Based on 1 normalized pattern(s):
the code contained herein is licensed under the gnu general public
license you may obtain a copy of the gnu general public license
version 2 or later at the following locations http www opensource
org licenses gpl license html http www gnu org copyleft gpl html
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 161 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de
Boards based on imx6qdl have duplicate memory nodes:
- One coming from the board device tree file: memory@
- One coming from the imx6qdl.dtsi file.
Fix the duplication by removing the memory node from
the imx6qdl.dtsi file and by adding 'device_type = "memory";'
in the board Device Tree.
Converted using the following command:
perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"``
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
Pull "i.MX device tree updates for 4.15" from Shawn Guo:
- New board support: i.MX51 ZII RDU1, i.MX53 GE Healthcare PPD, i.MX6
TX modules for MB7 from Ka-Ro Electronics, i.MX6 Wandboard revd1
variants, i.MX6 LWN DISPLAY5 board, Pistachio i.MX6Q board, i.MX6SX
Vining-2000 board.
- Use the 'vpcie-supply' property for PCIe device for boards
imx6qdl-sabresd, imx6q-novena and imx6q-cm-fx6.
- A series from Jagan Teki to update imx6qdl-icore board with audio,
touch and CAN support.
- Switch to nvmem for accessing OCOTP from tempmon for i.MX6SX and add
tempmon support for i.MX6UL.
- A bunch of patches from Lothar Waßmann updating Ka-Ro i.MX28, i.MX53
and i.MX6 TX modules.
- Fix DTC warnings in i.MX device trees, dropping leading zeros from
unit address, correcting display nodes notation and display port
names, fixing nodes with unit name and no reg property.
- Other random device updates for various board support.
* tag 'imx-dt-4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (63 commits)
ARM: dts: imx53-tx53: fix interrupt flags
ARM: dts: imx28-tx28: fix interrupt flags
ARM: dts: display5: Device tree description of LWN's DISPLAY5 board
ARM: dts: imx53-qsb-common: Fix 'led_gpio7_7@0' node with unit name and no reg property
ARM: dts: imx53-m53evk: Fix 'led_gpio@0' node with unit name and no reg property
ARM: dts: imx53: Fix 'usbphy@x' node with unit name and no reg property
ARM: dts: imx51-ts4800: Fix 'port@0' node with unit name and no reg property
ARM: dts: imx51-apf51dev: Fix 'backlight@bl1' node with unit name and no reg property
ARM: dts: imx: add ZII RDU1 board
ARM: dts: imx: add support for TX6 modules on MB7 baseboard
ARM: dts: imx: add support for TX6QP
ARM: dts: imx6-tx6: add a .dtsi file for the MB7 baseboard
ARM: dts: imx6-tx6: move display configuration to .dtsi file
ARM: dts: imx6-tx6: add support for I2C bus recovery
ARM: dts: imx6-tx6: convert to using simple-audio-card
ARM: dts: imx6-tx6: specify ethernet phy reset post-delay
ARM: dts: imx6-tx6: improve ethernet related pinctrl setup
ARM: dts: imx6-tx6: add trickle-charge config for DS1339
ARM: dts: imx6-tx6: remove obsolete ipu1 alias
ARM: dts: imx6-tx6: remove obsolete eeti,egalax_ts
[arnd: made sure we have no new leading zeroes in unit address during merge]
The container node in the iomuxc node is no longer necessary and causes
pinctl errors on the Ventana boards with analog video capture
since aa12693e4156adafdef80a8bd134123a6419621b:
pinctrl core: initialized pinctrl subsystem
imx6q-pinctrl 20e0000.iomuxc: no groups defined in /soc/aips-bus@02000000/iomuxc@020e0000/adv7180grp
imx6q-pinctrl 20e0000.iomuxc: no groups defined in /soc/aips-bus@02000000/iomuxc@020e0000/ipu2_csi1grp
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx6q-pinctrl 20e0000.iomuxc: function 'iomuxc' not supported
imx6q-pinctrl 20e0000.iomuxc: invalid function iomuxc in map table
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and
considers that the Ethernet PHY is active low, unless the
property 'phy-reset-active-high' is present.
Fix the device tree description by explicitly passing the
'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Remove the sky2 ethernet device node from the pcie controller which was
invalid to begin with.
The original intent was to allow the bootloader to populate the MAC via
dt but this requires the PCI bus topology to be complete in dt as well
and as these boards have an expansion connector that topology is dynamic
and can't be represented here.
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Several dts files set a bit in the SPEED field for pads
RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there
doesn't have an effect and the bit reads as zero.
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
Using "IMX6QDL_CLK_CKO" for the clock is easier to read instead of
the hardcoded clock number.
Gateworks Ventana boards seem to need "RGMII-ID" (internal delay)
PHY mode, instead of simple "RGMII", for their Marvell 88E1510
transceiver. Otherwise, the Ethernet MAC doesn't work with Marvell PHY
driver (TX doesn't seem to work correctly).
Tested on GW5400 rev. C.
This bug affects ARM Fedora 23.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Acked-by: Tim Harvey <tharvey@gateworks.com>
Cc: <stable@vger.kernel.org>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Follow the conventions for pinctrl:
- grouping pinctrl in logical alphabatized groups
- remove any pinctrl not being used by a driver or needed by user
- move iomuxc to bottom of file for readability
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Follow the convention of configuring padconf for all pins and not leaving
any 0x80000000 to leave them un-configured.
Use the gpio contants defined in bindings for active high/low
Remove aliases that are either not used by bootloader or are provided via
included dtsi files.
The general device-tree rule is to not include nodes that do not have a driver
or bindings in a dts/dtsi. Remove the place-holder nodes from the Gateworks
Ventana boards until a time that a driver with proper bindings exists.
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
The 'model' property in the imx-audio-sgtl5000 binding specifies the
user-visible name of the audio device. This should be something common and
not baseboard specific.
Configure ddc and enable HDMI
Since commit (655b43c staging: imx-drm-core: Use OF graph to find
components and connections between encoder and crtcs), 'crtcs' becomes a
dead property. Remove it.
The Gateworks Ventana product family consists of several baseboard designs
based on the Freescale i.MX6 family of processors. Each baseboard has a
different set of possible features.
