git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Topic branch for adding Exynos 5410 Odroid XU board for v4.8.
This brings support for Hardkernel's Odroid XU board. It was the first
design with big.LITTLE SoC from Samsung: Exynos5410. The board is not
very popular. Newer XU3 and XU4 got more attention.
Board details:
1. Exynos5410 octa-core (A15+A7, however as of now only one cluster is
enabled),
2. 2 GB DDR3 RAM,
3. PowerVR SGX544MP3 GPU (not enabled in DTS),
4. USB 3.0 Host x 1, USB 3.0 OTG x 1, USB 2.0 Host x 4,
5. HDMI 1.4a, MIPI DSI and Display Port (Display Port not on all of
revisions though),
6. eMMC 4.5 and microSD slots.
* tag 'samsung-dt-odroid-xu-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux: (28 commits)
ARM: dts: exynos: Add watchdog and Security SubSystem to Exynos5410
ARM: dts: exynos: Configure PWM, usb3503, PMIC and thermal on Odroid XU board
ARM: dts: exynos: Add Thermal Management Unit to Exynos5410
ARM: dts: exynos: Interrupt for USB DWC3-1 differs between Exynos5420 and 5410
dt-bindings: clock: Add watchdog and SSS clock IDs to Exynos5410
dt-bindings: clock: Add TMU clock ID to Exynos5410
ARM: dts: exynos: Add RTC and I2C to Exynos5410
ARM: dts: exynos: Add I2C, PWM and UART pinctrl to Exynos5410
ARM: dts: exynos: Move HSI2C nodes to exynos54xx.dtsi
ARM: dts: exynos: Add initial support for Odroid XU board
ARM: dts: exynos: Add USB to Exynos5410
ARM: dts: exynos: Move common Exynos5410/542x/5800 nodes to new DTSI
ARM: dts: exynos: MCT is not an interrupt controller and extend length of iomap
ARM: dts: exynos: Enable UART3 on Exynos5410
ARM: dts: exynos: Include common exynos5 in exynos5410.dtsi
ARM: dts: exynos: Move Exynos5250 and Exynos5420 nodes under soc
ARM: dts: exynos: Use phandle to get parent node in exynos5250-snow
ARM: dts: exynos: Prepare for inclusion of exynos5.dtsi in exynos5410.dtsi
ARM: dts: exynos: Move common nodes to exynos5.dtsi
ARM: dts: exynos: Split Odroid XU3 LEDs to separate DTSI
Move watchdog and Security SubSystem nodes from exynos5420.dtsi to file
shared with Exynos5410 and configure the clocks on the latter.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
On Exynos5410 the SPI interrupt for second USB DWC3 (called DRD: Dual
Role Device) is different - 200 instead of 73.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
The USI/HSI2C nodes can be mostly shared between Exynos5420 and
Exynos5410 so move them to common DTSI.
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Move USB 3.0 DWC and 2.0 EHCI/OHCI nodes from exynos5420.dtsi to
exynos54xx.dtsi common for entire family. For Exynos542x/5800 this
should not have functional impact but for Exynos5410 this effectively
adds USB support.
The Exynos5410/542x/5800 are very similar designs. Create a new
DTSI with common nodes to remove DTS duplication. Although currently
only MCT and SysRAM are shared but in future more nodes will be added to
the common file.
The patch should not have functional impact.
Multi-Core Timer generates interrupts but it is not really an interrupt
controller so remove the "interrupt-controller" and "interrupt-cells"
properties. Additionally extend the length of mapped memory to cover all
registers (last SFR is at 0x0A40).
The conventions is to put SoC devices under 'soc' node. In fact other
our DTSes (like exynos3250.dtsi or exynos5410.dtsi) already follow it.
Adjust exynos5250 and exynos5420 DTSI to follow this convention. This is
also necessary for the upcoming change in exynos5410.dtsi to inherit
from common exynos5.dtsi.
Exynos5420 and Exynos5250 share some nodes: the PWM, syscon
(sysreg_system_controller) and first four I2C controllers. Move them to
parent DTSI to avoid duplication.
Since commit 218e1496135e ("i2c: exynos5: add support for HSI2C on
Exynos5260 SoC") the "samsung,exynos5-hsi2c" is deprecated in favor of
SoC version specific: "samsung,exynos5250-hsi2c".
The MFC IP is also inter-connected by an Async-Bridge so the CLK_ACLK333
has to be ungated during a power domain switch. Trying to do it when the
clock is gated will fail and lead to an imprecise external abort error
when the driver tries to access the MFC registers with the PD disabled.
For example, if the s5p-mfc module is removed and the MFC PD turned off:
[ 186.835606] Power domain power-domain@10044060 disable failed
[ 186.835671] s5p-mfc 11000000.codec: Removing 11000000.codec
[ 186.837670] Power domain power-domain@10044060 disable failed
And when the module is inserted again:
[ 2395.176956] s5p_mfc_wait_for_done_dev:34: Interrupt (dev->int_type:0, command:12) timed out
[ 2395.177031] s5p_mfc_init_hw:272: Failed to load firmware
[ 2395.177384] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 2395.177441] pgd = ec3b4000
[ 2395.177467] [00000000] *pgd=00000000
[ 2395.177507] Internal error: : 1406 [#1] PREEMPT SMP ARM
[ 2395.177550] Modules linked in: s5p_mfc mwifiex_sdio mwifiex uvcvideo s5p_jpeg v4l2_mem2mem videobuf2_vmalloc videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_core v4l2_common videodev media [last unloaded: s5p_mfc]
[ 2395.177774] CPU: 1 PID: 2382 Comm: v4l_id Tainted: G W 4.6.0-rc6-next-20160502-00010-g7730dc64d2c1-dirty #179
[ 2395.177857] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 2395.177906] task: ed275500 ti: e6c8c000 task.ti: e6c8c000
[ 2395.177996] PC is at s5p_mfc_reset+0x1c4/0x284 [s5p_mfc]
[ 2395.178057] LR is at s5p_mfc_reset+0x1a4/0x284 [s5p_mfc]
This patch fixes this issue by adding the CLK_ACLK333 as an Async-Bridge
clock for the MFC power domain, so the PD configuration works properly.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
This patch adds the AMBA bus nodes using VDD_INT for Exynos542x SoC.
Exynos542x has the following AMBA buses to translate data between
DRAM and sub-blocks.
Following list specifies the detailed correlation between sub-block and clock:
- CLK_DOUT_ACLK400_WCORE clock for WCORE's AXI
- CLK_DOUT_ACLK100_NOC for NoC (Network on Chip)'s AXI
- CLK_DOUT_PCLK200_FSYS for FSYS's APB
- CLK_DOUT_ACLK200_FSYS for FSYS's AXI
- CLK_DOUT_ACLK200_FSYS2 for FSYS2's AXI
- CLK_DOUT_ACLK333 for MFC's AXI
- CLK_DOUT_ACLK266 for GEN's AXI
- CLK_DOUT_ACLK66 for PERIC/PERIR's AXI
- CLK_DOUT_ACLK333_G2D for G2D's AXI
- CLK_DOUT_ACLK266_G2D for ACP's AXI
- CLK_DOUT_ACLK300_JPEG for JPEG's AXI
- CLK_DOUT_ACLK166 for JPEG's APB
- CLK_DOUT_ACLK300_DISP1 for FIMD's AXI
- CLK_DOUT_ACLK400_DISP1 for DISP1's AXI
- CLK_DOUT_ACLK300_GSCL for GSCL Scaler's AXI
- CLK_DOUT_ACLK400_MSCL for MSCL's AXI
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Tested-by: Markus Reichl <m.reichl@fivetechno.de>
Tested-by: Anand Moon <linux.amoon@gmail.com>
This patch adds the NoCP (Network on Chip Probe) Device Tree node
to measure the bandwidth of memory and g3d in Exynos542x SoC.
This patch changes the compatible of Exynos5420 fimd
to "exynos5420-fimd". To support MIC bypass from display
path, the new compatible is introduced for Exynos5420.
Cc: Inki Dae <inki.dae@samsung.com>
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
Fix following DTC warnings in all Exynos542x/5800 boards:
Warning (unit_address_vs_reg): Node /video-phy@10040728 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /video-phy@10040714 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /usb@12000000 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /usb@12000000/dwc3 has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /usb@12400000 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /usb@12400000/dwc3 has a reg or ranges property, but no unit name
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Add support for restoring GScaler parent clocks configuration when GSCL
power domain is turned on.
For Exynos542x/5800 platforms, add CPU operating points
for migrating from Exynos specific cpufreq driver to using
generic cpufreq driver.
Changes by Bartlomiej:
- split Exynos5420 support from the original patch
- merged Exynos5422 fixes from Ben
Changes by Ben Gamari:
- Port to operating-points-v2
Cc: Doug Anderson <dianders@chromium.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Andreas Faerber <afaerber@suse.de>
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Signed-off-by: Ben Gamari <ben@smart-cactus.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Exynos5420 and Exynos5800 boards boot from big core (A15) but
Exynos5422 boards choose otherwise: LITTLE core (A7) (on Exynos5422 this
is property of the board - configurable by pulling up/down gpg2-1).
To make user-visible CPU ordering more consistent the 'cpus' node was
overridden by exynos5422-cpus.dtsi.
However this is a little bit ugly and error-prone. Overriding the CPU
child nodes requires to basically reverse what was done initially in
exynos5420.dtsi.
Instead, split CPU configuration entirely to separate files which should
be included by board DTS.
Suggested-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Chanho Park <parkch98@gmail.com>
The s5p-sss crypto HW acceleration driver supports only AES algorithms
thus it accesses only registers from feeder (offset 0x0, length 0x100)
and AES (offset 0x200, length 0x100) blocks of Security SubSystem (SSS).
The exynos-rng Pseudo Random Number Generator driver accesses only PRNG
block at offset 0x400 (length 0x100).
Narrow the size of memory mapped by s5p-sss driver so both drivers can
be loaded at the same time.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
This patch adds device node for Rotator device and it's SYSMMU to Exynos
542x device tree file.
The sysmmu_fimd1_1 should bind the clock CLK_SMMU_FIMD1M1, not the clock
CLK_SMMU_FIMD1M0. CLK_SMMU_FIMD1M0 is a clock for the sysmmu_fimd1_0.
This wrong clock binding causes the problem that is blocked in iommu_map
function when IOMMU is enabled and exynos-drm driver tries to allocate
buffer via DMA mapping API on Odroid-XU3 board.
Fixes: b70045167815 ("ARM: dts: add sysmmu nodes for exynos5420")
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Cc: <stable@vger.kernel.org> # v4.2
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
The dtc compiler combines all the defined nodes that have the same path
so a device node definition can be in one file and later be extended in
another one.
That's the case of the Exynos5420 pinctrl device nodes that are defined
in the exynos5420.dtsi file and extended in exynos5420-pinctrl.dtsi.
But since the exynos5420.dtsi file includes the exynos5420-pinctrl.dtsi
before the pinctrl device nodes are actually defined, the definition of
the pinctrl device nodes happens in exynos5420-pinctrl.dtsi and are
extended in exynos5420.dtsi.
That is the opposite of the original intention so even when there is no
difference in practice, the exynos5420-pinctrl.dtsi include should be
moved at the end of the exynos5420.dtsi file after the pinctrl device
nodes have been already defined.
This will also allow to later change the exynos5420-pinctrl.dtsi file
to use labels instead of full paths to extend the pinctrl nodes. Since
keeping the include at the top, would cause a dtc build error due the
pinctrl labels not being defined yet.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
This patch adds System MMU nodes to all defined devices that are
specific to Exynos5420/5800/5422 series.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add nodes for jpeg codec in Exynos5420 SoC.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
[k.kozlowski: fixed up minor differences for applying]
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes. Additionally remove duplicated serial and uart labels
for serial.
Replace fixed parent with last parent (obtained with clk_get_parent())
of clocks for devices in mfc and disp power domains. This should improve
behavior if such clocks were reparented by the drivers and new parents
are different than those specified in DTS.
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Add MAX98090 audio codec, I2S interface and the sound nodes
to support audio on exynos5422-odroidxu3 board. Now we can
support audio using simple-audio-card DT binding.
Signed-off-by: Inha Song <ideal.song@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Since commit e4b3d38088df ("phy: exynos-video-mipi: Fix regression by
adding support for PMU regmap") the syscon property is required in
samsung,s5pv210-mipi-video-phy nodes, but this DTS hadn't been updated
yet.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Commit ea08de16eb1b ("ARM: dts: Add DISP1 power domain for exynos5420")
added a device node for the Exynos5420 DISP1 power domain but dit not
make the DP controller a consumer of that power domain.
This causes an "Unhandled fault: imprecise external abort" error if the
exynos-dp driver tries to access the DP controller registers and the PD
was turned off. This lead to a kernel panic and a complete system hang.
Make the DP controller device node a consumer of the DISP1 power domain
to ensure that the PD is turned on when the exynos-dp driver is probed.
Fixes: ea08de16eb1b ("ARM: dts: Add DISP1 power domain for exynos5420")
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
git://git.infradead.org/users/jcooper/linux into irq/core
irqchip core change for v4.1 (round 3) from Jason Cooper
Purge the gic_arch_extn hacks and abuse by using the new stacked domains
NOTE: Due to the nature of these changes, patches crossing subsystems have
been kept together in their own branches.
- tegra
- Handle the LIC properly
- omap
- Convert crossbar to stacked domains
- kill arm,routable-irqs in GIC binding
- exynos
- Convert PMU wakeup to stacked domains
- shmobile, ux500, zynq (irq_set_wake branch)
- Switch from abusing gic_arch_extn to using gic_set_irqchip_flags
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt
Merge "Samsung DT updates for v4.1" from Kukjin Kim:
- for exynos3250
: add assigned clock parents for CMU nodes
- for exynos4412-odroid
: add eMMC reset line
- for exynos5250
: fixed typo for interrupt-cells
- for exynos5250-snow
: define stdout-path property
: represent bridge and panel connection
: enable wifi power-on and add cap-sdio-irq to wifi mmc node
- for exynos5250-spring
- for exynos5420
: add async-bridge clocks for gsc and disp1 PDs
- for exynos5420 boards
: Mux XMMCnDATA[0] pad correctly
- for exynos5420-odroidxu3
- for Peach boards
: add HS400 support and define stdout-path property
: add mclk entry and add WiFi module support
* tag 'samsung-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: Fixed typo interrupt-cells for exynos5420 and exynos5250
ARM: dts: Add HS400 support for exynos5420 and exynos5800
ARM: dts: add async-bridge clocks to gsc power domain for exynos5420
ARM: dts: add async-bridge clocks to disp1 power domain for exynos5420
dt-bindings: add asynchronous bridge clock for exynos
ARM: dts: Define stdout-path property for exynos5250-spring
ARM: dts: Define stdout-path property for exynos5250-snow
ARM: dts: Define stdout-path property for Peach boards
ARM: dts: Add assigned clock parents to CMU node for exynos3250
ARM: dts: Add mclk entry for Peach boards
ARM: dts: Add WiFi module support for Peach boards
ARM: dts: Mux XMMCnDATA[0] pad correctly for Exynos5420 boards
ARM: dts: add eMMC reset line for exynos5422-odroidxu3
ARM: dts: add eMMC reset line for exynos4412-odroid-common
ARM: dts: represent bridge and panel connection for exynos5420-peach-pit
ARM: dts: represent bridge and panel connection for exynos5250-snow
ARM: dts: Add cap-sdio-irq to wifi mmc node for exynos5250-snow
ARM: dts: Enable wifi power-on for exynos5250-snow
Changes fixes the misspelled of #interrups-cell.
arch/arm/boot/dts/exynos5420.dtsi:224: WARNING: 'interrups'
may be misspelled - perhaps 'interrupts'?
Tested on OdroidXU3 board.
Signed-off-by: Anand Moon <linux.amoon@gmail.com>
[kgene@kernel.org: added fixing same typo in exynos5250]
Exynos has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the fact that the PMU block is actually the first
interrupt controller in the chain for RTC, kernels with this patch
applied wont have any suspend-resume facility when booted
with old DTs, and old kernels with updated DTs may not even boot.
Also, I strongly suspect that there is more than two wake-up
interrupts on these platforms, but I leave it to the maintainers
to fix their mess.
Link: https://lkml.kernel.org/r/1426088693-15724-2-git-send-email-marc.zyngier@arm.com
[ jac: squash in maz's fixup from
https://lkml.kernel.org/r/5506989D.9050703@arm.com ]
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Both GSCALER IPs in gsc power domain have async-bridges (to FIMD and MIXER),
therefore their clocks should be enabled during power domain switch.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
FIMD and MIXER IPs in disp1 power domain have async-bridges (to GSCALER),
Mixed block needs to control hdmi clock to properly perform power on/off
operation, so add 'hdmi' clock also to mixer nodes.
Presented device tree bindings provide data already hardcoded in the
exynos_tmu_data.c file.
After this commit, it should be possible to reuse common thermal core
framework in Exynos SoCs.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
The DISP1 power domain on Exynos5420 SoC includes the FIMD1, MIXER
and HDMI modules. Add a device node for this power domain and mark
these modules as consumer of the DISP1 power domain.
When a power domain is powered on and off, the input clocks of the
devices attached to it are reparented. So a reference to the input
and parent clocks of the devices are needed to manage that.
This patch replaces all custom samsung,power-domain dt
properties with generic power domain bindings and updates
documentation Samsung's devices referring to old binding.
Suggested-by: Kevin Hilman <khilman@kernel.org>
[javier.martinez@collabora.co.uk: tested on the Exynos5800 Peach Pi Chromebook]
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
Merge "Samsung fixes for v3.19" from Kukjin Kim:
- exynos_defconfig: enable LM90 driver and display panel support
- HWMON
- SENSORS_LM90
- Direct Rendering Manager (DRM)
- DRM bridge registration and lookup framework
- Parade ps8622/ps8625 eDP/LVDS bridge
- NXP ptn3460 eDP/LVDS bridge
- Exynos Fully Interactive Mobile Display controller (FIMD)
- Panel registration and lookup framework
- Simple panels
- Backlight & LCD device support
- use pmu_system_controller phandle for dp phy
: DP PHY requires pmu_system_controller to handle PMU reg. now
* tag 'samsung-fixes-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: exynos_defconfig: Enable LM90 driver
ARM: exynos_defconfig: Enable options for display panel support
arm: dts: Use pmu_system_controller phandle for dp phy
The arndale-octa board was giving "imprecise external aborts" during
boot-up with MCPM enabled. CCI enablement of the boot cluster was found
to be the cause of these aborts (possibly because the secure f/w was not
allowing it). Hence, disable CCI for the arndale-octa board.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
DP PHY now require pmu-system-controller to handle PMU register
to control PHY's power isolation. Adding the same to dp-phy
node.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging tree pull request for 3.19-rc1.
We continued to delete more lines than were added, always a good
thing, but not at a huge rate this release, only about 70k lines
removed overall mostly from removing the horrid bcm driver.
Lots of normal staging driver cleanups and fixes all over the place,
well over a thousand of them, the shortlog shows all the horrid
details.
The "contentious" thing here is the movement of the Android binder
code out of staging into the "real" part of the kernel. This is code
that has been stable for a few years now and is working as-is in the
tens of millions of devices with no issues. Yes, the code is horrid,
and the userspace api leaves a lot to be desired, but it's not going
to change due to legacy issues that we have no control over. Because
so many devices and companies rely on this, and the code is stable,
might as well promote it out of staging.
This was all discussed at the Linux Plumbers conference, and everyone
participating agreed that this was the best way forward.
There is work happening to replace the binder code with something new
that is happening right now, but I don't expect to see the results of
that work for another year at the earliest. If that ever happens, and
Android switches over to it, I'll gladly remove this version.
As for maintainers, I'll be glad to maintain this code, I've been
doing it for the past few years with no problems. I'll send a
MAINTAINERS entry for it before 3.19-final is out, still need to talk
to the Google developers about if they are willing to help with it or
not, last I checked they were, which was good.
All of these patches have been in linux-next for a while with no
reported issues"
* tag 'staging-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1382 commits)
Staging: slicoss: Fix long line issues in slicoss.c
staging: rtl8712: remove unnecessary else after return
staging: comedi: change some printk calls to pr_err
staging: rtl8723au: hal: Removed the extra semicolon
lustre: Deletion of unnecessary checks before three function calls
staging: lustre: fix sparse warnings: static function declaration
staging: lustre: fixed sparse warnings related to static declarations
staging: unisys: remove duplicate header
staging: unisys: remove unneeded structure
staging: ft1000 : replace __attribute ((__packed__) with __packed
drivers: staging: rtl8192e: Include "asm/unaligned.h" instead of "access_ok.h" in "rtl819x_BAProc.c"
Drivers:staging:rtl8192e: Fixed checkpatch warning
Drivers:staging:clocking-wizard: Added a newline
staging: clocking-wizard: check for a valid clk_name pointer
staging: rtl8723au: Hal_InitPGData() avoid unnecessary typecasts
staging: rtl8723au: _DisableAnalog(): Avoid zero-init variables unnecessarily
staging: rtl8723au: Remove unnecessary wrapper _ResetDigitalProcedure1()
staging: rtl8723au: _ResetDigitalProcedure1_92C() reduce code obfuscation
staging: rtl8723au: Remove unnecessary wrapper _DisableRFAFEAndResetBB()
staging: rtl8723au: _DisableRFAFEAndResetBB8192C(): Reduce code obfuscation
This patch adds syscon based phandle to i2c device nodes of exynos5250
and exynos5420. These phandles will be used to save restore i2c sysreg
configuration register during s2r from i2c driver.
CC: Rob Herring <robh+dt@kernel.org>
CC: Randy Dunlap <rdunlap@infradead.org>
CC: Russell King <linux@arm.linux.org.uk>
CC: devicetree@vger.kernel.org
CC: linux-doc@vger.kernel.org
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
First round of new drivers, features and cleanups for IIO in the 3.19 cycle.
New drivers / supported parts
* rockchip - rk3066-tsadc variant
* si7020 humidity and temperature sensor
* mcp320x - add mcp3001, mcp3002, mcp3004, mcp3008, mcp3201, mcp3202
* bmp280 pressure and temperature sensor
* Qualcomm SPMI PMIC current ADC driver
* Exynos_adc - support exynos7
New features
* vf610-adc - add temperature sensor support
* Documentation of current attributes, scaled pressure, offset and
scaled humidity, RGBC intensity gain factor and scale applied to
differential voltage channels.
* Bring iio_event_monitor up to date with newer modifiers.
* Add of_xlate function to allow for complex channel mappings from the
device tree.
* Add -g parameter to generic_buffer example to allow for devices with
directly fed (no trigger) buffers.
* Move exynos driver over to syscon for PMU register access.
Cleanups, fixes for new drivers
* lis3l02dq drop an unneeded else.
* st sensors - renam st_sensors to st_sensor_settings (for clarity)
* st sensors - drop an unused parameter from all the probe utility
functions.
* vf610 better error handling and tidy up.
* si7020 - cleanups following merge
* as3935 - drop some unnecessary semicolons.
* bmp280 - fix the pressure calculation.
