path: root/arch/arm/boot/dts/imx28.dtsi
2015-10-19ARM: mxs: enable ocotp for i.MX23 and i.MX28Stefan Wahren
This patch enables On Chip OTP support for i.MX23 and i.MX28 SoCs, but keeps the old compatible string. Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-04-27ARM: dts: imx28: Fix AUART4 TX-DMA interrupt nameMarek Vasut
Fix a typo in the TX DMA interrupt name for AUART4. This patch makes AUART4 operational again. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: f30fb03d4d3a ("ARM: dts: add generic DMA device tree binding for mxs-dma") Cc: stable@vger.kernel.org Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: imx28: add alternative pinmuxing for spi3Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-03-30ARM: dts: imx: Add dr_mode host setting to all host-only usb instancesMatt Porter
The chipidea driver adds an extra line of spam to the log when a host-only chipidea instance is left set to the default of a dual role controller. [ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget Set the dr_mode property to host on all the host-only nodes to avoid this warning. Signed-off-by: Matt Porter <mporter@konsulko.com> Acked-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-09-16ARM: dts: imx28: add alternative pinmuxing for i2c1Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: dts: imx28: add pinmuxing for mmc1Marc Kleine-Budde
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> [ukl: rebase from ancient kernel version] Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx28: include gpio.h to allow use of symbolic namesMichael Heimpold
Signed-off-by: Michael Heimpold <mhei@heimpold.de> Acked-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-09ARM: dts: mxs: add mxs phy controller idPeter Chen
We need to use controller id to access different register regions for mxs phy. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: mxs: Add iio-hwmon to mx28 socAlexandre Belloni
This allows to read the SoC on-die temperature sensor available on the LRADC by using: cat /sys/class/hwmon/hwmon0/device/temp1_input Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: mxs: add #io-channel-cells to mx28 lradcAlexandre Belloni
Adding #io-channel-cells property to lradc allows us to use the lradc as an iio provider. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: i.MX28: dts: rename usbphy pin namesMichael Grzeschik
The pins have nothing todo with the phy layer. We better rename them, so it gets clear they are routed to the ehci core not to any phy. Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: mxs: Add a new pin config for the usb0 ID.Denis Carikli
Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: Eric Bénard <eric@eukrea.com> Signed-off-by: Denis Carikli <denis@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: mxs: Add 18bit pin config for lcdif.Denis Carikli
2014-02-09ARM: dts: mxs: add auart2 pinmux to imx28.dtsiAida Mynzhasova
Add auart2 pins configuration on its main pads Signed-off-by: Aida Mynzhasova <aida.mynzhasova@skitlab.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-01-05ARM: mxs: dts: Enable DCP for MXSMarek Vasut
Enable the DCP by default on both i.MX23 and i.MX28. Signed-off-by: Marek Vasut <marex@denx.de> Cc: David S. Miller <davem@davemloft.net> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: devicetree@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-11-11Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Most of this branch consists of updates, additions and general churn of the device tree source files in the kernel (arch/arm/boot/dts). Besides that, there are a few things to point out: - Lots of platform conversion on OMAP2+, with removal of old board files for various platforms. - Final conversion of a bunch of ux500 (ST-Ericsson) platforms as well - Some updates to pinctrl and other subsystems. Most of these are for DT-enablement of the various platforms and acks have been collected" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits) ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx) ARM: dts: bcm281xx: Add card detect GPIO ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt) ARM: bcm281xx: Add device node for the GPIO controller ARM: mvebu: Add Netgear ReadyNAS 104 board ARM: tegra: fix Tegra114 IOMMU register address ARM: kirkwood: add support for OpenBlocks A7 platform ARM: dts: omap4-panda: add DPI pinmuxing ARM: dts: AM33xx: Add RNG node ARM: dts: AM33XX: Add hwspinlock node ARM: dts: OMAP5: Add hwspinlock node ARM: dts: OMAP4: Add hwspinlock node ARM: dts: use 'status' property for PCIe nodes ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts ARM: mvebu: Add the core-divider clock to Armada 370/XP ...
2013-10-01Staging/iio/adc/touchscreen/MXS: add proper clock handlingJuergen Beisert
The delay units inside the LRADC depend on the presence of a 2 kHz clock. This change enables the clock to be able to use the delay unit for the touchscreen part of the driver. Signed-off-by: Juergen Beisert <jbe@pengutronix.de> Tested-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-27ARM: dts: mxs: Add muxing options for the SSP2 MMCMarek Vasut
Add pinmux for 4-bit SD card connected to SSP2. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-26ARM: dts: mxs: convert usb0_id_pins_a to use symbolic pin defsLothar Waßmann
This pin definition had been added after the initial patch to use symbolic pin names in DTS files. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-26ARM: dts: mxs: modify mx23/mx28 dts files to use padconfig definesLothar Waßmann
Convert mx23/mx28 dts files to use the padconfig defintions from mxs-pinfunc.h. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-26ARM: dts: mxs: modify mx23/mx28 dts files to use pinctrl headersLothar Waßmann
Convert mx23/mx28 dts filed to use the pinctrl header files. NOTE: During automatic conversion of these files to use the pinconfig definitions an inconsistency has been found in: arch/arm/boot/dts/imx28-apx4devkit.dts According to the comment the function for pad SSP2_SS0 should have been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131 represents: MX28_PAD_SSP2_SS0__AUART3_TX I used the later (though probably wrong) definition because that's what is actually being used in the DTB. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-26ARM: dts: imx28-evk: Allow usb peripheral mode to workFabio Estevam
Testing g_ether results in the following: [ 1.648022] using random self ethernet address [ 1.652778] using random host ethernet address [ 1.660504] usb0: HOST MAC c6:28:6a:81:dc:ff [ 1.666360] usb0: MAC 7e:81:54:16:c0:c6 [ 1.670504] using random self ethernet address [ 1.675842] using random host ethernet address [ 1.682655] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 1.689332] g_ether gadget: g_ether ready [ 3.328974] irq 237: nobody cared (try booting with the "irqpoll" option) [ 3.335831] CPU: 0 PID: 1 Comm: swapper Not tainted 3.11.0-rc6-next-20130819 #1035 [ 3.343500] [<c0014258>] (unwind_backtrace+0x0/0xf0) from [<c0011b20>] (show_stack+0x10/0x14) [ 3.352098] [<c0011b20>] (show_stack+0x10/0x14) from [<c006af4c>] (__report_bad_irq+0x20/0xc0) [ 3.360763] [<c006af4c>] (__report_bad_irq+0x20/0xc0) from [<c006b3f4>] (note_interrupt+0x1d4/0x234) [ 3.369943] [<c006b3f4>] (note_interrupt+0x1d4/0x234) from [<c0069754>] (handle_irq_event_percpu+0xc4/0x268) [ 3.379815] [<c0069754>] (handle_irq_event_percpu+0xc4/0x268) from [<c0069934>] (handle_irq_event+0x3c/0x5c) [ 3.389686] [<c0069934>] (handle_irq_event+0x3c/0x5c) from [<c006bb78>] (handle_level_irq+0x8c/0xe8) [ 3.398865] [<c006bb78>] (handle_level_irq+0x8c/0xe8) from [<c0068ff0>] (generic_handle_irq+0x20/0x30) [ 3.408213] [<c0068ff0>] (generic_handle_irq+0x20/0x30) from [<c000fc9c>] (handle_IRQ+0x30/0x84) [ 3.417040] [<c000fc9c>] (handle_IRQ+0x30/0x84) from [<c0012564>] (__irq_svc+0x44/0x54) [ 3.425094] [<c0012564>] (__irq_svc+0x44/0x54) from [<c0020244>] (__do_softirq+0x90/0x268) [ 3.433400] [<c0020244>] (__do_softirq+0x90/0x268) from [<c00207d4>] (irq_exit+0x9c/0xd8) [ 3.441619] [<c00207d4>] (irq_exit+0x9c/0xd8) from [<c000fca0>] (handle_IRQ+0x34/0x84) [ 3.449577] [<c000fca0>] (handle_IRQ+0x34/0x84) from [<c0012564>] (__irq_svc+0x44/0x54) [ 3.457629] [<c0012564>] (__irq_svc+0x44/0x54) from [<c04602b0>] (_raw_spin_unlock_irqrestore+0x34/0x44) [ 3.467164] [<c04602b0>] (_raw_spin_unlock_irqrestore+0x34/0x44) from [<c0348298>] (input_register_handler+0x98/0xb4) [ 3.477835] [<c0348298>] (input_register_handler+0x98/0xb4) from [<c064bc10>] (mousedev_init+0x30/0x60) [ 3.487275] [<c064bc10>] (mousedev_init+0x30/0x60) from [<c00088ac>] (do_one_initcall+0xe8/0x154) [ 3.496198] [<c00088ac>] (do_one_initcall+0xe8/0x154) from [<c062aabc>] (kernel_init_freeable+0xf0/0x1b4) [ 3.505810] [<c062aabc>] (kernel_init_freeable+0xf0/0x1b4) from [<c0456550>] (kernel_init+0x8/0xe4) [ 3.514899] [<c0456550>] (kernel_init+0x8/0xe4) from [<c000ee60>] (ret_from_fork+0x14/0x34) [ 3.523263] handlers: [ 3.525578] [<c0339d14>] ci_irq [ 3.528757] Disabling IRQ #237 Provide the USB0_ID pin in the usb0 node, so that g_ether can operate correctly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-16ARM: dts: mxs: add pin config for LCD sync and clock pinsLothar Waßmann
2013-08-16ARM: dts: mxs: add pin config for SSP3 interfaceLothar Waßmann
2013-08-16ARM: dts: mxs: add another set of saif0_pins (without MCLK)Lothar Waßmann
2013-08-16ARM: dts: mxs: add labels to most nodes for easier referenceLothar Waßmann
2013-08-16ARM: dts: mxs: whitespace cleanupLothar Waßmann
2013-08-16ARM: dts: mxs: Add spi aliasFabio Estevam
After providing spi alias, we can get the following message during probe: m25p80 spi1.0: sst25vf016b (2048 Kbytes) ,which looks better than the original one: m25p80 spi32766.0: sst25vf016b (2048 Kbytes) While at it, keep the alias entries in alphabetical order. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-16ARM: dts: mxs: remove old DMA binding data from client nodesShawn Guo
After mxs-dma driver adopts generic DMA device tree binding, channel interrupt number is defined in DMA controller node, and channel ID is listed in "dmas" property. So the DMA channel interrupt number in client nodes' "interrupts" property and fsl,<module>-dma-channel which are used by old customized DMA binding can be removed now. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2013-07-15ARM: mxs: saif0 is the clock provider to sgtl5000Shawn Guo
These systems all use saif0 as the mclock provider to codec sgtl5000. Reflect that in device tree source, so that sgtl5000 can find the clock by calling clk_get(). Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-07-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Do not idle omap device between crypto operations in one session. - Added sha224/sha384 shims for SSSE3. - More optimisations for camellia-aesni-avx2. - Removed defunct blowfish/twofish AVX2 implementations. - Added unaligned buffer self-tests. - Added PCLMULQDQ optimisation for CRCT10DIF. - Added support for Freescale's DCP co-processor - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits) crypto: testmgr - test hash implementations with unaligned buffers crypto: testmgr - test AEADs with unaligned buffers crypto: testmgr - test skciphers with unaligned buffers crypto: testmgr - check that entries in alg_test_descs are in correct order Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher" Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher" crypto: camellia-aesni-avx2 - tune assembly code for more performance hwrng: bcm2835 - fix MODULE_LICENSE tag hwrng: nomadik - use clk_prepare_enable() crypto: picoxcell - replace strict_strtoul() with kstrtoul() crypto: dcp - Staticize local symbols crypto: dcp - Use NULL instead of 0 crypto: dcp - Use devm_* APIs crypto: dcp - Remove redundant platform_set_drvdata() hwrng: use platform_{get,set}_drvdata() crypto: omap-aes - Don't idle/start AES device between Encrypt operations crypto: crct10dif - Use PTR_RET crypto: ux500 - Cocci spatch "resource_size.spatch" crypto: sha256_ssse3 - add sha224 support crypto: sha512_ssse3 - add sha384 support ...
2013-06-20Merge tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/dt From Shawn Guo: mxs device tree changes for 3.11: * A couple of new board support, cfa10055 and cfa10057 * A few updates on cfa10036 device tree source * Some auart pinctrl data addition * Adopt soc bus infrastructure for mach-mxs * tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs: dt: Add Crystalfontz CFA-10057 device tree ARM: mxs: dt: Add the Crystalfontz CFA-10055 device tree ARM: cfa10049: Switch the chip select pin of the LCD controller ARM: cfa10036: Add USB0 OTG port ARM: dts: apf28dev: Add touchscreen support for APF28dev ARM: mxs: Fix UARTs on M28EVK ARM: cfa10036: dt: Change i2c0 clock frequency ARM: dts: cfa10036: Change the OLED display to SSD1306 ARM: mx28: add auart4 2 pins pinmux to imx28.dtsi ARM: mx28: add auart3 2 pins pinmux to imx28.dtsi ARM: mx28: add auart2 2 pins pinmux to imx28.dtsi ARM: mxs: Use soc bus infrastructure ARM: dts: mx28: Adjust the digctl compatible string ARM: mxs: Remove init_irq declaration in machine description Includes an update to 3.10-rc6 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-17ARM: mx28: add auart4 2 pins pinmux to imx28.dtsiEric Bénard
Add auart4 2 pins configuration on SSP3 pads Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: mx28: add auart3 2 pins pinmux to imx28.dtsiEric Bénard
Add auart3 2 pins configuration on its main pads Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: mx28: add auart2 2 pins pinmux to imx28.dtsiEric Bénard
Add auart2 2 pins configuration on its main pads Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: mx28: Adjust the digctl compatible stringFabio Estevam
MX28 has the same DIGCTL block as MX23, so adjust the compatible string to reflect that. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-05-28crypto: dcp - Added support for Freescale's DCP co-processorTobias Rauter
This patch enables the DCP crypto functionality on imx28. Currently, only aes-128-cbc is supported. Moreover, the dcpboot misc-device, which is used by Freescale's SDK tools and uses a non-software-readable OTP-key, is added. Changes of v2: - ring buffer for hardware-descriptors - use of ablkcipher walk - OTP key encryption/decryption via misc-device (compatible to Freescale-SDK) - overall cleanup The DCP is also capable of sha1/sha256 but I won't be able to add that anytime soon. Tested with built-in runtime-self-test, tcrypt and openssl via cryptodev 1.6 on imx28-evk and a custom built imx28-board. Signed-off-by: Tobias Rauter <tobias.rauter@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-23ARM: dts: imx: cpus/cpu nodes dts updatesLorenzo Pieralisi
This patch updates the in-kernel dts files according to the latest cpus and cpu bindings updates for ARM. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-04ARM: dts: add generic DMA device tree binding for mxs-dmaShawn Guo
Add generic DMA device tree binding for mxs-dma. The changes include: * Add channel interrupts into DMA controller nodes * Add properties '#dma-cells' and 'dma-channels' for DMA controller nodes * And properties 'dmas' and 'dma-names' for DMA client nodes * Update mxs-dma device tree binding doc Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2013-04-04ARM: dts: mxs: add enet_out clock to devicetreeWolfram Sang
Put the clock to the devicetree, so the driver can take care of it later. Then, we don't have to do the enabling as a workaround in board init. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> [shawn.guo: add enet_out into imx28.dtsi and overwrite it for m28evk] Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: get ocotp base address from device treeShawn Guo
Instead of using the static definitions, get ocotp base address from device tree with mapping. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mxs: get reset address from device treeShawn Guo
Instead of using static address definition, get reset address from device tree with mapping, so that core_initcall mxs_arch_reset_init() can be killed. The "rtc" clock code in mxs_arch_reset_init() seems to be zombie, since there is no clk lookup defined in clock driver at all. Remove it together. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01clk: mxs: get base address from device treeShawn Guo
Instead of using the static definitions, get clkctrl and digctl base addresses with mapping from device tree. Use macro on variable is not nice, but it's done here to save huge pointless diff stat. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-04-01ARM: mxs: look up timrot clock from device treeShawn Guo
Change call clk_get_sys() to of_clk_get() to look up timrot clock from device tree, so that the clk_register_clkdev() call for timrot can be saved in clock driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-29ARM: dts: mxs: Add muxing options for the third PWMMaxime Ripard
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
2012-11-16Merge tag 'mxs-dt-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/dt From Shawn Guo <shawn.guo@linaro.org>: It's mxs device tree changes for 3.8. The majority is device tree source updates. One timer improvement and one defconfig update are also included there. * tag 'mxs-dt-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs_defconfig: Improve USB related support ARM: mxs: apf28dev: Add I2C and SPI support ARM: mxs: Setup scheduler clock ARM: dts: mxs: Add hog pins to Crystalfontz boards ARM: dts: cfa10036: Use pinctrl for power led ARM: mxs: apf28dev: Add LCD and backlight support ARM: mxs: apf28dev: Add pinctrl and gpios ARM: dts: mxs: Add 16 bits LCD screen muxing options for I.MX28 ARM: dts: cfa10049: Add the DH2228FV DAC to the DTS ARM: mxs: Add support for the Armadeus Systems APF28Dev docking board ARM: mx28: Skip OCOTP FEC MAC setup if in DT ARM: dts: mxs: Add PWM3 muxing options for i.MX28 ARM: mxs: Add support for the Armadeus Systems APF28 module ARM: dts: cfa10049: Add FEC to the CFA-10049 expansion board ARM: dts: imx23-olinuxino: Use pinctrl for gpio-led ARM: dts: imx23-olinuxino: Remove unneeded "default-on" ARM: dts: imx28-evk: Use pinctrl for gpio-led Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-16ARM: dts: enable dma support for auart0 in mx28Huang Shijie
enable the dma support for auart0 in mx28. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-02ARM: dts: mxs: Add 16 bits LCD screen muxing options for I.MX28Gwenhael Goavec-Merou
Signed-off-by: Julien Boibessot <julien.boibessot@armadeus.com> Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-10-30ARM: dts: mxs: Add PWM3 muxing options for i.MX28Julien Boibessot
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Julien Boibessot <julien.boibessot@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
