2014-07-18 | ARM: dts: imx: remove ssi fsl,mode for audio cards | Markus Pargmann | |
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com> | |||
2014-04-30 | ARM: dts: mbimxsd25 baseboard: Add USB support | Denis Carikli | |
Signed-off-by: Denis Carikli <denis@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com> | |||
2014-02-09 | ARM: dts: Add support for the cpuimx25 board from Eukrea and its baseboard. | Denis Carikli | |
The following devices/functionalities were added: * Main and secondary UARTs. * i2c and the pcf8563 device. * Ethernet. * NAND. * The BP1 button. * The LED. * Watchdog * SD. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: devicetree@vger.kernel.org Cc: Sascha Hauer <kernel@pengutronix.de> Cc: linux-arm-kernel@lists.infradead.org Cc: Eric BĂ©nard <eric@eukrea.com> Signed-off-by: Denis Carikli <denis@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> |
