path: root/arch/arm/boot/dts/imx6dl-aristainetos_7.dts
2015-03-30ARM: dts: imx6dl-aristainetos: enable backlight PWM explicitlyPhilipp Zabel
All PWM users should explicitly enable the used PWMs in their device tree so they can be disabled by default in imx6qdl.dtsi. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-07-18ARM: dts: imx6: add aristainetos board supportHeiko Schocher
This patch add support for the imx6dl based aristainetos board with following configuration: CPU: Freescale i.MX6DL rev1.1 at 792 MHz DRAM: 1 GiB NAND: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 SF: Detected N25Q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB As this board can used with 2 different display types, the differences between them are extracted into 2 DTS files, and the common settings are collected in a common file. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
