With the move from the 3.14.52 to the 4.1 kernel the way the weim
node defines chipselects changed.
A phandle to the gpr node is needed.
Only the following 4 configuration can be specified in the ranges property:
CS0(128M), CS1 (0M), CS2(0M), CS3(0M)
CS0(64M), CS1(64M), CS2(0M), CS3(0M)
CS0(64M), CS1(32M), CS2(32M), CS3(0M)
CS0(32M), CS1(32M), CS2(32M), CS3(32M)
With /sys/class/pwm a more versatile interface to pwm exists now.
PWM<A>: pwmchip3 export 0
PWM<B>: pwmchip1 export 0
PWM<C>: pwmchip4 export 0
PWM<B>: pwmchip2 export 0
e.g. configure a 1kHz 25% on PWM<C>:
(period and duty cycle in nano seconds)
$ cd /sys/class/pwm/pwmchip3
$ echo 0 > export
$ echo 1000000 > pwm0/period
$ echo 250000 > pwm0/duty_cycle
$ echo 1 > pwm0/enable
Use the device evalspi for spidev nodes.
This prevents a lot of useless warnings that spidev should not be used.
see commit 5c27aa11b23c3b6960e46f5cb5dee37c842bb8b6
Enable ADV7280 decoder for iMX6 modules. ADV7280 and ADV7180 have
same addresses viz. 0x21 respectively, changing the ADV7280 address
to 0x20 would result in a conflict with MAX9526. As a result enable
ADV7280 by default and disable ADV7180.
Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com>
(cherry picked from commit b7798ad9dccd6b1f54a0c1bbbfa3290934dc5d9b)
According to the datasheet the SPI clock (for read) must not exceed
1 / 55ns for i.MX6Q/D and 1 / 43ns for i.MX6DL/S.
Reflect that correctly in the device tree.
(cherry picked from commit c34080f3883684576b7629b3571dc9a1e018d511)
Synchronize with imx6dl-colibri-eval-v3.dts.
(cherry picked from commit 60bc22ab87825d102639ab5977a8340861e4a7ac)
This allows for easier disabling of unused cameras.
(cherry picked from commit 67c38ded18b74f229dd8c692bb1e8a51badee608)
(cherry picked from commit 1d87bfe7dcb69a9af7b2ce58cf9d810167042933)
