path: root/arch/arm/boot/dts/imx27-apf27.dts
2014-04-14ARM: dts: imx: add required #clock-cells for fixed-clockShawn Guo
Per bindings of fixed-clock, #clock-cells is a required property. Let's add it for those fixed rate clocks. Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-09ARM: dts: imx27: imx27-apf27: add pinctrl for fec and uart1Gwenhael Goavec-Merou
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: imx: use #include for all device treesShawn Guo
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT files, so that gcc -E handles the entire include tree, and hence any of those files can #include some other file e.g. for constant definitions. This allows future use of #defines and header files in order to define names for various constants, such as pinctrl settings. Use of those features will increase the readability of the device tree files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-02-10ARM: dts: imx: use nodes label in board dtsShawn Guo
Following omap3-evm.dts way, it changes all imx dts files to use label in board dts to refer to nodes defined by soc dtsi. Thus, the board dts files become easier to read and edit with the least indentation levels. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-11-16Add device tree file for the armadeus apf27Philippe Reynes
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Signed-off-by: Eric Jarrige <eric.jarrige@armadeus.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
