Add mxt nodes to dts and gpio-reset functionality.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
To operate RS-485 on Toradex Carrier Boards a low active RTS signal
is required. Furthermore, a low active RTS signal requires the
receiver to be active (this seems to be a hardware limitation of the
i.MX UART).
The new Apalis iMX6 Mezzanine board allows access to the MIPI-CSI2
interface from the evaluation board. The current device tree has
different GPIO pin assignments for the camera reset and power pins.
Change the pin assignment to use Apalis GPIO1 for reset and Apalis
GPIO2 for power down.
The Atmel maXTouch multitouch controller driver does not control the
reset line connected to the chip. Use a GPIO reset controller node to
release the reset line and make the controller work.
Note that both the reset controller's and the mxt mutitouch controller's
node are set to disabled. Either change this in the dtsi source or fix
this from U-Boot if you use an Atmel maXTouch multitouch controller.
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay && fdt set /mxt-reset status okay'
The SNVS RTC does not use an address in its node name anymore.
Instead of using the full path, simply use the SNVS RTC label.
The imx pwm driver now support output inversion with a 3rd parameter.
While at it move the backlight pwm settings into the carrier board
file were it belongs. Period and polarity are carrier board / display
dependent.
gst-inspect mfw_v4lsrc
gst-launch mfw_v4lsrc capture-mode=5 device=/dev/video2 ! mfw_v4lsink
Signed-off-by: Wojciech Bieganski <wbieganski@antmicro.com>
(cherry picked from commit 4f4528cf031a4c6585bfcefd66607780de064de8)
(cherry picked from commit b34325c7f99d3f323214e8b0f121711330769646)
Merge of Apalis iMX6 module level device tree and initial
add of Apalis iMX6 Evaluation Board device tree. Copied
and adopted from the Toradex toradex_4.1-2.0.x-imx branch.
