The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
smdk5250 and smdk5420
This patch moves the display-timings node from fimd to dp to reflect the
device tree bindings change.
Signed-off-by: Sean Paul <seanpaul@chromium.org>
[tomeu.vizoso@collabora.com: Rebased]
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
HS400 timing values are added for SMDK5420, exynos5420-peach-pit
and exynos5800-peach-pi boards. This also adds RCLK GPIO line,
this gpio should be in pull-down state.
This also enables HS400 on peach-pi and this updates the clock
frequency to 800MHz to be set as input clock to controller.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
[alim.akhtar@samsung.com: addressed review comments]
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
The Exynos5420 SoC has 3 sets of 8 pads used as data lines for the 3
MMC/SD/SDIO slots. These needs to be muxed as SD_n_DATA instead of a
GPIO or external interrupt to allow the MMC controller to communicate
with the attached cards or SDIO devices.
Which data lines needs to be muxed as SD_n_DATA depends on the bus
width used for data transfer:
* bus-width = <1> needs SD_n_DATA[0]
* bus-width = <4> needs SD_n_DATA[0-3]
* bus-width = <8> needs SD_n_DATA[0-7]
The Exynos5250-pinctrl.dtsi file that defines the groups of pins has
SD_n_DATA[0] muxed for both sdn_bus1 and sdn_bus4 so just one of them
needs to be included in the device node's pinctrl property.
But Exynos5420-pinctrl has a different definition and only includes
SD_n_DATA[1-3] for sdn_bus4. So for a bus-width = <4>, both sdn_bus1
and sdn_bus4 have to be in the dev pinctrl to mux all the needed pads.
It seems all Exynos5420 boards had just cargo cult the pinctrl lines
assuming that sdn_bus4 also included SD_n_DATA[0] and it only works
because the bootloader muxes the pads correctly. But that is not the
case for the devices not used by the bootloader such as WiFi modules.
Add sdn_bus1 too in the nodes pinctrl to not rely on the bootloader.
Suggested-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
dw-mmc in exynos
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
[kgene.kim@samsung.com: rebased exynos5250-snow changes]
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Add MFC memory banks to Exynos5420 based SMDK and Arndale-octa boards.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Add required fixed-regulator for VBUS supply for USB 3.0
controller phy.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Add generic compatible strings to the respective board DT files.
Fixed voltage regulators required by audio codec added.
Some boards might not have RTC xtal, so RTC shouldn't really be
enabled by default. Enable it in the required board files.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
This patch adds the mmc device tree node entries for exynos5420 SOC.
Exynos5420 has a different version of DWMMC controller,so a new
compatible string is used to distinguish it from the prior SOC's.
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Add pinctrl node for hdmi hpd gpio pin to exynos5420 smdk board
file. hpd Gpio property is added to the hdmi node. This patch also
adds hdmi ddc node.
Both hdmi device and ddc i2c channel are enabled in
exynos5420-smdk5420.dts
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
Add pin state information for DP HPD support that requires pin configuration
support using pinctrl interface.
Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org>
Adds DP controller DT node to exynos5420 SoC
Adds FIMD DT node to exynos5420 based SMDK. Also adds display-timimg
information node.
Add initial device tree nodes for EXYNOS5420 SoC and SMDK5420 board.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
