commit e8e94ed6285428ab780cd7b0df4622f71eceb39e upstream.
In order to get iio-hwmon support, the lradc must be declared as an
iio provider. So fix this issue by adding the #io-channel-cells property.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Fixes: bd798f9c7b30 ("ARM: dts: mxs: Add iio-hwmon to mx23 soc")
Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
We need to use controller id to access different register regions
for mxs phy.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
This allows to read the SoC on-die temperature sensor available on the LRADC by
using:
cat /sys/class/hwmon/hwmon0/device/temp1_input
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Enable the DCP by default on both i.MX23 and i.MX28.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: devicetree@vger.kernel.org
Pull ARM SoC DT updates from Olof Johansson:
"Most of this branch consists of updates, additions and general churn
of the device tree source files in the kernel (arch/arm/boot/dts).
Besides that, there are a few things to point out:
- Lots of platform conversion on OMAP2+, with removal of old board
files for various platforms.
- Final conversion of a bunch of ux500 (ST-Ericsson) platforms as
well
- Some updates to pinctrl and other subsystems. Most of these are
for DT-enablement of the various platforms and acks have been
collected"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits)
ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts
ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx)
ARM: dts: bcm281xx: Add card detect GPIO
ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt)
ARM: bcm281xx: Add device node for the GPIO controller
ARM: mvebu: Add Netgear ReadyNAS 104 board
ARM: tegra: fix Tegra114 IOMMU register address
ARM: kirkwood: add support for OpenBlocks A7 platform
ARM: dts: omap4-panda: add DPI pinmuxing
ARM: dts: AM33xx: Add RNG node
ARM: dts: AM33XX: Add hwspinlock node
ARM: dts: OMAP5: Add hwspinlock node
ARM: dts: OMAP4: Add hwspinlock node
ARM: dts: use 'status' property for PCIe nodes
ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C
ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes
ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts
ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts
ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts
ARM: mvebu: Add the core-divider clock to Armada 370/XP
The delay units inside the LRADC depend on the presence of a 2 kHz clock.
This change enables the clock to be able to use the delay unit for the
touchscreen part of the driver.
Signed-off-by: Juergen Beisert <jbe@pengutronix.de>
Tested-by: Marek Vasut <marex@denx.de>
Tested-by: Lothar Waßmann <LW@KARO-electronics.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Convert mx23/mx28 dts files to use the padconfig defintions from
mxs-pinfunc.h.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Convert mx23/mx28 dts filed to use the pinctrl header files.
NOTE: During automatic conversion of these files to use the pinconfig
definitions an inconsistency has been found in:
arch/arm/boot/dts/imx28-apx4devkit.dts
According to the comment the function for pad SSP2_SS0 should have
been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131
represents: MX28_PAD_SSP2_SS0__AUART3_TX
I used the later (though probably wrong) definition because that's
what is actually being used in the DTB.
After providing spi alias, we can get the following message during probe:
m25p80 spi1.0: sst25vf016b (2048 Kbytes)
,which looks better than the original one:
m25p80 spi32766.0: sst25vf016b (2048 Kbytes)
While at it, keep the alias entries in alphabetical order.
After mxs-dma driver adopts generic DMA device tree binding, channel
interrupt number is defined in DMA controller node, and channel ID is
listed in "dmas" property. So the DMA channel interrupt number in
client nodes' "interrupts" property and fsl,<module>-dma-channel which
are used by old customized DMA binding can be removed now.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
This patch updates the in-kernel dts files according to the latest cpus
and cpu bindings updates for ARM.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Add generic DMA device tree binding for mxs-dma. The changes include:
* Add channel interrupts into DMA controller nodes
* Add properties '#dma-cells' and 'dma-channels' for DMA controller nodes
* And properties 'dmas' and 'dma-names' for DMA client nodes
* Update mxs-dma device tree binding doc
Instead of using the static definitions, get ocotp base address from
device tree with mapping.
Instead of using static address definition, get reset address from
device tree with mapping, so that core_initcall mxs_arch_reset_init()
can be killed.
The "rtc" clock code in mxs_arch_reset_init() seems to be zombie, since
there is no clk lookup defined in clock driver at all. Remove it
together.
Instead of using the static definitions, get clkctrl and digctl base
addresses with mapping from device tree.
Use macro on variable is not nice, but it's done here to save huge
pointless diff stat.
Acked-by: Mike Turquette <mturquette@linaro.org>
Change call clk_get_sys() to of_clk_get() to look up timrot clock from
device tree, so that the clk_register_clkdev() call for timrot can be
saved in clock driver.
Add interrupt mapping and compatible string for MX23 LRADC.
into next/dt
From Shawn Guo:
They are a few mxs dts updates coming a little bit late. I'm sending
them as the second mxs/dt pull request for 3.8. Please consider to
pull.
* tag 'mxs-dt-3.8-2' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: dts: mxs: add oled support for the cfa-10036
ARM: mxs: Add SchulerControl SPS1 DTS file
ARM: imx23-olinuxino: Add spi support
imx23-olinuxino board has spi pins exposed on external connector.
This patch add spi support.
Signed-off-by: Fadil Berisha <f.koliqi@gmail.com>
The current DT nodes for mx23/mx28 miss the `clocks-names` item for gpmi-nand.
So the gpmi-nand driver could not find the proper clock.
This patch fixes this issue.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Pull ARM soc-specific updates, take 2 from Olof Johansson:
"This branch converts the MXS Freescale platform to use irqdomains and
sparse IRQ, in preparation for DT probing and multiplatform kernels."
* tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: mxs: remove mach/irqs.h
ARM: mxs: select SPARSE_IRQ
ARM: mxs: adopt irq_domain support for icoll driver
ARM: mxs: select MULTI_IRQ_HANDLER
ARM: mxs: retrieve timer irq from device tree
gpio/mxs: adopt irq_domain support for mxs gpio driver
Add USB resources for mx23.
It really becomes a maintenance issue that every time a device needs
to look up (clk_get) a clock we have to patch kernel clock file to call
clk_register_clkdev for that clock.
Since clock DT support which is meant to resolve clock lookup in device
tree is in place, the patch moves imx23 client devices' clock lookup
over to device tree, so that any new lookup to be added at later time
can just get done in DT instead of kernel.
Remove irq_domain_add_legacy call from mach-mxs.c and have icoll adopt
irq_domain support in the driver.
Rather than using the static timer irq definition, we should retrieve
timer irq from device tree for better.
Instead of assigning SSP1_DETECT inside mmc0_4bit_pins_a, let the board dts
handle this setup.
Not every board will use MX23_PAD_SSP1_DETECT as SSP1 functionality.
Add AUART0 support.
Fix registers range.
Cc: stable@vger.kernel.org
Add DT node for gpmi nand.
Also add pinctrl for gpmi nand.
Enable the gpmi-nand in mx23-evk board.
Add lcd support for imx23-evk and imx28-evk.
Add pwm device and pwm-backlight for imx23-evk and imx28-evk.
Enable rtc for imx23 and imx28.
Add auart device for imx23-evk board.
The 8-bit mode mmc has pin conflicts with display. Let's use 4-bit
mode by default, so that display can be enabled together later.
Also add vmmc-supply for mmc device.
Add comments for pinmux-ids so that we do not have to keep looking at
Documentation/devicetree/bindings/pinctrl/fsl,mxs-pinctrl.txt to read
all these pinmux-ids.
Replace "gpmi" with "gpmi-nand" to get the
GPMI interface probing with DT instead of
failing to get clock.
Cc: Detlev Zundel <dzu@denx.de>
CC: Dong Aisheng <b29396@freescale.com>
CC: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Linux ARM kernel <linux-arm-kernel@lists.infradead.org>
It adds gpio support for device tree boot.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Huang Shijie <b32955@freescale.com>
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
Acked-by: Vinod Koul <vinod.koul@intel.com>
It adds initial device tree support for imx23-evk board, and only
serial console is enabled.
