path: root/arch/arm/boot/dts/imx27.dtsi
2015-11-18ARM: dts: imx27.dtsi: change the clock information for usbPeter Chen
For imx27, it needs three clocks to let the controller work, the old code is wrong, and usbmisc has not included clock handling code any more. Without this patch, it will cause below data abort when accessing usbmisc registers. usbcore: registered new interface driver usb-storage Unhandled fault: external abort on non-linefetch (0x008) at 0xf4424600 pgd = c0004000 [f4424600] *pgd=10000452(bad) Internal error: : 8 [#1] PREEMPT ARM Modules linked in: CPU: 0 PID: 1 Comm: swapper Not tainted 4.1.0-next-20150701-dirty #3089 Hardware name: Freescale i.MX27 (Device Tree Support) task: c7832b60 ti: c783e000 task.ti: c783e000 PC is at usbmisc_imx27_init+0x4c/0xbc LR is at usbmisc_imx27_init+0x40/0xbc pc : [<c03cb5c0>] lr : [<c03cb5b4>] psr: 60000093 sp : c783fe08 ip : 00000000 fp : 00000000 r10: c0576434 r9 : 0000009c r8 : c7a773a0 r7 : 01000000 r6 : 60000013 r5 : c7a776f0 r4 : c7a773f0 r3 : f4424600 r2 : 00000000 r1 : 00000001 r0 : 00000001 Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 0005317f Table: a0004000 DAC: 00000017 Process swapper (pid: 1, stack limit = 0xc783e190) Stack: (0xc783fe08 to 0xc7840000) Signed-off-by: Peter Chen <peter.chen@freescale.com> Reported-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: <stable@vger.kernel.org> #v4.1+ Acked-by: Shawn Guo <shawnguo@kernel.org>
2015-09-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Ladies and gentlemen, we proudly announce to you the latest branch of ARM device tree contents for the mainline kernel. Come and see, come and see! No less than twentythree thousand lines of additions! Just imagine the joy you will have of using your mainline kernel on newly supported hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or UniPhier hardware! For those of you feeling less adventurous, added hardware support on platforms such as TI DM814x and Gumstix Overo platforms might be more of your liking. We've got something for everyone here! Ahem. Cough. So, anyway... This is the usual large batch of DT updates. Lots and lots of smaller changes, some of the larger ones to point out are: - Rockchip veyron (Chromebook) support, as well as several other new boards - DRM support on Atmel AT91SAM9N12EK - USB additions on some Allwinner platforms - Mediatek MT6580 support - Freescale i.MX6UL support - cleanups for Renesas shmobile platforms - lots of added devices on LPC18xx - lots of added devices and boards on UniPhier There's also some dependent code added here, in particular some branches that are primarily merged through the clock tree" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits) ARM: tegra: Add gpio-ranges property ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114 ARM: tegra: Add Tegra124 PMU support ARM: tegra: jetson-tk1: Add GK20A GPU DT node ARM: tegra: venice2: Add GK20A GPU DT node ARM: tegra: Add IOMMU node to GK20A ARM: tegra: Add CPU regulator to the Jetson TK1 device tree ARM: tegra: Add entries for cpufreq on Tegra124 ARM: tegra: Enable the DFLL on the Jetson TK1 ARM: tegra: Add the DFLL to Tegra124 device tree ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller. ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes ARM: dts: rockchip: correct regulator power states for suspend ARM: dts: rockchip: correct regulator PM properties ARM: dts: vexpress: Use assigned-clock-parents for sp810 pinctrl: tegra: Only set the gpio range if needed arm: boot: dts: am4372: add ARM timers and SCU nodes ARM: dts: AM4372: Add the am4372-rtc compatible string ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain ...
2015-08-11ARM: dts: imx27: add support of internal rtcPhilippe Reynes
Add support of internal rtc on imx27. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-08ARM: dts: imx27: Adjust the GPT compatible stringFabio Estevam
include/soc/imx/timer.h describes well the different versions of the GPT block among the imx family: enum imx_gpt_type { GPT_TYPE_IMX1, /* i.MX1 */ GPT_TYPE_IMX21, /* i.MX21/27 */ GPT_TYPE_IMX31, /* i.MX31/35/25/37/51/6Q */ GPT_TYPE_IMX6DL, /* i.MX6DL/SX/SL */ }; So the proper compatible string for the MX27 case should be "fsl,imx21-gpt". Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-05-14ARM: dts: imx27: only map 4 Kbyte for fec registersPhilippe Reynes
According to the imx27 documentation, fec has a 4 Kbyte memory space map. Moreover, the actual 16 Kbyte mapping overlaps the SCC (Security Controller) memory register space. So, we reduce the memory register space to 4 Kbyte. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Fixes: 9f0749e3eb88 ("ARM i.MX27: Add devicetree support") Cc: <stable@vger.kernel.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: imx: Add dr_mode host setting to all host-only usb instancesMatt Porter
The chipidea driver adds an extra line of spam to the log when a host-only chipidea instance is left set to the default of a dual role controller. [ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget Set the dr_mode property to host on all the host-only nodes to avoid this warning. Signed-off-by: Matt Porter <mporter@konsulko.com> Acked-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-01-05ARM: dts: imx: Update VPU compatible stringsFabio Estevam
Update the VPU compatible strings to also use "cnm,coda<model>". Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-07-18ARM: i.MX27 clk: dts: Use clock defines in DTS filesAlexander Shiyan
Use clock definitions in i.MX27 DTS files. Additional changes included in this patch (imx27.dtsi): - Fix IPG clock for UART6. - Use EMI_AHB_GATE clock for WEIM. - Added GPIO_IPG_GATE clock for GPIO nodes. Currently this clock is not used by the driver, but it can be added in the future. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27-pdk: Add keypad supportFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27: Place the usb phy nodes in the board dts filesFabio Estevam
It is not a good approach to have the USB PHY nodes inside imx27.dtsi since the USB PHYs on mx27 are not internal to the SoC. Place the USB PHY nodes in the board dts files instead. Also, each board may have a different clock source for the USB PHY, so do not hardcode it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27: Use the correct usb clock gateFabio Estevam
USB Host1, Host2 and OTG are gated via 'usb_ipg_gate' clock, so fix it in order to avoid the following kernel oops: usbcore: registered new interface driver usb-storage 10024000.usb supply vbus not found, using dummy regulator Unhandled fault: external abort on non-linefetch (0x808) at 0xf4424184 Internal error: : 808 [#1] PREEMPT ARM Modules linked in: CPU: 0 PID: 1 Comm: swapper Not tainted 3.15.0-rc1-26325-g971f9fd-dirty #64 task: c7829aa0 ti: c7836000 task.ti: c7836000 PC is at ci_hdrc_probe+0x3a4/0x634 LR is at ci_hdrc_probe+0x100/0x634 pc : [<c036cc78>] lr : [<c036c9d4>] psr: 60000013 sp : c7837d48 ip : 00000001 fp : 00000000 r10: 00000000 r9 : 00000000 r8 : c791b6c0 r7 : c7945000 r6 : f4424000 r5 : c7945010 r4 : c794e010 r3 : f4424184 r2 : 00000000 r1 : 8c000004 r0 : 0c000004 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 0005317f Table: a0004000 DAC: 00000017 Process swapper (pid: 1, stack limit = 0xc78361c0) Stack: (0xc7837d48 to 0xc7838000) Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-04-30ARM: dts: imx: Add alias for ethernet controllerMarek Vasut
Add alias for FEC ethernet on i.MX to allow bootloaders (like U-Boot) patch-in the MAC address for FEC using this alias. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-04-14ARM: dts: imx: add required #clock-cells for fixed-clockShawn Guo
Per bindings of fixed-clock, #clock-cells is a required property. Let's add it for those fixed rate clocks. Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-24ARM: dts: i.MX27: Add USB nodesAlexander Shiyan
This patch adds the missing (Universal serial bus) USB devicetree nodes for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: i.MX27: Add SSI nodesAlexander Shiyan
This patch adds the missing (Synchronous Serial Interface) SSI1 & SSI2 devicetree nodes for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: i.MX27 boards: Switch to use standard GPIO and IRQ flags definitionsAlexander Shiyan
2014-02-09ARM: dts: imx27 phyCARD-S pinctrlMarkus Pargmann
Add pinctrl nodes and properties for phyCARD-S device nodes. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27 iomux device nodeMarkus Pargmann
This patch adds a iomux node for imx27 pinctrl driver. The gpio registers are embedded in the iomux memory area. So this patch moves them into the iomux node for a better hardware description. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-10-18ARM: imx27: add missing #pwm-cells propertySteffen Trumtrar
The pwm-node is missing its #pwm-cells property. The pwm-framework will complain about this. Add the missing property. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-17ARM: imx27.dtsi: fix CSPI PER clock idGwenhael Goavec-Merou
CSPI PER clock is per2clk (per2_gate id 60) instead of cspiX_ipg_gate. Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Disable AUDMUX in the templateAlexander Shiyan
AUDMUX expects additional parameters to be configured correctly, so turn it off into a template. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Remove clock name from CPU nodeAlexander Shiyan
Clock name is not needed for "cpufreq-cpu0". Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Increase "clock-latency" valueAlexander Shiyan
i.MX27 CPU can be clocked with a 32 kHz quartz, and not just 32768 Hz, so increase "clock-latency" value, which will ensure that we use two clock cycles on frequency change. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Add label to CPU nodeAlexander Shiyan
Add a label to i.MX27 CPU node. This change allows the reuse this node in the upper levels of the DTS. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Remove optional "ptp" clock source for FECAlexander Shiyan
Patch removes optional "ptp" clock source for FEC. This clock is missing in i.MX27. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Using "wdog_ipg_gate" clock source for watchdogAlexander Shiyan
Patch replaces "dummy" clock source for watchdog with "wdog_ipg_gate". Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27: Add core voltagesAlexander Shiyan
This patch adds core voltages for i.MX27 CPUs. Only 266 and 400 MHz modes is documented in the datasheet, so we add a 266 MHz frequency for conform this. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Add WEIM nodeAlexander Shiyan
This patch adds the missing (Wireless External Interface Module) WEIM devicetree node for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Move IIM node under AIPI2 busAlexander Shiyan
This patch moves IIM node under AIPI2 bus, since this is proper location for this module. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27 cpufreq-cpu0 frequenciesMarkus Pargmann
Set operating-points for imx27. There is no regulator support, so the voltages are 0. The frequencies should be the same for all imx27 boards, so it is defined here and can be overwritten if necessary. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27: Add 1-wireMarkus Pargmann
2013-08-22ARM: dts: imx27: Add imx framebuffer deviceMarkus Pargmann
2013-08-22ARM: imx27: Use 'AITC' for the interrupt controller nameFabio Estevam
On the MX27 Reference Manual the interrupt controller is named AITC: ARM926EJ-S Interrupt Controller So use the AITC term instead of AVIC. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Origin: id:1334193132-18944-2-git-send-email-festevam@gmail.com Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Add i2c aliasesSascha Hauer
This allows to order the i2c devices correctly. While at it reorder the aliases entries alphabetically. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX27: Add iim nodeSascha Hauer
2013-08-22ARM: dts: imx27: Add kpp devicetree nodeAlexander Shiyan
This patch adds the missing (Keypad Port) KPP devicetree node for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <eagle.alexander923@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27: Sort entries by addressAlexander Shiyan
2013-08-22ARM: dts: imx27: Rename PWM devicetree nodeAlexander Shiyan
i.MX27 have only one PWM, so index from PWM devicetree node removed. Signed-off-by: Alexander Shiyan <eagle.alexander923@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27: Add AUDMUX devicetree nodeAlexander Shiyan
This patch adds the missing (Digital Audio MUX) AUDMUX devicetree node for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <eagle.alexander923@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27: Add SAHARA2 devicetree nodeAlexander Shiyan
This patch adds the missing (Symmetric/Asymmetric Hashing and Random Accelerator) SAHARA2 devicetree node for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <eagle.alexander923@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: imx27: Add VPU devicetree nodeAlexander Shiyan
This patch adds the missing VPU devicetree node for i.MX27 CPUs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: i.MX27: Add SDHC devicetree nodesAlexander Shiyan
This patch adds the missing SDHC devicetree nodes for i.MX27 SoCs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutonix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: i.MX27: Add DMA devicetree nodeAlexander Shiyan
This patch adds the missing DMA devicetree node for i.MX27 SoCs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutonix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: Add aliases for i.MX27 SPI controllerAlexander Shiyan
Add aliases to determine the proper SPI bus number. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: imx27: Add PWM0 to device treeGwenhael Goavec-Merou
2013-05-24ARM: dts: imx: fix clocks for cspiJonas Andersson
The CSPI controller has only one clock, but the driver spi-imx.c needs clock "per" to calculate bitrate divisor. Signed-off-by: Jonas Andersson <jonas@microbit.se> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: i.MX27: Add clocks to GPT devicetree nodesSascha Hauer
2013-04-09ARM: i.MX27: Add GPT devicetree nodesSascha Hauer
The GPT is the GPT timer found on i.MX SoCs. This adds the missing GPT devicetree nodes. Also fixup the watchdog register map size along the way. it's 0x1000, not 0x4000. This didn't hurt before as the region was not occupied by another device, but now overlaps with the GPT. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: mx27: Replace clk_register_clkdev with clock DT lookupFabio Estevam
Similarly as it was done for mx6q, use a DT lookup in order to make maintainance task for the clock devices easier. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: imx: use #include for all device treesShawn Guo
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT files, so that gcc -E handles the entire include tree, and hence any of those files can #include some other file e.g. for constant definitions. This allows future use of #defines and header files in order to define names for various constants, such as pinctrl settings. Use of those features will increase the readability of the device tree files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
