Update IPU and display property, make sure these dts files can
pass build.
Signed-off-by: Sandor Yu <R01008@freescale.com>
commit 89c1a8cf63f8c69dfddb6e377c04df8b25ab1c88 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Add the DT description for the SGTL5000 found on the Hummingboard Pro
model.
Setup pwm lines as follows -
pwm1: In case HummingBoard base carrier; this pin drives through a serial
capacitor the mono out of the audio jack.
In case HummingBoard pro the this pad can be reached by wiring to
C8 capacitors on the board.
pwm2: Setup pwm2 on gpio-1 but leave the default function of the iopad as
a gpio.
The user can change the io pad mux in user space and therefore use
this function on gpio-1 (pin number 7 on the 26 pin header).
pwm3,pwm4: unused
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
[tweaked alias for pwm pinctrl group --rmk]
Enable the commented out PCF8523 RTC support for Hummingboard pro
base boards.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Update SolidRun iMX6 platforms DT descriptions to be dual-licensed.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Rabeeh Khoury <rabeeh@solid-run.com>
Add the IOMUX setting for the IR input, rather than relying on the
boot loader.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
HummingBoard after rev 2.0 and the production one starting rev 3.0 uses
gpio 3,5 (EIM_DA5 pad) as the gpio infra red receiver input.
Since the original Carrier1 board is obsolete and we are retiring it,
update the DT file for this. This will mean IR reception will not
work on Carrier1 with this DT file.
