adds pmusysreg node to exynos5250 and exynos5420 dtsi files to
handle PMU register accesses in a centralized way using syscon driver
git://git.linaro.org/people/mike.turquette/linux
Pull clk framework changes from Mike Turquette:
"The first half of the clk framework pull request is made up almost
entirely of new platform/driver support. There are some conversions
of existing drivers to the common-clock Device Tree binding, and a few
non-critical fixes to the framework.
Due to an entirely unnecessary cyclical dependency with the arm-soc
tree this pull request is broken into two pieces. The second piece
will be sent out after arm-soc sends you the pull request that merged
in core support for the HiSilicon 3620 platform. That same pull
request from arm-soc depends on this pull request to merge in those
HiSilicon bits without causing build failures"
[ Just did the ARM SoC merges, so getting ready for the second clk tree
pull request - Linus ]
* tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits)
devicetree: bindings: Document qcom,mmcc
devicetree: bindings: Document qcom,gcc
clk: qcom: Add support for MSM8660's global clock controller (GCC)
clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8974's global clock controller (GCC)
clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8960's global clock controller (GCC)
clk: qcom: Add reset controller support
clk: qcom: Add support for branches/gate clocks
clk: qcom: Add support for root clock generators (RCGs)
clk: qcom: Add support for phase locked loops (PLLs)
clk: qcom: Add a regmap type clock struct
clk: Add set_rate_and_parent() op
reset: Silence warning in reset-controller.h
clk: sirf: re-arch to make the codes support both prima2 and atlas6
clk: composite: pass mux_hw into determine_rate
clk: shmobile: Fix MSTP clock array initialization
clk: shmobile: Fix MSTP clock index
ARM: dts: Add clock provider specific properties to max77686 node
clk: max77686: Register OF clock provider
"DT and DT-conversion-related changes for various ARM platforms. Most
of these are to enable various devices on various boards, etc, and not
necessarily worth enumerating.
New boards and systems continue to come in as new devicetree files
that don't require corresponding C changes any more, which is
indicating that the system is starting to work fairly well.
A few things worth pointing out:
* ST Ericsson ux500 platforms have made the major push to move over
to fully support the platform with DT
* Renesas platforms continue their conversion over from legacy
platform devices to DT-based for hardware description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (327 commits)
ARM: dts: SiRF: add pin group for USP0 with only RX or TX frame sync
ARM: dts: SiRF: add lost usp1_uart_nostreamctrl pin group for atlas6
ARM: dts: sirf: add lost minigpsrtc device node
ARM: dts: sirf: add clock, frequence-voltage table for CPU0
ARM: dts: sirf: add lost bus_width, clock and status for sdhci
ARM: dts: sirf: add lost clocks for cphifbg
ARM: dts: socfpga: add pl330 clock
ARM: dts: socfpga: update L2 tag and data latency
arm: sun7i: cubietruck: Enable the i2c controllers
ARM: dts: add support for EXYNOS4412 based TINY4412 board
ARM: dts: Add initial support for Arndale Octa board
ARM: bcm2835: add USB controller to device tree
ARM: dts: MSM8974: Add MMIO architected timer node
ARM: dts: MSM8974: Add restart node
ARM: dts: sun7i: external clock outputs
ARM: dts: sun7i: Change 32768 Hz oscillator node name to clk@N style
ARM: dts: sun7i: Add pin muxing options for clock outputs
ARM: dts: sun7i: Add rtp controller node
ARM: dts: sun5i: Add rtp controller node
ARM: dts: sun4i: Add rtp controller node
Pull ARM SoC non-critical fixes from Olof Johansson:
"As usual, we have a batch of fixes that weren't considered significant
enough to warrant going into the later -rcs for previous release, so
they are queued up on this branch.
A handful of these are for various DT fixups for Samsung platforms,
and a handful of other minor things.
There are also a couple of stable-marked patches for mvebu -- they
came in quite late and we decided to keep them deferred until the
first -stable release to get more coverage instead of squeezing them
into 3.13"
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits)
ARM: at91: smc: bug fix in sam9_smc_cs_read()
i2c: mv64xxx: Document the newly introduced Armada XP A0 compatible
i2c: mv64xxx: Fix bus hang on A0 version of the Armada XP SoCs
ARM: mvebu: Add quirk for i2c for the OpenBlocks AX3-4 board
ARM: mvebu: Add support to get the ID and the revision of a SoC
ARM: dts: msm: Fix gpio interrupt and reg length
irqchip: sirf: set IRQ_LEVEL status_flags
ARM: OMAP2+: gpmc: Move legacy GPMC width setting
ARM: OMAP2+: gpmc: Introduce gpmc_set_legacy()
ARM: OMAP2+: gpmc: Move initialization outside the gpmc_t condition
ARM: OMAP2+: board-generic: update SoC compatibility strings
Documentation: dt: OMAP: explicitly state SoC compatible strings
ARM: OMAP2+: enable AM33xx SOC EVM audio
ARM: OMAP2+: Select USB PHY for AM335x SoC
ARM: bcm2835: Fix grammar in help message
ARM: msm: trout: fix uninit var warning
ARM: dts: Use MSHC controller for eMMC memory for exynos4412-trats2
ARM: dts: Fix definition of MSHC device tree nodes for exynos4x12
ARM: dts: add clock provider for mshc node for Exynos4412 SOC
clk: samsung: exynos4: Fix definition of div_mmc_pre4 divider
Specify pll_ref, pll_in, sclk_audio, and sclk_pcm_in for the AudioSS
clock controller.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Due to incorrect clock specified in MDMA0 node, using MDMA0 controller
could cause system failures, due to wrong clock being controlled. This
patch fixes this by specifying correct clock.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
[t.figa: Corrected commit message and description.]
Ensure that unused I2C controllers are not activated, causing problems due
to inappropriate pinmuxing or similar, by marking the controllers as
disabled by default and requiring boards to explicitly enable those that
are in use.
Signed-off-by: Mark Brown <broonie@linaro.org>
Rather than requiring each board to explicitly disable the SPI controllers
it is not using instead require boards to enable those that they are using.
This is less work overall since normally at most one of the controllers is
in use and avoids issues caused by inappropriate pinmuxing.
Add the device-tree binding for the PWM controller to Exynos5250 and Exynos5420
Signed-off-by: Olof Johansson <olofj@chromium.org>
This patch rename's the device tree mmc node's from "dwmmc" to "mmc".
According to ePAPR chapter 2.2.2 generic node name recommendation,
it has been opted change from dwmmc to mmc.Also this patch remove the
instance index from the node name.
As fifo-depth property in dw_mmc device tree node is SOC
specific, move this property to exynos5250 SOC specific
file.
[kgene.kim@samsung.com: squashed fifo-depth patch for cros5250-common]
According to ePAPR, chapter 2.3.4, the status property has
defined that it should be set to "disabled" when "the device
is not presently operational, but it might become operational
in the future".
So this patch disable dwmmc node by "status = disabled" in SOC
dts file and enable dwmmc node by "status = okay" in board specific
dts file.
