path: root/arch/arm/boot/dts/imx27-pinfunc.h
2014-07-11pinctrl: i.MX27: Remove nonexistent pad definitionsAlexander Shiyan
Pads for PB0-PB3, PC0-PC4, PE26-PE31 and PF24-PF31 does not exist on the i.MX27 SOC. There is no reason to define them, the presence of such definitions in the DTS files is a bug. This patch removes these nonexistent pad definitions. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-02-09ARM: dts: i.MX27: Configure GPIOs as "input" by defaultAlexander Shiyan
This patch changes the default direction for pins used as GPIO to "input". This prevents a short circuit on the configuration stage when GPIO-pin is connected to the other output pin. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27 pin functionsMarkus Pargmann
Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
