Commit f014b5b3b3ab added an additional clock to ahci_imx.c used
on i.MX8. Add a dummy clock to imx6q.dtsi so that i.MX6 which doesn't
need the clock the driver keeps working.
Fixes:
[ 2.053942] ahci-imx 2200000.sata: can't get sata_ext clock.
[ 2.053962] ahci-imx: probe of 2200000.sata failed with error -2
Revert below upstreaming patch which broke SPI5 dma since ram
script used for ecspi to workaroud ERR009165 and spi driver
changed to XCH mode instead of SMC.
Revert "ARM: dts: imx6q: Use correct SDMA script for SPI5 core"
This reverts commit df07101e1c4a29e820df02f9989a066988b160e6.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
(cherry picked from commit 443e65efad14aa3fe1c99ead8fac10ec856b7e44)
This node will be used by the OCRAM driver in optee to:
* Get the OCRAM start address for power management in optee.
* Add an entry that will overwrite ocrams nodes and dynamically reduce
the OCRAM available for mmio-sram in Linux.
That way we do not touch the legacy Linux boot and remove the dedicated
optee device tree.
Signed-off-by: Clement Faure <clement.faure@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Upstream refactored GPC power domains to have a nested pgc node, this
means that the pu power domain needs to be referenced differently.
This fixes warnings like these:
OF: /soc/gpu@00130000: could not get #power-domain-cells for
/soc/aips-bus@02000000/gpc@020dc000
This warning probably also means that GPU power management is not done
correctly.
Old bindings are still used on imx6s*
Fixes: 0a9a9a732f88 ("MGS-3705-1 gpu: dts: enable gpu devices for imx6")
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Xianzhong <xianzhong.li@nxp.com>
set GPU baseAddress with 256M on IMX6Q and iMX6QP,
add reserved cma in DTB to support different size,
the default cma size is 320M on all imx6 boards.
integrated patches from imx_4.9.y:
1.MGS-955 GPU:Integrate GPU module
commit: 73183c14a20d4f1d02317f80db3d90b3be1546fc
2.MGS-1211 gpu: add GPU for 6sl,6sx,6dl
commit: 80a8994c47cbb97fb31ef0efab92ddb29002448e
3.MGS-1087 gpu: Move the GPU reserved memory to DTS file
commit: ea0111da6892b52c790da607a3d91140d1ebf936
4.MGS-2540 [#ccc] Need set baseAddress with RAM start address on IMX6Q
commit: de838d99d9264884cbaaa601ab323a70b62634d9
Signed-off-by: Xianzhong <xianzhong.li@nxp.com>
When VPU is running at 396MHz, need to increase
VDDSOC_CAP voltage for all cpu set-points, so add
vpu clock node for cpufreq driver.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add busfreq device node label to allow override busfreq
properties on machine device tree descriptor
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Signed-off-by: Anson Huang <b20788@freescale.com>
(cherry picked from commit fd8faeb7a40fc2f9fb331d6ca6a60b64c95d7ee6)
Add imx v4l2 capture driver.
Signed-off-by: Sandor Yu <R01008@freescale.com>
Add IPU, HDMI and LDB support.
Add busfreq support for i.MX6Q/DL.
Add pll1, pll1_bypass and pll1_bypass_src clock
reference define in dts file.
Signed-off-by: Bai Ping <b51503@freescale.com>
Reserve iram space for low power code. The first 16KB space
is used for suspend/resume and cpuidle. Another 4KB space is
for busfreq code.
for i.MX6SX, it has a dedicated ocram space start at 0x8f8000
for low power code.
commit df07101e1c4a29e820df02f9989a066988b160e6 upstream.
According to the reference manual the shp_2_mcu / mcu_2_shp
scripts must be used for devices connected through the SPBA.
This fixes an issue we saw with DMA transfers.
Sometimes the SPI controller RX FIFO was not empty after a DMA
transfer and the driver got stuck in the next PIO transfer when
it read one word more than expected.
commit dd4b487b32a35 ("ARM: dts: imx6: Use correct SDMA script
for SPI cores") is fixing the same issue but only for SPI1 - 4.
Fixes: 677940258dd8e ("ARM: dts: imx6q: enable dma for ecspi5")
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Signed-off-by: Steve Longerbeam <steve_longerbeam@mentor.com>
This patch adds the device tree graph connecting the input multiplexers
to the IPU CSIs and the MIPI-CSI2 gasket on i.MX6. The MIPI_IPU
multiplexers are added as children of the iomuxc-gpr syscon device node.
On i.MX6Q/D two two-input multiplexers in front of IPU1 CSI0 and IPU2
CSI1 allow to select between CSI0/1 parallel input pads and the MIPI
CSI-2 virtual channels 0/3.
On i.MX6DL/S two five-input multiplexers in front of IPU1 CSI0 and IPU1
CSI1 allow to select between CSI0/1 parallel input pads and any of the
four MIPI CSI-2 virtual channels.
Changes from Steve Longerbeam:
- Removed some dangling/unused endpoints (ipu2_csi0_from_csi2ipu)
- Renamed the mipi virtual channel endpoint labels, from "mipi_csiX_..."
to "mipi_vcX...".
- Added input endpoint anchors to the video muxes for the connections
from parallel sensors.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
The IOMUXC General Purpose Register space contains various bitfields
that control video bus multiplexers. Describe them using a mmio-mux
node. The placement of the IPU CSI video mux controls differs between
i.MX6D/Q and i.MX6S/DL.
Adopt the i.MX6Q/DL DT to the new and more flexible GPC binding.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
To establish a connection between GPIO controllers and pin multiplexor
controller add gpio-ranges properties to all GPIO controllers found
on iMX50, iMX6Q/D, iMX6DL/S, iMX6SL, iMX6SX, iMX6UL and iMX7D/S
SoCs. The change was done after human parsing of output from
% gawk -n '{ sub(/.*__/, ""); if ($1 ~ "^GPIO") print $1, $2/4}' imxXX-pinfunc.h | sort -n
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
When compiled with "W=1", dtc complains: e.g.
"Warning (unit_address_vs_reg):
Node /soc/ipu@02800000/port@2/endpoint@0
has a unit name, but no reg property"
Endpoint nodes don't have a reg property, and the addresses
in their node names are ordinals without any special meaning
so remove them and swap them for semantic node names.
Signed-off-by: Joshua Clayton <stillcompiling@gmail.com>
The backlinks are already there since commit 4520e69238b3 ("ARM: dts:
imx6qdl: Add IPU DI ports and endpoints, move imx-drm node to dtsi")
and were moved by commit 70c2652c6c5b ("ARM: dts: imx6qdl: Move existing
MIPI DSI ports into a new 'ports' node"), but the links from IPU2 DI0/1
to the MIPI DSI mux are missing. Fix this.
The i.MX6Quad Plus processor is an high performance SOC of i.MX6 family.
It has enhanced graphics performance and increased overall memory bandwidth
compared to i.MX6Q. Most of the design are same as i.MX6Quad/Dual, so code
for i.MX6Quad can be resued by this chip. The revision number is identied as
i.MX6Q Rev2.0, but actually it is a new chip, as we did many change to the
overall architecture.
This patch adds basic dtsi file support for the new i.MX6Quad Plus processor.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
The pinctrl group ipu2grp is a leftover from the previous iomuxc DT
cleanup. It's not used by anyone now. More importantly, it's getting
in the way of saving the unnecessary pinfunc container node from the
board dts files that include imx6q.dtsi.
Let's clean it up.
Tested-by: Michael Trimarchi <michael@amarulasolutions.com>
This adds the device nodes for 2D, 3D and VG GPU cores.
This allows for consistent numbering of the IPU output and
input ports.
The MIPI DSI node contains some ports which represent possible DRM CRTCs
it can connect with. Each port has a 'reg' property embedded. This
property will be wrongly interpretted by the MIPI DSI bus driver, because
the driver will take each subnode which contains a 'reg' property as a
DSI peripheral device. This patch moves the existing MIPI DSI ports into
a new 'ports' node so that the MIPI DSI bus driver may distinguish its
DSI peripheral device(s) from the existing ports.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
Enable dma support for ecspi5 controller
Signed-off-by: Anton Bondarenko <anton_bondarenko@mentor.com>
According to latest i.MX6Q datasheet Rev. 3, 02/2014,
the latest cpufreq volt/freq table is as below:
LDO enabled/bypassed(min value):
996MHz: VDDARM: 1.225V, VDDSOC: 1.150V;
792MHz: VDDARM: 1.150V, VDDSOC: 1.150V;
396MHz: VDDARM: 0.925V, VDDSOC: 1.150V;
the 792MHz setpoint's VDDARM min voltage is updated
from 1.125V to 1.150V, adding 25mV to cover board IR
drop, 1.175V is the right voltage we should use.
This patch adds links to the on-chip SRAM and reset controller nodes
and switches the interrupts. Make the BIT processor interrupt, which exists on
all variants, the first one. The JPEG unit interrupt, which does not exist on
i.MX27 and i.MX5 thus is an optional second interrupt.
Use different compatible strings for i.MX6Q/D and i.MX6S/DL, as they have to
load separate firmware images for some reason.
Switch to use DT macro for clock ID, so that device tree source is more
readable.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds CSI subnodes for IPU1 and IPU2 that will contain
ports and endpoints connecting to external elements in the video
pipeline.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
This patch connects IPU and display encoder (HDMI, LVDS, MIPI)
device tree nodes, as well as parallel displays on the DISP0
and DISP1 outputs, using the OF graph bindings described in
Documentation/devicetree/bindings/media/video-interfaces.txt
The IPU ports correspond to the two display interfaces. The
order of endpoints in the ports is arbitrary.
Each encoder with an associated input multiplexer has multiple
input ports in the device tree. The order and reg property of
the ports must correspond to the multiplexer input order.
Since the imx-drm node now only needs to contain links to the
display interfaces, it can be moved to the SoC dtsi level. At
the board level, only connections between the display interface
ports and encoders or panels have to be added.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Extracted from another patch by Fabio Estevam, this adds the DT
configuration for HDMI output on the IMX6 SoCs
According to datasheet, i.MX6Q has setpoint of 852MHz
which is exclusive with 996MHz, the fuse map of speed_grading
defines the max speed of ARM, here we add this 852MHz
setpoint opp info, kernel will check the speed_grading
fuse and remove all illegal setpoints.
The quad version has a SPI controller more than the other
versions. Add an alias for it.
i.MX6Q needs to update vddarm, vddsoc/pu regulators when cpu freq
is changed, each setpoint has different voltage, so we need to
pass vddarm, vddsoc/pu's freq-voltage info from dts together.
According to datasheet, VDD_CACHE_CAP must not exceed VDDARM_CAP
by more than 200mV, as all of i.MX6Q boards' VDD_CACHE_CAP currently
are connected to VDDSOC_CAP, so we need to follow this rule by
increasing VDDARM_CAP's voltage.
Make the interrupts node slightly more readable.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
The ocram on imx6q is 256 KiB while on imx6dl it's 128 KiB. Let's
have separate node for imx6q and imx6dl. It also changes imx6q size
0x3f000 to 0x40000 to match the hardware.
Acked-by: Liu Ying <Ying.Liu@freescale.com>
Only imx6q has the ahci sata controller, enable
it on imx6q platforms.
Signed-off-by: Richard Zhu <r65037@freescale.com>
Add more imx6q/dl pin groups for those supported boards, e.g. sabresd,
sabreauto, arm2.
IPU2 pin groups are added into imx6q.dtsi, since the block is only
available on imx6q.
The imx6q and imx6dl are two pin-to-pin compatible SoCs. The same board
design can work with either chip plugged into the socket, e.g. sabresd
and sabreauto boards.
We currently define pin groups in imx6q.dtsi and imx6dl.dtsi
respectively because the pad macro names are different between two
chips. This brings a maintenance burden on having the same label point
to the same pin group defined in two places.
The patch replaces prefix MX6Q_ and MX6DL_ with MX6QDL_ for both SoCs
pad macro names. Then the pin groups becomes completely common between
imx6q and imx6dl and can just be moved into imx6qdl.dtsi, so that the
long term maintenance of imx6q/dt pin settings becomes easier.
Unfortunately, the change brings some dramatic diff stat, but it's all
about DTS file, and the ultimate net diff stat is good.
In the arm2 board, the UART2 works in the dte mode.
So add a pinctrl for both the imx6q{dl} boards.
Signed-off-by: Huang Shijie <b32955@freescale.com>
The i.MX6Q and i.MX6DL are pin compatible, so the pinmux entries
should be in sync. This patch systematically adds the pinmux entries
missing from the imx6q to the imx6dl file.
Some name inconsistencies and whitespace damage is fixed along the
way.
This new pinctrl is used by the imx6q-sabresd board.
into next/dt
From Shawn Guo:
imx device tree changes for 3.11:
* A bunch of new board additions, imx6sl-evk, vf610-twr, imx53-tx53,
imx53-m53evk and imx27-phytec-phycore
* Various pinctrl setting updates and additions
* Enable various on board peripherals, usb, audio, nor, display etc.
* Configure L2 cache data and tag latency from device tree
* Add imx-weim bus driver
* tag 'imx-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: (82 commits)
ARM: dts: imx27: Add VPU devicetree node
ARM: mxc: fix gpio-ranges for VF610
ARM: dtsi: imx6qdl-sabresd: Enable WM8962 audio support
ARM: dtsi: imx6qdl-sabresd: Enable SSI2 and AUDMUX
ARM: dtsi: imx6qdl-sabresd: Add WM8962 CODEC support
ARM: dtsi: imx6qdl-sabresd: add a fixed regulator for WM8962
ARM: dtsi: imx6dl: Add a pinctrl for AUDMUX
ARM: dtsi: imx6q/imx6dl: Add a pinctrl for I2C1
ARM: dts: imx6qdl-sabresd: add clko1 iomux configuration
ARM: dts: Phytec imx6q pfla02 and pbab01 support
ARM: dts: imx6q: Add pinctrl for usdhc2 and enet
ARM: dts: imx27-phytec-phycore-rdk: Add MTD name for NOR flash
ARM: dts: imx27-phytec-phycore-rdk: Add SDHC support
ARM: dts: i.MX27: Add SDHC devicetree nodes
ARM: dts: i.MX27: Add DMA devicetree node
ARM: dts: imx6qdl-sabreauto: enable the WEIM NOR
ARM: dts: imx6dl: add pinctrls for WEIM NOR
ARM: dts: imx6q: add pinctrls for WEIM NOR
ARM: dts: imx6qdl: add more information for WEIM
ARM: dts: imx6q{dl}: fix the pin conflict between SPI and WEIM
Add a pinctrl for I2C1 used on imx6q/dl-sabresd.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
Add a group to the usdhc2 and enet pinctrl.
Signed-off-by: Christian Hemp <c.hemp@phytec.de>
Add two pinctrls for WEIM:
one for the weim nor, another for the chipselect.
