This patch adds device nodes for the AUDSS clock controller,
peripheral DMA 0/1 controllers and the Audio Subsystem I2S controller.
These entries are required for sound support on Odroid-XU board.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Replace duplicated macros in each DTSI file with a common macro coming
from header. Include the header in each pinctrl DTSI so further changes
could use it.
Although PIN_FUNC_SPC_2 does not bring much information about the
function itself, it still is more descriptive then hard-coded
number <2>.
Add pincontrol groups for HSI2C (USI), I2C, PWM and UART to Exynos5410.
This allows configuring these pins to specific functions.
Configure the pinctrl for MMC0 (eMMC) and MMC2 (microSD card).
Add the required pin configuration support to Exynos5410 using pinctrl
interface.
Signed-off-by: Hakjoo Kim <ruppi.kim@hardkernel.com>
[AF: Rebased, style changes]
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Pavel Fedin <p.fedin@samsung.com>
[k.kozlowski: Move pinctrl nodes into soc node]
