Arrange the license text a bit to make it clear.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Update SolidRun iMX6 platforms DT descriptions to be dual-licensed.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Rabeeh Khoury <rabeeh@solid-run.com>
This patch is important for the MicroSOM implementation due to the
following details -
1. VIH of the Atheros phy is 1.7V.
2. NVCC_ENET which is the power domain of the MDIO pad is driven by the
PHY's LDO (i.e. either 1.8v or 2.5v).
3. The MicroSOM implements an onbouard 1.6kohm pull up to 3.3v (R3000).
In the case the PHY's LDO was 1.8v then there would be only a 100mV
margin for the signal to be acknowledged as high (1.8v-1.7v).
Due to that setting the pad as an open drain will let the 1.6kohm pull
that signal high to 3.3 that assures enough margins to the PHY to be
acked as '1' logic.
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Bit 6,7 are marked as reserved for the ethernet RGMII pins, so avoid
setting these bits.
Add support for the SolidRun HummingBoard. This commit adds support for
the following interfaces on this board:
- Consumer Ir receiver
- S/PDIF output
- Both USB interfaces
- Gigabit Ethernet using AR8035
- UART port
