Boards based on imx6qdl have duplicate memory nodes:
- One coming from the board device tree file: memory@
- One coming from the imx6qdl.dtsi file.
Fix the duplication by removing the memory node from
the imx6qdl.dtsi file and by adding 'device_type = "memory";'
in the board Device Tree.
Converted using the following command:
perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"``
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Adopt the SPDX license identifier headers to ease license compliance
management.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Downstream packages like Debian flash-kernel use
/proc/device-tree/model
to determine which dtb file to install.
Hence each dts in the Linux kernel should provide a unique model
identifier.
Commit 8536239e371f ("ARM: dts: Restructure imx6qdl-wandboard.dtsi for new
rev C1 board.")' created new files imx6dl-wandboard-revb1.dts and
imx6q-wandboard-revb1.dts but used the same model identifier as in
imx6dl-wandboard.dts and imx6q-wandboard.dts.
This patch provides unique model identifiers for revision B1 of
the Wandboard Dual and Wandbaord Quad.
The patch leaves imx6dl-wandboard.dts and imx6q-wandboard.dts unchanged
because it is not foreseeable if the same dts will valid for future
board revisions or not. Furthermore we should avoid unnecessary
changes.
The rev C1 Wandboard uses the Broadcom 4330 for WiFi and Bluetooth instead of
the 4329. This changes the PADS assigned for the control lines. Another
side effect of the change is that on the rev C1 board, usdhc driver can't
detect the chip presence correctly so usdhc2 now needs its 'non-removeable'
property removed.
So that rev B1 and earlier can continue to work, this patch splits the
board-specific definitions from imx6qdl-wandboard.dtsi into
imx6qdl-wandboard-revb1.dtsi and imx6qdl-wandboard-revc1.dtsi. The new files
include the original base imx6qdl-wandboard.dtsi which retains the common
definitions.
The existing imx6dl-wandboard.dts includes imx6qdl-wandboard-revc1.dtsi and
imx6dl-wandboard-revb1.dts (new) includes imx6qdl-wandboard-revb1.dtsi.
This makes the rev C1 board the new default. The same pattern is used for
So, from U-Boot on a WB-Quad you use imxq-wandboard-revb1.dtb for the older B1
board and imxq-wandboard.dtb for the current rev C1 board.
Signed-off-by: George Joseph <george.joseph@fairview5.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
