The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Arrange the license text a bit to make it clear.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Update SolidRun iMX6 platforms DT descriptions to be dual-licensed.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Rabeeh Khoury <rabeeh@solid-run.com>
Spread-spectrum doesn't work with Cubox-i hardware. eSATA devices are
detected, but then fail on normal IO. Therefore, disable this feature.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Add the transmit level, boost and attenuation parameters necessary for
the eSATA interface on Cubox-i to work.
Add support for the SolidRun Cubox-i devices. This commit adds similar
basic support as the HummingBoard. Further devices will be supported
in future patches.
