Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
commit 89c1a8cf63f8c69dfddb6e377c04df8b25ab1c88 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
This adds the stdout-path property to various i.MX boards. Values
of the property have been taken from barebox, so they should be
correct. Also, the older linux,stdout-path property is converted
to stdout-path.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Add support for the GK802 'QUAD CORE Mini PC', which seems to be loosely
based on the Freescale i.MX6Q HDMI dongle reference design.
It is supposedly identical to the Hiapad Hi802.
