The change corrects cpu compatible property to a defined one,
see Documentation/devicetree/bindings/arm/cpus.txt
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Since commit 3d42a379b6fa5b46058e3302b1802b29f64865bb
("can: flexcan: add 2nd clock to support imx53 and newer")
the can driver requires a dt nodes to have a second clock.
Add them to imx35 to fix probing the flex can driver on the
respective platforms.
Signed-off-by: Denis Carikli <denis@eukrea.com>
Cc: <stable@vger.kernel.org>
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
This patch adds simple-card support to the i.MX SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds the missing (General Purpose Timer) GPT devicetree node
for i.MX35 CPUs.
Like other imx SoCs only one USB clock is needed on mx35.
Add alias for FEC ethernet on i.MX to allow bootloaders (like U-Boot)
patch-in the MAC address for FEC using this alias.
Cc: Eric Bénard <eric@eukrea.com>
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
